Reading: Top 80+ Valve Questions and Answers
Inst Tools > Blog > Control Valves > Top 80+ Valve Questions and Answers
Explore over top 80 valve questions and answers about valve types, operation, and maintenance in various industrial applications.
Last updated: August 31, 2024 8:25 pm
Control Valves Instrumentation MCQ
38 Min Read
Valve QuestionsWhat is a Rotary Valve?What is a Side Entry Ball Valve?What is a Quick Exhaust Valve?What is a Manual Valve?What is a Poppet Valve?What is a Top Entry Ball Valve?What is a Sample Valve?What is a Full Port Valve?What is an Orbit Valve?What is a Tank Bottom Valve?What is an Angle Seat Valve?What is a Multi-Port Ball Valve?What is a Floating Ball Valve?What is an Equalizing Valve?What is a Blowdown Valve?What is a Resilient Seated Valve?What is a Hand Valve?What is a Choke Valve?What is a Balance Valve?What is a Diverter Valve?What is a Bellows Sealed Valve?What is a Throttle Valve?What is a Hydraulic Directional Control Valve?What is a Four-Way Valve?What is a Ball Check Valve?What is a Foot Valve?What is a Globe Valve?What is a Double Block and Bleed Valve?What is a Wafer Check Valve?What is a Thermostatic Valve?What is a Gate Valve?What is a Check Valve?What is a Tilting Disc Check Valve?What is a Mixing Valve?What is a Pressure Sustaining Valve?What is a V-Port Ball Valve?What is a Lift Check Valve?What is a Venting Valve?What is a Trunnion Ball Valve?What is a Butterfly Valve?Valves TestWhat is a Diaphragm Valve?What is a Three-Way Valve?What is a Stop Check Valve?What is a Y-Pattern Valve?What is a Motorized Valve?What is a Vacuum Relief Valve?What is a Piston Valve?What is a Silent Check Valve?What is a Double Disc Check Valve?What is a Diverting Valve?What is a Remote Operated Valve?What is a Severe Service Valve?What is a Hydraulic Valve?What is a Knife Gate Valve?What is an Angle Valve?What is a Triple Offset Butterfly Valve?What is a Metal Seated Valve?What is a Tank Vent Valve?What is a Solenoid Valve?What is a Control Valve?What is a Sleeve Plug Valve?What is a Lined Valve?What is a Float Valve?What is an Axial Flow Valve?What is a Swing Check Valve?What is a Reduced Port Valve?What is a Multi-Turn Valve?What is a Safety Valve?What is a Cryogenic Valve?What is a Tandem Valve?What is a Pinch Valve?What is a Plug Valve?What is a Needle Valve?What is a Pressure Relief Valve?What is a Proportional Valve?What is a Ball Valve?What is a Spring-Loaded Check Valve?What is an Expansion Valve?What is a Cartridge Valve?What is an Emergency Shut-Off Valve?What is a Linear Valve?
Valve Questions
Watch the valve video to understand the explanations for the given questions.
Valve Questions and Answers (Part 1)
Question 1
A. A valve with a sliding gate for quick on/off control
B. A valve that moves linearly to control flow rate
C. A valve with a rotating disc for flow control
D. A valve that operates by rotating a closure element
Show the Answer
Question 2
A. A ball valve accessed through the top for maintenance
B. A ball valve that stops movement from the top
C. A ball valve with a body split into two or more pieces
D. A ball valve with a single-piece body
Show the Answer
Question 3
A. A valve specially designed to operated the valve slowly
B. A valve that controls the flow of gases without using any type of air medium
C. A valve that rapidly exhausts air from a system
D. A valve that rapidly stores air from a system
Show the Answer
Question 4
A. A valve operated by PLC
B. A valve operated by hand
C. A valve operated by air
D. A valve that regulates flow based on temperature
Show the Answer
Question 5
A. A valve with a poppet to change the flow direction
B. A valve with a poppet to control the process temperature
C. A valve with a movable poppet that lifts to open and seats to close
D. A valve with a fixed poppet that lifts to open and seats to close
Show the Answer
Question 6
A. A ball valve with a split body design
B. A ball valve with a fixed ball supported by trunnions
C. A ball valve that allows maintenance from the top
D. A ball valve that stops movement from the top
Show the Answer
Question 7
A. A valve that controls fluid mixing in a tank
B. A valve that isolates the two process pipelines
C. A valve that collects samples from transmitters
D. A valve that allows for the collection of fluid samples
Show the Answer
Question 8
A. A valve with a reduced internal diameter
B. A valve that allows full flow with no restriction
C. A valve with a increased internal diameter
D. A valve that allows half flow with no restriction
Show the Answer
Question 9
A. A valve with a linear motion to open and close
B. A valve that seals with a flexible seat
C. A valve with a rotating motion to open and close
D. A valve with multiple ports for flow control
Show the Answer
Question 10
A. An automatic tank bottom valve for level control
B. A valve designed for draining tanks from control room only
C. A valve designed for pumping tanks at the bottom
D. A valve designed for draining tanks at the bottom
Show the Answer
Question 11
A. A valve with an angled seat for quick and tight shutoff
B. A valve that operates at an no angle to the flow
C. A valve with an straight seat for quick and tight shutoff
D. A valve with an angled seat for slow and loose shutoff
Show the Answer
Question 12
A. A ball valve with multiple actuators
B. A valve with a single flow path
C. A ball valve with multiple balls
D. A ball valve with multiple flow paths
Show the Answer
Question 13
A. A valve that seals with a rubber seat
B. A valve that operates under low pressure
C. A ball valve where the ball is free to move
D. A valve with a trunnion-mounted ball
Show the Answer
Question 14
A. A valve that balances density between two points
B. A valve that balances temperature between two points
C. A valve that balances pressure between two points
D. A valve that is used in high-pressure systems only
Show the Answer
Question 15
A. A valve that regulates the flow of gases
B. A valve that maintains constant pressure
C. A valve that controls vacuum pressure
D. A valve used to remove sludge or sediment from boilers
Show the Answer
Question 16
A. A valve that controls flow using a bellows seal
B. A valve that allows full flow without restriction
C. A valve with a metal-to-metal sealing surface
D. A valve with a soft, flexible sealing surface
Show the Answer
Question 17
A. A valve that operated using solenoid and coil
B. A valve operated manually by hand
C. A valve operated using automatic devices
D. A valve that automatically closes in emergencies
Show the Answer
Question 18
A. A valve that restricts flow in oil and gas applications
B. A valve that prevents backflow of fluid
C. A valve with a bellow for control
D. A valve that changes direction by 90 degrees
Show the Answer
Question 19
A. A valve that ensures uneven distribution of flow in a system
B. A valve that ensures less opening and more closing
C. A valve that ensures more opening and less closing
D. A valve that ensures even distribution of flow in a system
Show the Answer
Question 20
A. A valve that directs flow between two valves
B. A valve with a rotating disc for throttling flow
C. A valve that directs flow from one inlet to multiple outlets
D. A valve that controls pressure and temperature
Show the Answer
Question 21
A. A valve that operates with a rotating disc
B. A valve with a bellows element to stop the flow
C. A valve with a hermetic seal using a bellows structure
Show the Answer
Question 22
A. A valve that is manually operated to start and stop flow
B. A valve that regulates flow by varying the opening size
C. A valve that uses a ball with a hole to control flow
D. A valve with a gate that fully opens or closes flow
Show the Answer
Question 23
A. A valve to control the hydraulic fluid pressure
B. A valve that directs hydraulic fluid to different paths
C. A valve uses pneumatic air to control the flow rate
D. A valve that directs hydraulic fluid to single path
Show the Answer
Question 24
A. A valve that uses four solenoid valves for the operation
B. A valve that admits air to prevent vacuum conditions
C. A valve that controls four pressure sources
D. A valve that controls flow between four different paths
Show the Answer
Question 25
A. A valve with a rotating plug for flow control
B. A valve that uses a flexible diaphragm for sealing
C. A valve that uses a ball to prevent backflow
D. A valve that lifts to allow flow without using ball
Show the Answer
Question 26
A. A valve used in high-pressure systems
B. A valve that controls fluid direction in steam systems
C. A valve placed at the bottom of a pump suction line
D. A valve that uses a conical plug for shutoff
Show the Answer
Question 27
A. A valve that uses a flexible diaphragm
B. A valve that controls flow through a rotating disc
C. A valve with a disk that slides across an orifice
D. A valve that uses a plug and seat design
Show the Answer
Question 28
A. A valve with one sealing mechanisms to isolate fluid and two bleed ports
B. A valve that controls tank level using block and bleed valves
C. A valve with two sealing mechanisms to isolate fluid and a bleed port
D. A valve that controls pressure in tanks using block and bleed valves
Show the Answer
Question 29
A. A thin, compact valve designed for heavy spaces
B. A thin, compact valve designed for tight spaces
C. A valve that uses a disc that swings open and closed
D. A valve with a piston that lifts to allow flow
Show the Answer
Question 30
A. A valve that controls flow based on temperature
B. A valve that controls temperature based on flow rate
C. A valve that controls temperature based on pressure
D. A valve that controls flow based on pressure
Show the Answer
Question 31
A. A valve that uses a sliding gate to control flow
B. A valve that operates with a rotating disc
C. A valve with a spherical disc controlling flow
D. A valve with a flexible diaphragm
Show the Answer
Question 32
A. A valve that controls flow through a rotating disc
B. A valve that opens and closes by hand
C. A valve that prevents backflow of fluid
D. A valve with a needle-like stem for precise control
Show the Answer
Question 33
A. A valve with a rotating ball for flow control
B. A valve with a needle-like stem for precise control
C. A valve that uses a plug for shutoff
D. A valve with a disc that tilts to open and close
Show the Answer
Question 34
A. A valve that regulates flow between two outlets only
B. A valve that mixes two or more fluid streams
C. A valve that divides two or more fluid streams
D. A valve that controls pressure between four paths only
Show the Answer
Question 35
A. A valve that maintains a minimum upstream temperature and pressure
B. A valve that maintains a minimum upstream pressure
C. A valve that controls flow in two directions using pressure
D. A valve that controls vacuum pressure
Show the Answer
Question 36
A. A valve that diverts flow between six outlets
B. A ball valve operated using a V-shaped actuator for density control
C. A ball valve without a V-shaped notch for flow control
D. A ball valve with a V-shaped notch for flow control
Show the Answer
Question 37
A. A valve where the disc lifts horizontally to allow flow
B. A valve that prevents backflow with a swinging disc
C. A valve that uses a needle-like stem for flow control
D. A valve where the disc lifts vertically to allow flow
Show the Answer
Question 38
A. A valve that stores air or gas from a system
B. A valve that releases air or gas from a system
C. A valve that prevents air backflow
D. A valve that controls the temperature of a process
Show the Answer
Question 39
A. A valve with a floating ball for sealing
B. A ball valve where the ball is free to move
C. A valve with a trunnion-mounted ball
D. A ball valve with a fixed ball supported by trunnions
Show the Answer
Question 40
A. A valve with a sliding gate for flow control
B. A valve that uses a plug to block the flow
C. A valve with a quarter-turn rotating disc
D. A valve with a flexible membrane for sealing
Show the Answer
Valves Test
This valve test video provides the remaining quiz questions and answers with explanations.
Valve Questions and Answers (Part 2)
Question 41
C. A valve with a flexible membrane for sealing
D. A valve with a rotating disc
Show the Answer
Question 42
A. A valve that controls pressure in two directions
B. A valve that uses three solenoid valves for the operation
C. A valve that directs flow between three ports
D. A valve that controls three pressure sources
Show the Answer
Question 43
A. A valve that prevents backflow with a rotating disc
B. A valve with a flexible diaphragm for flow control
C. A valve that uses a ball to allow flow
D. A valve that combines a check valve and a stop valve
Show the Answer
Question 44
A. A valve with a stem that is angled at 45 degrees
B. A valve with a piston mechanism for flow control
C. A valve with a stem that is angled at 90 degrees
D. A valve that allows flow in one direction only
Show the Answer
Question 45
A. A valve that uses solenoid coil for the operation
B. A valve operation based on the process flow
C. A valve operated by an electric motor
D. A valve operated by an instrument air
Show the Answer
Question 46
A. A valve that uses vacuum for controlling the pressure
C. A valve that uses vacuum for controlling the flow rate
D. A valve that admits air to prevent vacuum conditions
Show the Answer
Question 47
A. A valve that uses a diaphragm for flow control
C. A valve that uses a piston to control flow
D. A valve that prevents backflow of fluid
Show the Answer
Question 48
A. A valve that uses a piston for flow control
B. A valve that uses a ball to regulate flow direction
C. A valve that prevents backflow without slamming
D. A valve that uses a rotating disc to control flow
Show the Answer
Question 49
A. A valve with a flexible diaphragm for sealing
B. A valve that uses a rotating ball to prevent backflow
C. A valve with one disc that open and close for flow control
D. A valve with two discs that open and close for flow control
Show the Answer
Question 50
A. A valve that controls pressure between four paths only
B. A valve that mixes fluids for temperature control
C. A valve that directs flow between different outlets
D. A valve that regulates flow between two outlets only
Show the Answer
Question 51
A. A valve that allows full flow rate restriction without using any actuator
B. A valve controlled from a distance using electrical, pneumatic, or hydraulic means
C. A valve controlled manually via an actuator
D. A valve operated using push buttons and handwheels only
Show the Answer
Question 52
A. A valve designed for low pressure and temperature
B. A valve designed for extreme temperature conditions only
C. A valve designed for extreme pressure conditions only
D. A valve designed for extreme pressure and temperature
Show the Answer
Question 53
A. A valve that lifts to prevent backflow
B. A valve with a disc that swings open and closed
C. A valve that rotates to allow flow control
D. A valve used to control hydraulic fluid flow
Show the Answer
Question 54
A. A valve with a sharp-edged gate that cuts through solids or slurry
B. A valve that cuts through thin media to change the flow direction
C. A valve that cuts through thin media to stop flow
D. A valve with a ball that cuts through solids or slurry
Show the Answer
Question 55
A. A valve that changes the direction of flow by 180 degrees
B. A valve that is used for high-temperature applications only
C. A valve that controls the flow through a straight path
D. A valve that changes the direction of flow by 90 degrees
Show the Answer
Question 56
A. A valve with three ports for flow diversion
B. A valve with three offsets for tight sealing
C. A valve with a single offset for control
D. A valve with three ports for flow mixing
Show the Answer
Question 57
A. A valve with a metal-to-metal sealing surface
B. A valve with a plastic sealing surface
C. A valve with a soft, flexible sealing surface
D. A valve with a rubber-to-metal sealing surface
Show the Answer
Question 58
A. A valve that decreases the storage tank pressure
B. A valve that increases the storage tank pressure
C. A valve that allows air in and out of a storage tank
D. A valve that controls the direction of gases
Show the Answer
Question 59
B. A valve controlled by pneumatic pressure only
C. A valve operated by electromechanical devices
D. A valve that is manually operated
Show the Answer
Question 60
A. A valve used to prevent backflow only
B. A valve that regulates fluid flow in a system
C. A valve that changes the direction of flow only
D. A valve that is manually operated only
Show the Answer
Question 61
A. A valve with a floating plug for sealing
B. A plug valve without a lubricated sleeve for sealing
C. A plug valve with a lubricated sleeve for sealing
D. A valve that operates two ports simultaneously
Show the Answer
Question 62
A. A valve with an internal lining for corrosion resistance
B. A valve without an external lining for corrosion resistance
C. A valve without an internal lining for corrosion resistance
D. A valve with an external lining for corrosion resistance
Show the Answer
Question 63
A. A valve that prevents the backflow of fluids using float
B. A valve that controls flow based on the position of a floating element
C. A valve that mixes fluid streams based on the floating element size
D. A valve that controls the process temperature using float switch
Show the Answer
Question 64
A. A valve that operates by rotating a closure element
B. A valve that controls flow with a rotating element
C. A valve with a flow path that runs parallel to the axis of the valve body
D. A valve with a rotating disc for throttling flow
Show the Answer
Question 65
A. A valve that controls flow with a flexible diaphragm
B. A valve with a hinged disc that swings to prevent backflow
C. A valve with a rotating plug for shutoff
D. A valve that uses a piston to control flow
Show the Answer
Question 66
A. A valve with a increased internal diameter
B. A valve that allows zero flow with no restriction
C. A valve with a smaller internal diameter
D. A valve that allows full flow with no restriction
Show the Answer
Question 67
A. A valve that requires multiple valves to control flow rate
B. A valve that uses series of valves to control the flow rate
C. A valve that requires multiple turns to open or close
D. A valve that requires single turn to open or close
Show the Answer
Question 68
A. A valve that controls the flow of liquids under normal conditions
B. A valve used to control temperature
C. A valve designed to open automatically under high pressure
D. A valve that stops backflow of fluid
Show the Answer
Question 69
A. A valve used for extremely high-pressure applications
B. A valve used for extremely low-temperature applications
C. A valve used for extremely high-temperature applications
D. A valve used for extremely low-pressure applications
Show the Answer
Question 70
A. A valve that operates two ports simultaneously
B. A valve with a floating ball for sealing
C. A valve with two separate valve mechanisms in parallel
D. A valve with two separate valve mechanisms in series
Show the Answer
Question 71
A. A valve with a rotating plug for quick shutoff
B. A valve that uses a sliding gate to regulate flow
C. A valve that controls flow by pinching a tube
D. A valve with a flexible diaphragm for sealing
Show the Answer
Question 72
A. A valve used for backflow prevention
B. A valve with a cylindrical or conical plug
C. A valve that uses a flexible diaphragm for control
D. A valve that uses a sliding gate to control flow
Show the Answer
Question 73
A. A valve with a quarter-turn spherical disc
C. A valve that allows unidirectional flow
Show the Answer
Question 74
A. A valve that opens automatically to relieve excess pressure
B. A valve with a plug that rotates for flow control
C. A valve that opens automatically to relieve normal pressure
D. A valve used for precise metering of flow
Show the Answer
Question 75
A. A valve that maintains constant upstream pressure and temperature
B. A valve that controls flow in proportion to process density
C. A valve that controls flow in proportion to an input signal
D. A valve that controls pressure in proportion to process temperature
Show the Answer
Question 76
D. A valve used to regulate high-pressure steam
Show the Answer
Question 77
A. A check valve that uses a spring to close the valve quickly
B. A check valve that uses a spring to close the valve slowly
C. A valve with a needle-like stem for precise control
D. A valve that rotates to allow or block flow
Show the Answer
Question 78
A. A valve that controls tank level and temperature
B. A valve that controls flow rate of instrument air
C. A valve that controls very low pressure applications
D. A valve that controls refrigerant flow in HVAC systems
Show the Answer
Question 79
A. A valve that directs fluid to multiple outlets
B. A valve installed as a self-contained unit within a manifold
C. A valve with a rotating ball for quick on/off control
D. A valve with a flexible diaphragm for pressure control
Show the Answer
Question 80
A. A valve with a diaphragm for precise adjustments
B. A valve that closes rapidly to isolate a system in an emergency
C. A valve that stops working in emergency conditions
D. A valve that manually closes in emergencies
Show the Answer
Question 81
A. A valve that operates based linear flow rate
B. A valve with a rotating disc for flow control
C. A valve where the flow control element moves in rotation
D. A valve that operates with a linear motion to open or close
Show the Answer
  • Identify Valve Parts Quiz with Answers
  • Control Valve Questions and Answers
  • Top 100+ SCADA Questions and Answers
  • Top Limit Switch Questions and Answers
  • Electrical Engineering Documents Questions
  • Industrial Automation Components Questions
Standard Test Signals Objective Questions
Types of Pilot Operated Diaphragm Solenoid Valve Principle
Sensors Objective Questions
Shaft and Coupling Bore Tapers Repair Caused Frequent Shutdowns
Frequency Division Multiplexers Objective Questions
Sensors and Transducers Test
Classification of Gate Valves
Calculate Control Valve Stem Position
Pressure to Current (P/I) Converter Principle
Control Valve Performance with Varying Pressure
Difference between Globe Valve and Gate Valve ?
What is ON/OFF Valve ?
Telemetry Systems Objective Questions
Level and Density Measurement Objective Questions
Circuit Measurement Objective Questions
Electrical and Electronics Circuit Measurement Objective Questions
Choked Flow of Control Valve
Choked Flow of Control Valves
30% Feed Control Valve
Purpose of 100% and 30% Feed Control Valves in a Power Plant
Control Valve Passing Problem after Overhauling Job
Measurement of Errors Objective Questions
Measuring Instruments MCQ
Level Gauges Questions and Answers
Level Gauges Objective Questions and Answers – Instrumentation
Summary of Valve Types Characteristics
Calibration of a Strain Gage Load Cell
Shunt Calibration of a Strain Gauge Load Cell
Coriolis Mass Flowmeter Principle
Coriolis Mass Flow Sensor Theory
Main Functions of a Multimeter
Interesting Multimeter Functions (And What They Really Do)
Remote User Authentication
Security of Industrial Automation Systems
Electric Circuits Objective Questions – Set 9
PLC TB Wiring
Electrical Signal and Control Wiring
PLC Program using Timers
PLC Timers Program
control of level in three cascaded Loops
Multiple Lags (orders)
