Reading: Applications of Needle Valves
Inst Tools > Blog > Control Valves > Applications of Needle Valves
Last updated: March 21, 2019 3:22 pm
Control Valves
A needle valve is a type of valve having a small port and a threaded, needle-shaped plunger.
Applications of Needle ValvesConstruction and operationUses of Needle Valves
It allows precise regulation of flow, although it is generally only capable of relatively low flow rates.
Applications of Needle Valves | Advantages of Needle Valve
An instrument needle valve uses a tapered pin to gradually open a space for fine control of flow. The flow can be controlled and regulated with the use of a spindle.
A needle valve has a relatively small orifice with a long, tapered seat, and a needle-shaped plunger on the end of a screw, which exactly fits the seat.
As the screw is turned and the plunger retracted, flow between the seat and the plunger is possible; however, until the plunger is completely retracted, the fluid flow is significantly impeded.
Since it takes many turns of the fine-threaded screw to retract the plunger, precise regulation of the flow rate is possible.
The virtue of the needle valve is from the vernier effect of the ratio between the needle’s length and its diameter, or the difference in diameter between needle and seat.
A long travel axially (the control input) makes for a very small and precise change radially (affecting the resultant flow).
Needle valves may also be used in vacuum systems, when a precise control of gas flow is required, at low pressure, such as when filling gas-filled vacuum tubes, gas lasers and similar devices.
Needle valves are usually used in flow-metering applications, especially when a constant, calibrated, low flow rate must be maintained for some time, such as the idle fuel flow in a carburettor.
Note that the float valve of a carburettor (controlling the fuel level within the carburettor) is not a needle valve, although it is commonly described as one. It uses a bluntly conical needle, but it seats against a square-edged seat rather than a matching cone. The intention here is to obtain a well-defined seat between two narrow mating surfaces, giving firm shutoff of the flow from only a light float pressure.
Needle valves are also commonly used to provide shut off for the pressure gauge or on applicators to shut off the supply of NH3 to the knives in Anhydrous Ammonia (NH3) applications.
Since flow rates are low and many turns of the valve stem are required to completely open or close, needle valves are not used for simple shutoff applications.
Since the orifice is small and the force advantage of the fine-threaded stem is high, needle valves are usually easy to shut off completely, with merely “finger-tight” pressure. The spindle and/or seat of a needle valve, especially one made from brass, are easily damaged by excessive turning force when shutting off the flow.
Small, simple needle valves are often used as bleed valves in water-heating applications.
Unlike a ball valve or valves with a rising stem, it is not easy to tell from examining the handle position whether the valve is open or closed.
Valves Pressure Loss – Questions and Answers
What is Butterfly Check Valve ?
How Needle Valve Works ?
Control Valve Interview Questions and Answers
Control Valves Theory
What is an Altitude Valve?
Control Valve Parts Questions and Answers
Globe Valve Body Design
Pressure Safety Valve Leak Test Procedure (PSV Testing)
Introduction to Types of Valves
Why Restriction Orifice is some distance from Blowdown valve ?
SIS Final Control Elements
Objective Questions on Valves
Shaft and Coupling Bore Tapers Repair Caused Frequent Shutdowns
CONTROL VALVE CHARACTERISTICS
Difference between Quick Opening, Linear & Equal Percentage Control Valve characteristics
On-OFF Valve Animation
What is ON/OFF Valve ?
Direct & reverse actions control valve
Direct Acting Control Valves & Reverse Acting Control Valves
Basic Configuration of Motor Operated Valve
Rotork Motor Operated Valve Basic Configuration
Basics of Actuators
Basics of Actuators
Root Cause Analysis for Valve Problem
Root Cause Analysis for Tank Overflow due to Valve Problem
Control Valve Positioners
Free Online Control Valves Course
Free Control Valves Course
Connect the Differential Pressure Gauge at the Filter
How Do You Connect the Differential Pressure Gauge at the Filter?
Armature Current in a DC Motor
DC Motor Torque
Intelligent Motor Control Center
What is an Intelligent Motor Control Center? – IMCC
Robotic Process Automation
What is Robotic Process Automation? Advantages, Applications
Control Valves Chemical attack Problems
Example of Automated Guided Vehicle with PLC
Displacer interface level measurement Calibration
Displacer Interface Level Measurement
Orifice Beta
