Reading: What is the OPC Server?
Inst Tools > Blog > Control Systems > What is the OPC Server?
The OPC server is a program that often connects with hardware like HMI to get the data and convert it into OPC protocol.
Last updated: March 4, 2021 11:05 am
Control Systems PLC Tutorials
3 Min Read
OPC stands for Open Platform Communications or some say  OLE (Object Linking and Embedding) for Process Control. It is a type of protocol used in Industrial Automation.
OPCAdvantages of OPC
The OPC is always used in the Client/Server pair. The OPC server converts the hardware communicated data from PLC into  OPC protocol. So that other software like SCADA can access the data.
The OPC client communicates with the OPC server to receive data or send commands to the hardware.
OPC
OPC Server
Image Credits: halvorsen
Usually, the OPC is implemented in a Single Server – Client in a single system format. But there are some famous alternate methods,
  • OPC aggregation – In this method, the OPC Client is connected to several OPC servers to acquire data
  • OPC bridging – In this method, the OPC server is connected with another OPC server to share data.
  • OPC tunneling – In this method, the OPC client is connected to an OPC server over a network.
The combination of OPC server and OPC client supports many connections. The OPC datahub is designed in such a way to handle all those connections.
In addition to improving OPC server and client connections, the OPC datahub can connect any OPC server or client to other applications as well, including Excel, a web browser, or any other database.
The Following are some of the OPC specifications that are used in Industries,
  • OPC AE ( Alarms and Events) – OPC AE servers are used to accept and exchange process alarms and events.
  • OPC-HDA (Historical Data Access) – This is used to retrieve historical process data for analysis. This data is typically stored in files, databases, or remote telemetry systems.
  • OPC-DA (Data Access) – Provides access to real-time data. We can query the most recent values of temperature, pressure, density, acceleration, and other types of process control data from the OPC-DA server.
Advantages of OPC
Some of the benefits of using OPC are,
  • Interoperability.
  • Since the client software always going to access data from the server, the Client software has no need to know the hardware protocol.
  • Scalability of the system.
Author: Abishek D
  • OPC Questions & Answers
  • DNP3 Protocol Basics
  • Compare Modbus & Fieldbus
  • SCADA Communication
  • What is the HART Protocol?
Tank Filling and Emptying using Intouch Scada Script
Job Skills Required for Industrial Electrical Maintenance
Heating and Mixing of Products using PLC Example Tutorial
PLC Analog Input Sampling Ladder Logic
What is Alarm Shelving? – Nuisance Alarms, Types, Suppression
Relation Control System
PLC Programming Examples using Timer
Basic PLC Ladder Programming Example
Relay Permissive and interlock circuits
How to use Scale and Normalize Instructions in PLC
CAN Protocol with the OSI Model
Basics for CAN Bus Protocol – Controller Area Network
DeMorgan's Theorems
DeMorgan’s Theorems using Ladder Diagram
PLC Examples for calling functions in SCL
Safety Control System
What is Safety Control System ?
Instrumentation Logic Checks
How to Do Logic Checks During Plant Pre-Commissioning
Measuring Instruments MCQ
Optimal Control Systems
Parameter Optimization
Electrical Engineering Problems - Root Cause Analysis
30 Electrical Engineering Problems – Root Cause Analysis
Redundant Power Supply
How Does Redundant Power Supply Work?
Functional Block Diagram of XNOR Logic Gate
PLC Functional Block Diagram for Logic Gates
Eddy Current
Eddy Current Working Principle Animation
Pneumatic Actuators
Self-Actuated Valves, Pneumatic & Hydraulic Actuators
