Reading: PLC Connection between Instrument, Junction Box, Marshalling & System Cabinet
Inst Tools > Blog > Control Systems > PLC Connection between Instrument, Junction Box, Marshalling & System Cabinet
Last updated: March 4, 2021 4:06 pm
Control Systems PLC Tutorials
19 Comments
A PLC connection represents the signal flow starting from the field transmitters, junction box, marshalling cabinet, system cabinet and Human-Machine Interface for the operator graphic display.
PLC ConnectionPLC or DCS Signal Flow :Field Instruments to Junction boxWiring between Marshalling and System CabinetsSummary
PLC Connection
DCS and PLC Flow Diagram
Here we are discussing about traditional 4-20mA analog input devices only for ease of understanding the basic concept.
We have thousands of field transmitters installed in a process plant. So it is practically difficult to lay straight individual cables from each field transmitter to control room for displaying the process variables on the workstation.
As per design standards, particular number of field devices / transmitters are wired and terminated in a Field Junction box.
Cable used for connecting the field device to Junction box are called as Branch cables or field cables. Generally we use one pair cables for branch cables.
The below figure shows 5 field devices are connected to a Junction Box using individual Branch cables.
In this example, for carrying out these five signals to control room  we need minimum 5 pair cable (means one cable have 5 pairs) and also we have to consider spare cable requirement for future purpose.
so at least 6 pair cable or better a 12 pair cable best suits the below requirement.
Say we choose 12 pair cable and is nothing but a Main Cable or Home run cable as it interfaces the field junction box and marshalling cabinet in the control room.
so finally one big main cable is required and serves our purpose.
Field Instruments to Junction Box
In a Process plant, we have so many Junction boxes installed and connected with number of field devices.
Say we have 100 no’s of Junction boxes installed that means we have 100 no’s main cables are there which are coming from field to control room.
so practically it not possible to directly wire these main cables to analog input/output cards. To avoid these problems we use Marshalling cabinet for terminating these 100 no’s main cables.
Marshalling cabinet main purpose is to provide main cables termination and then re-distribute the field devices to respective Analog Input/Output card using internal wiring.
Internal wiring will be used to connect from Marshalling cabinet to system cabinet.
Marshalling Cabinet to System Cabinet
System cabinet consists of Processor card (CPU), Analog Input Cards, Analog Output Cards, Communication cards etc.
Once Main cables are terminated in Marshalling cabinet, we have to take these field devices to the respective Analog input card channel.
so we use internal wiring to route these main cables/field devices from marshalling to system cabinet.
Once the main cables are connected to the Analog Input card via internal wiring and it converts the 4-20mA which is coming from field devices into equivalent Digital signal i.e. in Binary codes and the same will be communicated to Processor card.
The processor card performs as per the predefined or programmed instructions. The processor card may have inbuilt or separate Ethernet communication link which is used to display the measured process variables on the workstation.
Summary
The above animation depicts a typical cabling scheme that collects and distributes signals to and from the field devices.
A Field Junction Box is used to concentrate the signals into multi-conductor homerun cables or main cables.
The homerun cables then terminate in a remote or marshalling cabinet where the signals are marshalled (reorganized) as necessary to efficiently terminate at the I/O interface of the DCS or PLC system.
  • What is Fieldbus?
  • PLC or DCS Systems
  • Top 100 PLC MCQ
  • PLC Valve Control Logic
  • What is SCADA?
Electrical Switches Principle & Types
#10 PLC Best Practices – Assign Register Blocks by Function
PLC Pneumatic Circuit Control
Selection of Components Used In Electrical Earthing or Grounding
Direct Digital Control (DDC) Systems
How to tune a PID Controller ?
19 Comments
  • Thorn says:
    August 18, 2016 at 9:24 am
    It helps me a lot..Im just a beginner and need something like this,,,,thanks for posting
  • Jyoti says:
    December 11, 2016 at 7:42 pm
    Nice
  • Ajit Kumar Prasad says:
    January 25, 2017 at 3:07 am
    Thanks brother
  • Kamlesh sanchela says:
    March 10, 2017 at 9:02 am
    Thanks
  • Gulam Ahmed Raza says:
    August 17, 2017 at 12:49 pm
    Nice knowledge site
  • Kishor says:
    December 6, 2017 at 6:46 am
    Nice one
  • ANKIT KUMAR DIVEWADI says:
    December 15, 2017 at 1:59 pm
    Best site ever seen. Nice collection
  • abcde says:
    January 5, 2018 at 5:24 am
    How to do internal cross wiring for marshalling cabinet? please explain with animation or pics?
  • Nikanth says:
    January 7, 2018 at 2:35 pm
    Thanks a lot. It really helps me a lot to understand the basics. The Best Website for Inst Guys.
  • Ashik says:
    March 21, 2018 at 5:08 pm
    Ji super keep it up
  • husasain says:
    June 5, 2018 at 2:07 pm
    is it true?
    that fieldbus can omit marshaling cabinet
  • Faisal Hussain says:
    February 20, 2019 at 12:16 pm
    Wow thank allah it’s great web
    February 20, 2019 at 12:20 pm
    Thanks for helping
  • Bipin Chaudhari says:
    September 3, 2019 at 12:07 pm
    thanks!
  • ajay says:
    June 29, 2020 at 10:33 pm
    thanks a lot
  • Essam says:
    August 25, 2020 at 7:23 pm
    Thank you very much
  • MD IKBAL says:
    February 23, 2021 at 10:22 pm
    Verry use full knowledge
    Thanks Brother
  • Suresh Mishra says:
    May 22, 2021 at 11:17 am
    Very good knowledge
  • dilshad khan says:
    July 26, 2023 at 3:47 pm
    Great information for new one
Example of Flip-Flop PLC Program for Lamps Application
What are Faceplates? How to Create a Faceplate? HMI Visualization
PLC Programming for Traffic Barrier Control
What is Hot Standby in PLC?
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
2 wire transmitter current loops
Use Cryptographic checks for PLC
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
PLC Programming Limit Switch
PLC Program for Tank Heating Control using Heater
PLC Programming for Tank Heating Control using Heater
SCADA RTU TELEMETRY
SCADA & Telemetry Systems
PLC Program for Fishpond Water Level Monitoring System
PLC Program for Artificial Fishpond Water Level Monitoring System
Communicate between the PLC program and HMI program
Design a Program Using Studio 5000 and FactoryTalk View Studio
Difference Between Solenoid Valve and Motorized Valve
Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
Instrument Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
actuated-valve-schematic
Components of Shutdown Valve
HMI screen for operator
#8 PLC Best Practices – Validate HMI Input Variables at PLC Level
Thermocouple Reference Junction
Thermocouple Working Principle
Frequency Response MCQ
Experimentation of Transfer Function
BJT Amplifiers Interview Questions & Answers
