Reading: Thermostat – Types, Working Principle, Advantages, Applications
Inst Tools > Blog > Temperature Measurement > Thermostat – Types, Working Principle, Advantages, Applications
A thermostat is a handy device that controls the temperature in various household items like refrigerators, air conditioners, and irons.
Last updated: August 14, 2023 2:03 pm
6 Comments
What is a Thermostat?
A thermostat is a handy device that controls the temperature in various household items like refrigerators, air conditioners, and irons. It’s like a temperature watchdog, keeping an eye on how hot or cold things are and adjusting them to just the right level.
What is a Thermostat?How Does a Thermostat Work?Bimetallic Strips ThermostatThe Science of Bimetallic ThermostatTypes of ThermostatsAdvantagesDisadvantagesApplicationsConclusion
The secret behind a thermostat is the idea of “thermal expansion.” Imagine a solid bar of metal getting longer as it gets hotter. That’s thermal expansion.
Now, think of sticking two different kinds of metal together into one strip. This double-metal strip is the brain of a traditional thermostat.
  1. When It’s Cold: The double-metal strip stays straight, and electricity flows through it, turning the heater on. You can picture this like a bridge that’s down, letting cars (electricity) through.
  2. When It Gets Hot: One metal gets longer faster than the other, so the strip bends. If it bends enough, it’s like the bridge going up. The cars (electricity) can’t get through anymore, so the heater turns off, and the room cools down.
  3. Cooling Down: As the room gets colder, the strip goes back to being straight. The bridge is down again, and the heater turns back on.
By twisting a temperature dial, you tell the thermostat the exact point you want the bridge to go up or down. It won’t happen instantly; the metal needs time to bend. This slow bending ensures the heater doesn’t keep turning on and off all the time.
Here’s how this clever double-metal strip (bimetallic strip) works in detail:
  • Setting the Temperature: A dial lets you pick the temperature at which the heater turns on or off.
  • Bimetal Strip: The strip is made of two metals (like iron and brass) bolted together. Iron doesn’t get as long as brass when it’s heated, so the strip bends inward when hot.
  • Electrical Circuit: The bimetal strip is part of an electrical path (shown in gray). When the strip is cool and straight, it’s like a bridge, and the heater is on. When it bends, the bridge is broken, and the heater is off.
  1. Mechanical Thermostats
    • Bimetallic Strip Thermostats
    • Liquid-Filled Thermostats
  2. Electronic Thermostats
    • Digital Thermostats
    • Programmable Thermostats
    • Smart Thermostats
  3. Hybrid Thermostats
  4. Line Voltage Thermostats
  5. Low Voltage Thermostats
  6. Pneumatic Thermostats
Advantages
  • Precise temperature control
  • Energy efficiency
  • Convenience and easy adjustment
  • Integration with other systems
  • Enhanced functionality such as learning behavior and maintenance alerts
Disadvantages
  • Complexity and higher cost
  • Compatibility issues with heating and cooling systems
  • Dependence on power (electricity)
  • Potential for inaccurate readings
  • Maintenance and possible battery replacements
Applications
  • Residential heating and cooling systems
  • Commercial building climate control
  • Automotive cooling systems
  • Industrial temperature regulation
  • Refrigeration systems
  • Greenhouses
  • Aquarium temperature control
  • Medical equipment temperature regulation
  • Cooking appliances like ovens and grills
  • Water heating systems
Conclusion
A thermostat, with its bimetallic strip, is like a smart bridge controller, always knowing when to let electricity through (heater on) or stop it (heater off). By understanding and responding to temperature, this simple device helps keep our homes comfy and our energy bills in check. It’s a beautiful example of how something small and smart can make a big difference in our daily lives.
RTD Calculator Software
Pneumatic Temperature Transmitter with Sensor Principle
How Does an Infrared Thermometer Work?
Free Download Thermocouple Calculator
Distributed Temperature Sensors (DTS) in Power Lines
Why RTD installed after the Orifice Plate ?
6 Comments
  • inzamam says:
    June 5, 2016 at 9:02 am
    nice post ……
    I have one doubt…
    how the material properties are getting changed based on the input temperature in dial switch in thermostat working principle…..
    eg.
    if i set a temp 30 deg C …. the bimetal bends at 30 deg C
    if i set temp 100 deg C ….the bimetal bends at 100 deg C
    how this happens ???
    • Sandeep says:
      June 14, 2016 at 3:30 pm
      How the bimaterial Property changes with set point .
    • Fazal says:
      October 27, 2016 at 8:07 pm
      Changing thermostat value actually changes the position of wire 2 relative to bimettalic strip.
      if you increase value for example in above case, it will move the touching end of wire 2 with bimetallic strip furthur to right causing the touching end stay for long time with bimettalic strip.
  • biobala says:
    October 31, 2017 at 1:42 pm
    Really super post
  • darshan says:
    July 1, 2022 at 4:45 pm
    is there stripe heated by resistance of heat or the heat of heater.
    • darshan says:
      July 1, 2022 at 4:47 pm
      *resistance of stripe or heat from heater
Thermocouples Sources of Error
Liquid In Glass Thermometer Principle
What is a Four-wire RTD ?
RTD Standards
What is a Thermopile ?
What is a Temperature Controller? – How to Choose?
Resistance Temperature Detectors Troubleshooting Tips
Installation Precautions of Thermocouple and RTD
Stability and Uniformity of Temperature Bath
Different RTD Types
Difference between PT100, PT1000, Nickel RTD and Balco RTD
Temperature Transmitter Formula
Calculate Temperature Transmitter Output
Thermocouple Material Characteristics
Thermocouple Construction
RTD Testing Methods
RTD Testing Methods in Calibration Laboratory
RTD Connection Diagram
Difference Between 2 wire RTD, 3 wire RTD, and 4 wire RTD’s
Van Stone Type Thermowell
Types of Thermowells
Comparison of Temperature Sensors - Industrial Process Control
Quiz on Thyristor Chopper
Controller Output Current Loop
DCS Controllers to Output Current Loops
Light ON OFF Control using PLC
Gas Detection Definitions
Standard Gas Detection Definitions
Synchronous Machines Efficiency Questions
Instrumentation Loop Diagram
Loop diagram and System Inspection Lab Exercise
