Reading: What is Blowdown Valve (BDV)?
Inst Tools > Blog > Control Valves > What is Blowdown Valve (BDV)?
The primary function of a Blowdown valve is to control the concentrations of suspended & total dissolved solids (TDS) in the boiler.
Last updated: November 13, 2020 6:22 pm
Control Valves
2 Comments
3 Min Read
The blowdown valves are used for operation in the open position. The main function of the blowdown valve is mainly to control a continuous flow of steam/fluid under high differential pressure.
Blowdown Valve (BDV)Applications of Blowdown valvesTypes of Blowdown valvesContinuous Blowdown (CBD) valvesIntermittent Blowdown (IBD) valves
The outstanding feature of this type of valve is that it can maintain fluid-tightness and it is easily operated without the help of any wedging action.
The primary function of a blowdown valve is to control the concentrations of suspended & total dissolved solids (TDS) in the boiler.
Boiler blowdown is a severe service application which results in rapid erosion and wearing out of conventional valves.
Continuous blowdown is usually an on-going process, whereas intermittent blowdown is performed on an as needed basis.
Continuous Blowdown (CBD) valves are designed to operate in continuous open position by releasing water continuously through a blowdown tap near the boiler water surface, thereby maintaining the TDS level in the boiler drum.
Continuous Blowdown Valve is an angle type valve with a needle shaped trim in a venturi diffuser. The venturi diffuser provides sufficient area for the high velocity flashing water, thereby avoiding choked flow.
Intermittent Blowdown (IBD) valves are designed to operate at predetermined intervals by releasing water & accumulated sludge periodically through a blowdown tap near the bottom of the boiler.
The primary requirement of these valves is to provide tight shut-off even after repetitive blowdown operations.
Earlier, these two functions (blowdown and sealing) were performed by two different valves installed in series and operated in a definite sequence.
Intermittent Blowdown Valve carries out both these functions in sequence i.e. blowdown in open position and sealing in closed position.
This is achieved by providing a multi-step throttling plug, which splits the total pressure drop across each step.
The sealing area is separate from the throttling area, which reduces erosion and provides leak tightness even after prolonged usage.
  • Control Valve flow coefficient
  • Interview Questions on Valves
  • Control Valve Animation
  • Valve Flow Characteristics
  • Control Valve Connections
How to Troubleshoot Control Valve? – Problems and Solutions
Self-Actuated Valves, Pneumatic & Hydraulic Actuators
Control Valve Relation between Cv and Kv
Progressive Control Valve Sequence
Control Valve Flow Direction
Control Valve Performance with Constant Pressure
2 Comments
  • S M Shoaib says:
    February 10, 2020 at 3:16 pm
    Very important information is available here.
  • Arghama De says:
    July 1, 2020 at 12:23 pm
    Very informative article. I have a doubt, please clarify.
    Is it a good engineering practice to take close feedback of battery limit shutdown valves before open command goes to BDV during depressurization?
    Please share the reason.
Valve Safety Factor
What is a 4-way Solenoid Valve?
Introduction to Types of Valves
Pneumatic Valve Positioner Working Principle
Pressure Relief Valve Terminology
Basics of Gate Valves
Basic Parts of Control Valves
Electrical Actuators
Fail-Close Valve
What is a Fail-Close Valve? – Advantages and Disadvantages
valve packing assembly
What is Valve Packing ?
What is a Rotary Actuator
Difference Between Linear Actuator and Rotary Actuator
Ball Valve Parts
What is Ball Valve ?
Air Cylinder Consumption Calculation for Control Valves
Self Actuated Pressure Control Valve Functional Testing
Motor Operated Valve Problems and Troubleshooting
Safety Relief Valve Material Selection
cat5e plenum cable
cat5e Plenum Cable History, Advantages and Disadvantages
What are Switchgear Interlocks?
Cybersecurity Projects for Engineering Students
Chemical Seal Pressure Transmitter
What is the Purpose of Chemical Seals Pressure Transmitter?
Hazardous Area Classification Comparison
Comparison of IEC & NEC Area Classifications
Electronic Devices & Circuits Quiz – Set 2
pH sensor calibration procedure
