Reading: Up Down Counter Instruction in PLC
Inst Tools > Blog > PLC Tutorials > Up Down Counter Instruction in PLC
Last updated: March 4, 2021 12:38 pm
Let’s study the working of up down counter instruction function in Siemens PLC programming.
Up Down CounterUp Function Ladder LogicDown Function Ladder LogicLadder LogicStopping counter function when accumulator reaches presetCar Parking ExampleIO ListLogic
Up Down Counter
UP DOWN Counter instruction is used to counting up/down function.CU input is used to get counter enable Bool input. CD input is used to get counter enable bool input.
S input is used to get the set input, once S input changes from 0 to 1, counter accumulator value changes to 999, which is counter’s higher limit.
PV is word input where you can give preset value with the format of C#.R input is the reset Bool input’s output is used to get counter enable output. CV and CV_BCD used to get the counter’s accumulator value in integer format and BCD format.
Input I0.0 is pressed, counter C0 counts one and enabling Q’s output Q0.0. Even if you turn off I0.0, Q0.0 remains in the ON state until reset.I0.0 is pressed trice, the accumulator value is 3.
Note: In Siemens, Counter will not stop counting once the accumulator meets preset, it will continue counting whenever it gets signal for CU input.
Input I0.1 is pressed, counter C0 counts one down Q0.0 remains in the ON state until reset or accumulator reaches zero.
Note: In Siemens, down Counter will stop counting once the accumulator meets zero, it will not continue counting done even it gets signal for CD input.
Ladder Logic
Network 1:
I0.0 is pressed trice, the accumulator value is 3.M0.0 is a memory address that gets enable once MW0 reaches 3.
Network 2:
Counter accumulator value stored in MW0 is comparing with 3 using greater than or equal to block to turn on memory M0.0.
Note: By using the above method, we can restrict the counter to count after the preset value. Else it will be reaching the higher limit 999.
Car Parking Example
Let’s use this up-down counter in car parking example:
In a parking slot, the entry sensor is used to count cars which are entering and exit sensor will count exiting, Total number of car possible to park inside slot is three. Indication light is there to indicate parking is open and closed.
IO List
Car Parking PLC Example
Logic
car parking example logic
Network 1:
I0.0 is the entry sensor which is detecting car coming inside and counting up function is happening; in the above rung, it is shown like three cars were sent.
Parking is full indication (Q0.0) is ON.M0.0 is used to restrict the counter to count more than preset.
Network 2:
Greater than equal to Comparator is used to restrict the counter to count more than the preset value. ROL is received in M0.0
Network 3:
Less than Comparator is used to compare the number of car entering is within the limit.Q0.1 is the indication for parking is open.
Author: Hema Sundaresan
  • OFF Delay Timer using PLC
  • Retentive ON Delay Timer
  • Pulse Timer Instruction
  • ON Delay Timer using PLC
  • OFF versus ON Delay Timers
PLC Ladder Logic Example based on Set Coil and Reset Coil
What is Live Zero in 4-20 mA Current Loop?
Create Ladder Diagram from Boolean Logic
How to Select a SCADA for New PLC Project?
  • Steve Wandji says:
    May 24, 2020 at 6:37 pm
    Good morning, I0.2 isn’t in the IO List
Parts of PLC
CRA Module in Schneider PLC – Remote IO Adapter Module
Unknown Do’s Need to Know as a PLC Programmer
Move Instruction in Tia Portal
Traffic Barrier Control
PLC Programming for Traffic Barrier Control
PID parameters
PID in Siemens TIA Portal
HMI screen for operator
#8 PLC Best Practices – Validate HMI Input Variables at PLC Level
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
Free Download PLC Book
#10 PLC Best Practices – Assign Register Blocks by Function
Downloading Free PLC software
Step by Step Guidelines for Downloading Free PLC software
Machine Tool and Coolant Control PLC Ladder Logic
Machine Tool and Coolant Control: PLC Ladder Logic Design
Electric Circuits Objective Questions – Set 6
Instrumentation Engineer’s Calibration Mistakes
Pressure Switch Construction
Basics of Pressure switches
S84 - IEC 61511 Standard for Safety Instrumented Systems
S84 / IEC 61511 Standard for Safety Instrumented Systems
Electronic Symbols
Electronic Diagrams, Prints and Schematics
Pneumatic Temperature Transmitter with Sensor Principle
Negative Readings in Gas Detectors
Why Negative Readings in Gas Detectors ?
Safety Relief Valve Material Selection
