  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Allen Bradley Math Functions
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > Allen Bradley Math Functions
Last updated: March 4, 2021 3:23 pm
To study the working of Allen Bradley Math functions (ADD, SUB, MUL, DIV, SQR & NEG) using simple example in programmable logical controllers (PLC).
Allen Bradley Math FunctionsPLC Math FunctionsADD:SUB:MUL:DIV:SQRNEQ:Program LogicPLC Program using Math FunctionsLadder Logic Description:RUNG 0000:RUNG 0001:RUNG 0002:RUNG 0003:RUNG 0004:RUNG 0005:RUNG 0006:RUNG 0007:Conclusion:
Working with Math Blocks in AB PLC
There are three parameters in each block,
Source A –Address of the first Value
 Source B –Address of the second value
Destination (Dest) – Address where result of the function will store.
PLC Math Functions
ADD:
Add block is used to do the Addition of the two values stored in source A and source B and store the output in  destination address.
SUB:
Sub block is used to do the Subtraction of the two values stored in source A and source B and store the output in destination address.
MUL:
MUL block is used to do the Multiplication of the two values stored in source A and source B and store the output in destination address.
DIV:
DIV block is used to do the Division of the two values stored in source A and source B and store the output in destination address.
SQR
SQR block is used to find the square root of the value stored in source address and results the value in destination address.
NEQ:
NEQ block is used to negate the value stored in source address and results the value in destination.
Program Logic
When start switch is pressed,
  1. Value stored in N7:0 and N7:1 gets added and results the value in N7:2
  2. Add block output is one of the input to Sub block which do subtraction function by taking value stored in N7:1 and stores the address in N7:3.
  3. Sub block output is one the input to Mul block and perform multiplication along with value stored in N7:1 and stores the result in N7:4
  4. Mul block output is one the input to DIV block and perform Division along with value stored in N7:0 and stores the result in N7:5
  5. SQR block performs square root of the Value stored in N7:5 and results the output in N7:6.
  6. Value stored in N7:6 get negated using NEG block and results the final output in N7:7.
  7. If the resulted output is positive turn on output positive indication else output negative indication.
ADD and SUB Blocks in PLC Programming
MUL and DIV Blocks in PLC Programming
SQR and NEG Blocks in PLC Programming
LES and GRT Blocks in PLC Programming
RUNG 0000:
When Start switch is pressed, N7:0 and N7:1 get added and store the value in N7:2.
RUNG 0001:
Value stored in N7:2 get subtracted with value stored in N7:1 and results the value in N7:3.
RUNG 0002:
Value stored in N7:3 get multiplied with value stored in N7:1 and results the value in N7:4.
RUNG 0003:
Value stored in N7:4 get divided by value stored in N7:0 and results the value in N7:5.
RUNG 0004:
Value stored in N7:5 get squared and results the value in N7:6.
RUNG 0005:
Value stored in N7:6 get negated and results the value in N7:7.
RUNG 0006:
Less than block (Source B value sets to 0) is used to check whether the result is negative and results the output in indication lamp (O: 0/0)
RUNG 0007:
Greater than block (Source B value sets to 0) is used to check whether the result is positive and results the output in indication lamp (O: 0/1)
Conclusion:
We can use this example program to understand the working Math block functions in AB PLC.
Author : Hema Sundaresan
Single Push button Ladder Logic
Motor Logic with Push buttons
What is Latching in PLC ?
Masked Move Instruction in PLC
What is Interlocking in PLC ?
How to use PLC with SQL Database? – Basics & Tutorials
Ladder Diagram Example using Memory Bits and Set Coils
How to Choose a Suitable HMI for Your Application?
208kSubscribersSubscribe
Recent Comments
  • anuj kapoor on DCS Program to Maintain Draft in Furnace
  • anuj kapoor on IoT based Smart Boiler Control System with Cloud PLC and SCADA
Related Articles
CRA Module in Schneider PLC
CRA Module in Schneider PLC – Remote IO Adapter Module
Omron PLC Instructions - Move, Move Bit, Move Digit
Move, Move Bit, Move Digit – Examples of Omron PLC Programs
Elevator PLC Ladder Logic
Safety interlock for motor starters in Siemens PLC
Motor Starter Logic using Siemens PLC Tia Portal
PLC attendance system design
factorytalk view studio hmi
How to Create Templates in FactoryTalk View Studio?
IP Address Change in Simatic
PLC Configuration of Profinet I/O System
Move function block
Move Instruction in Tia Portal
More Articles
Circulating Pump
What is a Circulating Pump?
Level Measurement in Liquids
Point Level Detection Working Principle
JMP instruction in PLC Programming
How to use JUMP Instruction in PLC Ladder Logic?
Relay Parts
Difference Between NO and NC Contacts
AC Generator Operation
Types of AC Generators
Well Manometer Principle
Free WinCC SCADA Training Course
Free SCADA Training Course
Float level gauge Principle
Float Type Level Indicator Principle
