Reading: Ultrapure Water in the Semiconductor Industry
Inst Tools > Blog > Common > Ultrapure Water in the Semiconductor Industry
In this post, we will learn the use of ultrapure water in the semiconductor industry for manufacturing the electronic chips.
Last updated: September 28, 2022 4:09 pm
Common
In this post, we will see the use of ultrapure water in the semiconductor industry.
Semiconductors are a very important part of our life. Daily use devices from small ones like headphones to mobiles to laptops to controllers used in automobiles; any electronic equipment cannot function without a semiconductor.
Ultrapure Water in Semiconductor Industry
They are the heart of any electronic device. It is important to know that there are only a handful of manufacturers in the world who deal in its making.
It requires a very finest level of accuracy in making a wafer chip; even a nano mistake can make it a waste. Semiconductors require a huge amount of pure water, or you can say even ultrapure water in their manufacturing.
For general knowledge, it must be known that a standard 30cm. wafer chip requires 2200 gallons of water (1 gallon is approximately equal to 4 liters).
So, you can imagine the amount of water to manufacture chips in bulk daily. And the most important; is not just water, it is ultrapure water.
With such a high level of purity, the amount of impure or wastewater generated during manufacturing is also a large quantity.
This wastewater is very toxic due to the presence of heavy metals and toxic solvents, and it is almost impossible to treat such water with 0% purity output.
So, apart from manufacturing a chip, dealing with water is also a major challenge and technology in this industry.
Let us first understand clearly why such a high amount of pure water is required in manufacturing a silicon wafer chip. A semiconductor contains a number of transistors and other power electronic devices.
Semiconductors are built-in layers on silicon wafers into integrated circuits. It is important to know that after each one of several dozen layers of semiconductors are added to a silicon wafer, it must be rinsed and cleaned properly to remove waste (ions, particles, silica, TOC, dissolved oxygen) from it. This prevents chips from getting contaminated. Even a minute layer of impurity can make the chip unusable.
Ultrapure water is produced through many critical stages of water treatment. In general, let us consider the steps commonly used everywhere.
The first stage starts with the pre-treatment process. Here, raw water is passed through filter stages like MMF (Mixed Media filter), ACF (Activated Carbon filter), and Softener, and then passes through RO (Reverse Osmosis).
The second stage consists again of the 2nd pass RO system. The output from this RO is passed to a UV lamp where residual ozone is destroyed.
Then follows processes of vacuum de-aeration, passing water through mixed beds, resin regeneration, etc.
Finally, in the third stage, water is distributed to various points where pure water is required. Before reaching the final points, water again passes through UV oxidation, polishing mixed beds and degasifier.
The final output is very pure and contains very minute particles, which are mostly negligible and will not harm the chips (less than 1 particle>0.05uM per mL).
As discussed earlier, wastewater generated from purification stages needs to be treated before disposing it off in the drains. So, effluent treatment systems are then used to treat wastewater.
The chip industry demands the purest form of water for cleaning chips and an equal amount of treatment for wastewater. Any malfunction in both these processes can make the industry unusable.
  • Sensors in Water Treatment Plant
  • Compare Sensor and Transducer
  • Level Sensors Questions and Answers
  • Partial Discharge Detection Sensors
  • Pneumatic Temperature Sensors
6 Pieces of Essential Equipment For PCB Assembly
How to Use Bracelet Scanner? – Ultrasonic Thickness Gauge
Automating Lab Data Reconciliation: Key Steps to Success
What are the Advantages & Disadvantages of CNC Milling?
Important Applications of Rapid Prototype CNC Machining Services
HVAC Questions & Answers
Power Tool Maintenance – When And How To Replace Carbon Brushes
What is a Viscometer? – Types, Applications, Advantages
Ultrasonic Testing (UT) : Principle, Advantages, Disadvantages
Ideal Guide To Sheet Metal Fabrication Manufacturing and Design
Robotic Process Automation (RPA) in AI – Market Growth & Business Benefits
Lag time
How Does a Touch Sensor Work?
Career Scope in Electronics Engineering
Basic Pneumatic System
Introduction to Fluid Power and Pneumatics
Reproducibility in Measurement
What is Reproducibility?
CNC Machining Glass Industry
5 Ways CNC Machining is Benefiting the Glass Industry
Comparison of Absorption Chillers and Electric (Compression) Chillers
Difference between Water Cooled Chiller and Air Cooled Chiller
Alternative Optical Proximity Sensor
Proximity Sensor
Satellites Application in Agriculture
The Most Significant Developments in Satellite Technology
Food Safety Equipment And Tools
Food Safety Equipment, Tools, and Tips: A Guide For Businesses
Best Instrumentation Engineering Books to Purchase
Accelerometer Vibration Probe
Accelerometer Vibration Probe Principle
Thermowell Problems
Thermowell Problems
PLC offline data of a project are compared
Compare Two Offline PLC Projects
Drum Level differential pressure transmitter
Calculate Differential Pressure Sensed by Level Transmitter
Shift Registers Objective Questions
How Buoyant Force instruments Works
HART Communication Tutorial 1
HART Communication Tutorial Part 4
FIFO in STL Language in Siemens PLC
How to Code a FIFO Queue in STL Language in Siemens PLC?
