Reading: Turbine Flow Meter Coefficient and Scaling Factor
Inst Tools > Blog > Flow Measurement > Turbine Flow Meter Coefficient and Scaling Factor
Turbine flowmeter generates 10 pulses per gallon of liquid passing through it. Determine the meter coefficient and calculate the scaling factor.
Last updated: November 2, 2023 10:01 am
Flow Measurement Formulas
1 Min Read
A digital turbine flowmeter generates 10 pulses per gallon of liquid passing through it.
Determine the meter coefficient and calculate the scaling factor that is needed to develop an output in which each pulse would represent 100 gallons.
Turbine Flow Meter Scaling Factor
Solution:
The meter coefficient is as follows:
Turbine Flow meter coefficient
K = Pulses / Volume
so as per above inputs, K = 10 Pulses / gallon
The scaling factor is as follows:
 = (10 pulses/gallon) x (100 gallons)
= 1000 pulses
Therefore, a scaling factor of 1,000 is necessary to ensure that the flowmeter’s digital circuit generates one output pulse for every 1,000 pulses generated by the magnetic pickup coil.
  • Vortex Flow Meter Principle
  • Dall Tube Flow Meter Principle
  • Flow Meter Verification
  • MPFM Working Principle
  • Flow Transmitter Questions
Hot Wire Anemometer Principle and Types
Pitot Tube Problems and Troubleshooting Steps – Flow Instrument
PLC Problems Troubleshooting
What is a Turbine Flow Meter?
Formula for Process Variable to Percentage Conversion
4-20mA Formulas and Examples
Working Principle of Flow Switch with Animation
Flow Instruments – Selection, Principle & Application
Working Principle of Vortex Flow Meter
4-20mA Linear Conversion Calculation for VFD Drive (Formula)
Coriolis Mass Flow Sensor Theory
V Cone Flow Meter – Principle, Advantages, Disadvantages
Types of Vortex Flow Meter Sensors
Calculate Flow Coefficient Kv of Solenoid Valve
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Orifice Beta
Swirl Flowmeters Principle
Swirl Flow Meters Working Principle
Scaling Sensor Output to Engineering Units
Types of Flow Meters
Bernoulli's Principle and Flow Meters
Flow meter Turndown Ratio
Why Turndown Ratio is important when Selecting a Flow Meter?
How a Δp flow meters works
What is Differential Pressure Flow Meter?
Grounding Electronic Equipment
Importance of Grounding Electronic Equipment
Two Hand Press PLC
Two Hand Press Safety Control Circuit
Hybrid Solar Power System
Electromagnetism Objective Questions and Answers
200+ Electromagnetism Objective Questions and Answers
AB PLC Temperature Switch
Programmable Logic Controller (PLC) Questions and Answers – 17
In this article, you will learn the configuration of PlantPAx library in factory talk studio of Rockwell Automation.
Configuration of PlantPAx Library in Factory Talk Studio
Color detection PLC logic
Conveyor Sorting System with Color Detection PLC Logic
Basic Electricity Objective Questions and Answers
100+ Basic Electricity Objective Questions and Answers
