Reading: What is PV Tracking ?
Inst Tools > Blog > Control Systems > What is PV Tracking ?
Last updated: October 9, 2018 4:17 pm
Control Systems
2 Min Read
Setpoint Tracking (also called PV tracking):
PV Tracking is An option on many controllers. When a control loop is in MANUAL, with PV Tracking turned on, the controller setpoint (SP) will follow the PV. When the loop is returned to AUTO, there is no sudden movement of the process, because the PV is already at setpoint. If PV Tracking is turned off, returning to AUTO will drive the loop to its previous setpoint.
Setpoint tracking refers to the automatic adjustment of the controller setpoint so that it follows the process variable (PV). This occurs (only if the option is enabled) when the controller is in the manual mode. If set point tracking is enabled,when the controller is transferred to auto, the transfer takes place without any change whatsoever in controller output. This also means of course that the loop will continue to adjust the final element to maintain the PV at the value obtaining immediately before the transfer to auto. This may not be desirable in all cases since it relies on the operator to readjust the setpoint to the desired value at some time after the controller is transferred to auto.
Typical applications where setpoint tracking is desirable are those where the setpoint may vary under normal circumstances e.g. fuel gas flow on a boiler. In applications where the setpoint is normally fixed e.g. for steam temperature control, setpoint tracking would not normally be enabled.
Most often it is referred to as providing bumpless transfer from manual to auto. Without setpoint tracking whether or not a bump occurs depends on the state of tune of the controller. Since in manual, the controller integral term initializes so that the sum of the integral and proportional terms equals the manual output value, when the controller is trasferred to auto, there is no step due to proportional action but the output initially ramps at a rate proportional to the gain*error/integral action time.
Also Read: PID Controller Bumpless Transfer
All About Fieldbus Protocols
Derivative Controller Principle
Integrating Processes – Liquid Level Control
How to Write a Program in Ecostruxure Machine Expert HVAC Software?
  • Allanso Golden says:
    January 19, 2021 at 7:26 am
    I want this knowledge
Introduction to PlantPAx Distributed Control System
Closed Loop Control System : Boiler Water Level Control System
Free PID Controller Gains Tuning Tool
Instrumentation and Control (I&C) Design
PID Controller Functions
Modbus Function Command Formats
How to Stop Cyber Attacks on PLC or DCS?
HMI
How to Train Your Maintenance Team for Industrial Automation Systems
Augmented Reality and Virtual Reality in Industrial Automation
Loop Calibrator to Simulate a 4-20 mA Signal
Process Control System
Basics of Process Control Systems
Analog inputs in library
Design Process Graphics in Factory Talk View Studio with an Analog Input
Power Supply Sizing for Industrial Automation Systems
IACS Network
Remote Connectivity to Industrial Automation Systems
schottky diode working principle
Schottky Diode Working Principle
BUS TIE REACTORS
Current Limiting Reactors in Power System
Allen Bradley SLC 500 PLC Programming
Combining Independent Current Sources in Parallel
Networked SCADA Architecture
Difference between MCB and RCBO
Difference Between MCB and RCBO
Resistance Temperature Detectors Troubleshooting Tips
Comparison of Control Loops - Open, Closed, Cascade, Feedforward, Ratio
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
