Reading: What is the Simple Alternative Vessel Level Indication?
Inst Tools > Blog > Level Measurement > What is the Simple Alternative Vessel Level Indication?
A large vessel containing crude oil has a defective radar-based level transmitter. How do you choose a simple alternative level indication?
Last updated: January 25, 2021 8:49 pm
Level Measurement Practical Questions
1 Min Read
Until the level transmitter is replaced by one of your co-workers, operators need to periodically check the crude oil level in the vessel.
The vessel is vented, but inaccessible to a tape measure, float, or any other manual “sounding” device one might ordinarily use to determine liquid level in a vessel.
Devise a way to provide a simple yet reasonably accurate level measurement indication for operators to use while they wait for the radar-based level transmitter to be replaced.
Connect a pressure gauge to any accessible port near the bottom of the vessel, and hand-sketch a “level” scale on the gauge face reading in whatever units of measurement the operators find most convenient to use.
You can correlating pressure in PSI to level based on the assumed density of the crude oil.
Do you have any other ideas? Share with us through the below comments section.
  • What is Water Cut Meter?
  • pH Meters Questions & Answers
  • Optical Data Communication
  • Valve Position Indication
  • Identify the Pressure Gauge Error
Credits: Tony R. Kuphaldt
Level Sensors MCQ – Industrial Instrumentation
Explain What these Spool Valve Symbols Represent?
Calibrating Level Transmitter with Remote Seals
Practical Process Control System Questions & Answers – 11
Guided-wave Radar Level Measurement Animation
Tilt Level Switch Working Animation
Cat and Mouse type Level Indicator
Pressure Transmitter using Potentiometer and Diaphragm
Analyze the Relay Circuit and Find the Status ?
Basics of Level Measurement
PLC Practice Questions
Basics of Hydrostatic Level Measurement
Draw Wiring of a Pressure Switch to control two lamps
DP Transmitter Dry Leg & Wet Leg Calculations
Calibration setup for a low-range electronic pressure transmitter
Instrument Lab Exercise – Ranging and Manometer Usage
RF Admittance Level Transmitter Working Principle
thermocouple Transmitter Formula
Calculate Process Temperature using a Thermocouple
Programmable Logic Controller (PLC) Questions and Answers – 1
pressure switch ladder-logic diagram
Draw the appropriate Pressure Switch Symbol ?
Flow Transmitter Readings mismatch with DCS
Float Level Switch Principle
Float Level Switch Working Principle Animation
level gauge
Basics of Sight Glass Level Gauge
Water Vapor in Instrument Air Lines
How to Minimize Water Vapor in Instrument Air Lines?
What is a Tag in SCADA
What is a Tag? Types of Tags in SCADA
Electron Flow Through Battery
Batteries Theory
Causes of PLC Stop Mode
Various Causes for PLC Going in Stop Mode
Safety Instrumented Systems Online Exam
Motor Primary Resistance Starter
Electrical Motor Starter Circuits
Process Control Instrumentation Terms Glossary
Pressure Gauge Water traps and pigtail siphons
Pressure Gauge Water Traps and Pigtail Siphons
