Reading: What is Gas Meter and Regulating Station?
Inst Tools > Blog > Flow Measurement > What is Gas Meter and Regulating Station?
In this article, we will discuss about the gas meter and regulating station for the natural gas distribution system.
Last updated: December 14, 2021 11:30 am
Flow Measurement
In this article, we will discuss about the gas meter and regulating station for commercial usage. This station is used for the natural gas distribution systems.
This is the Meter Regulating Station in Indonesia and is owned by Indonesia National Gas Company (PGN) or Perusahaan Gas Negara.
Before we discuss this plant in more detail, we must understand about the gas distribution system.
Gas Distribution System P&ID
From the drawing, we know that the Meter Regulating Station (M/RS) is located after the tie-in line from the PGN line.
The gas is about 5 – 30 Barg from the tie-in line for the M/RS inlet. In this M/RS the gas is filtered, regulated, and measured until this outlet is 1 – 4 Barg.
So, what makes the gas is at pressure-reduced conditions? So, let’s check for the part of the P&ID at the M/RS section. And knowing the datasheet from these stations.
Metering Regulating Station
On the datasheet, we know the maximum flow rate, pressure, and G-Size from Turbine Meter (G-250).
Turbine Meter P&ID
The first process is gas in from the inlet (insulation joint). There are 2 lines at upstream and downstream. We can know the pressure inlet from PG-01.
The gas is in via BV1/2A (Ball Valve). And after that, the gas passes the filter GF1/2 (Gas Filter) to filter the gas from impurities. And measured with the differential pressure gauge (DP).
The gas is about 5 – 30 Barg. And after the DP gauge, the gas is regulated by SSOV (Slam-Shut Off Valve) to 4,5 Barg, Pilot Regulator Monitor (PRM) 4,1 Barg, and Pilot Regulator Active (PRA) 4 Barg and will go to the downstream section to be calculated with Electronic Volume Corrector (EVC) who’s connected with the pressure sensor, temperature sensor, a turbine meter with encoder to record the flowrate.
After that, the gas measured this temperature with thermowell too (TW1/2) and go to outlet insulation joint section and measured by PG 02 (The author forget to draw the outlet pressure gauge, so the draw on this P&ID is small than other instruments).
Turbine Meter Custody Transfer
There are the PRV1/2 (Pressure Relief Valve) to relieve the pressure if there is overpressure at the upstream pressure.
It usually happened if the usage of the gas is suddenly decreased. The PRV is set on 4.3 Barg.
Gas-volume Conversion Device PTZ Box
The picture above is showing about the parameters is measured by EVC. There are Vm (Volume at measurement conditions or nPsiG) and Vb (Volume at base conditions or 0Psig).
So the EVC is used to convert the gas flow rate from measured condition to base condition. In this case, gas compressibility law is available.
PV = nRT
If the gas temperature is low, so the pressure and the volume will be decreased than at higher temperature conditions.
This equipment is equipped with a pressure sensor, temperature sensor (PT-100), and IGTM turbine meter G-250. It can be added by NAMUR sensor and Encoder. And we can monitor the gas composition such as C1, C2, C3, C4,….until H2.
The equipment is featured by RS485 communication. So the gas value from EVC is can be collected and monitored with SCADA wireless (using GPRS) or not (using RS485).
Gas Composition PTZ Box
Gas Composition
EVC Wiring Configuration
PTZ Box
EVC Inputs Configuration
EVC Pressure Sensor Inputs
Custody Metering Installation
EVC Installation Configuration
Custody Meter Insulation Joint at Inlet and Outlet Stream
To get good performance for the measure and regulating process at this gas distribution system, the equipment at the M/RS should be on good maintenance.
Author: Ramadhani Ichlasul Amal
Bachelor of Applied Instrumentation Engineering Sepuluh Nopember Institute of Technology (ITS). And now at Jargas Jombang Operational and Maintenance Team.
Comparison of Venturi and Orifice flow meter
Overview of Positive Displacement Flow Meters
Flow Meter Calibration
Linear to Square Root Extraction
Orifice Plate Turndown ratio
  • RG says:
    July 12, 2023 at 8:44 am
    Terima kasih, sangat membantu 👍
Types of Vortex Flow Meter Sensors
Piston Flow Meters Working Principle with Animation
Orifice Plate Tapping – Orifice Plate Taps
Turbine Flow Meter Installation Procedure
Basics of Restriction Orifice (RO) – Types, Applications, Standards
Hot Wire Anemometer Principle and Types
What is a Coriolis Flow Meter?
What is Water Cut Meter?
Types of Flow Meters
Flow Meters Troubleshooting
Turbine Flow Meters Troubleshooting
Sick Flow meters
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Oscillating Piston Flow Meters Animation
Oscillating Piston Flow Meters Working Principle
Flowmeter Characteristics
Flow Meter Characteristics
Flow Transmitters Questions and Answers
Flow Transmitters Questions and Answers – Instruments Test
Coriolis flow meter sensor coils
Coriolis Flow Meter Construction
Orifice Construction
How does an Orifice Measures Flow?
Asynchronous Counter Objective Questions
Converter Instruction in Siemens PLC Programming
Industrial Internet of Things
Introduction to the Industrial Internet of Things (IIoT)
Strip-Chart-Recorder-Working-Principle
Strip Chart Recorder Working Principle
Methods of Transistor Biasing
Membrane Bioreactor in Water Treatment - MBR Process
Membrane Bioreactor in Water Treatment – MBR Process
Needle Valve Body Design
What is Needle Valve ?
Hunting and Damper Windings Questions
