Reading: What is a Power Transformer? – Components and Types
Inst Tools > Blog > Electrical Basics > What is a Power Transformer? – Components and Types
A power transformer is used for stepping up or down higher-rated voltages. Learn its definition, types, and components.
Last updated: October 10, 2022 10:08 am
Electrical Basics
In this post, we will see the concept of a power transformer.
What is a Power Transformer?Components of Power TransformerTypes of Power Transformer
A transformer is an electrical device that is used to change voltage range; either increasing it to a certain level or decreasing it to a certain level. It is one of the most basic components used in an electrical network.
Voltage conversion is necessary because you cannot always apply the same input voltage to any device. Every instrument has its own set of power requirements and it varies from instrument to instrument.
Electrical power goes in three phases – generation, transmission, and distribution.
It has substations involved and the substation has many types of equipment; a transformer being one of them. One of the most commonly used types of transformer in it is a power transformer.
In this post, we will understand the concept of a power transformer.
 The power transformer is used in the generation and transmission stages. It can be a single phase or three phases. A power transformer is used for stepping up or down higher rated voltages in both these stages.
Typically, it can step up from 11KV to around 800KV for transmission; and step down again from 800KV to 240KV or 11KV for aiding the distribution process. Its basic working is the same as the normal transformer that we know. Only there are some additional design changes in it for working at higher voltages.
This transformer is provided with tapping on the primary winding side. Power lines are subjected to many variations according to demands and to work with that, tapping is provided on the primary side. By setting the proper tap, we can maintain proper voltage at the secondary side winding. You can change the taps even when the power supply is on.
It is put in operation during peak load. This means, it is connected in parallel with a normal transformer and when there is high peak demand during morning or evening hours, then the power transformer is used.
During non-peak hours, the normal transformer comes into the picture and the power transformer is shut off. The main thing here is that power is transmitted without changing the frequency.
Two winding transformers are generally used where the ratio of high voltage and low voltage is greater than 2. It is cost-effective to use an auto transformer where the ratio between high voltage and low voltage is less than 2.
Power transformers are essential in minimizing substantial energy losses, due to Joule’s effect, in the transmission of large amounts of electrical power over long distances by converting it into high-voltage current and then stepping it down to a safer low-voltage current.
Power transformers are commonly found in power plants, industrial plants, and electric utility companies.
The components of a power transformer are mentioned below.
  • Core components
  • HV and LV windings
  • Insulating materials
  • Tap changer
  • Bushings
  • Transformer tank
  • Conservator component
  • Breather component
  • Cooling system
  • Explosion vent
  • Buchholz relay
The power transformers are classified as follows.
  • Based on turns ratio – isolation transformers, step-down transformers, and step-up transformers.
  • Based on phase supply – Autotransformer, single-phase, and three-phase.
  • Based on core and winding construction – Berry-type, core-type, and shell-type.
  • Based on core material – air core, ferrite core, iron core, and toroidal core.
In this way, we saw the concept of a power transformer.
Types of Earth Leakage Circuit Breaker
Why is Phase Failure Relay Required in LV Panels?
What is Vacuum Circuit Breaker?
How to Protect Electrical Terminal Blocks From Tampering?
What is a VFD? – Theory, Advantages, Disadvantages
Difference Between Emergency STOP and Emergency Power OFF
  • Charles Palmer says:
    October 12, 2022 at 1:42 pm
    Items missing from presentation : GRAPHICS ETC
Types of Motor Enclosures
What is a Megger? Principle, Advantages, Disadvantages, Applications
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Why do we need to Control the Motion using VFD drives?
Partial Discharge in Power Lines and its Detection through Sensors
What is an Intelligent Motor Control Center? – IMCC
Difference Between HV and LV Cables
Difference between Power Cables and Signal Cables
RDOL starter
What are DOL and RDOL starters? Advantages, Disadvantages
Garage Door Roller Shutter
VFD Commissioning and Testing Procedure
Difference Between Alternator and Generator
Difference Between Alternator and Generator?
Arc Protective Clothing
What is Arc Protective Clothing? – Importance, Features, Materials
hand-crank megger photo
What is Megger Test?
Flame Cables
Difference Between Flame Resistant and Flame Retardant Cables
Purpose of End of Line (EOL) Resistor in Fire & Gas System ?
Why we use End of Line (EOL) Resistor in Fire and Gas System ?
Pressure Control Valve
What is Pressure Control Valve?
How to Measure Specific Gravity of Battery
PLC Program for Stage Control Curtains and Stage Elevation
PLC Program for Stage Control: Curtains and Stage Elevation
What is a Lightning Arrester? How does it work?
Thyristor Mounting Objective Questions and Answers
Calibration Sheet
Calibration : Up-tests and Down-tests
Automatic Lamp Control in Storage Facility
