Reading: Thermocouples Sources of Error
Inst Tools > Blog > Temperature Measurement > Thermocouples Sources of Error
Last updated: August 4, 2018 9:55 pm
3 Min Read
Homogeneity (Wire Uniformity)
With thermocouples the main error lies not with stem conduction but with errors arising from inhomogeneity of the thermocouple wire. Therefore for reliable and consistent results the wires must be homogenous, i.e. the wire must have uniform properties, throughout.
The resultant output e.m.f. from a thermocouple is proportional to the temperature difference between the two junctions. The e.m.f. is generated not at the junction but in the part of the wire that passes through the temperature gradient between the measuring junction and the reference junction. As the e.m.f. is generated in the part of the wire in the temperature gradient then changing the immersion depth will change the position along the wire where the e.m.f. is generated. If the wire properties are different then errors occur.
There is nothing magical about the junction and it is a mistake to think that the e.m.f. is generated at the junction.
Thermocouples Calibration Errors
There is debate relating to the wisdom of calibrating thermocouples. Whilst the best method would be to calibrate thermocouples in situ, this is frequently not possible. As this is a practical guide to calibrating sensors, and thermocouples are calibrated in metal block baths, then the approach recommended here is to carefully consider the homogeneity.
It follows that the leads from the thermocouple should not be run through unnecessary temperature gradients and joins in the wire should be avoided when possible. When joins are made they should not be positioned in a temperature gradient.
Lead Resistance
This is generally less of a problem with thermocouples than p.r.t.’s, particularly with modern instrumentation. Manufacturers of thermocouple instruments may specify a maximum loop resistance, typically 100 ohms.
Thermal Lag
For thermocouples built into large sheaths or thermowells, this effect needs to be as considered for p.r.t.’s. For thermocouples constructed from fine wires the thermal lag tends not to be significant; indeed such a sensor may be selected for its fast response properties.
Thermal Capacity
As with Thermal Lag this may be an issue for larger assemblies but not for fine wire thermocouples.
Cold Junction Compensation (CJC) Errors
For simple instruments the CJC is built into the device, e.g. a field temperature transmitter. This will typically consist of a internal temperature-sensing device that measures the temperature of the junction of the thermocouple wire and the instrument and an uncertainty of +/- 1ºC, or more, may be expected.
Also Read : RTD Sources of Errors
What is a Three-wire RTD ?
Important Factors for Thermocouple Selection
Thermocouple Calculations
RTD Calibration
Ambient Temperature Effects on RTD
Basic Temperature Sensors MCQ Questions Answers
  • T R Raja says:
    January 6, 2020 at 2:10 pm
    we are facing an error in temperature measurement we are taken take two comparing thermocouples and standard thermocouple on calibrating comparing thermocouple say A and B reads 1 to 2 Deg error on reaching 700 Deg the difference is coming around 8 Deg.C this happens tree times will you give solution/Reason for that
    type K type
    outer insulation fiber glass 1 time,
    bare wire with ceramic beads 2 nd time
    ceraamic fiber insulation 3 rd time.
What is a Four-wire RTD ?
What is RTD Sensitivity ?
Spiral Bimetallic Thermometer Principle
Use of Temperature Transmitters instead of Direct Wiring
Distributed Temperature Sensors (DTS) in Power Lines
What is Temperature ?
Introduction to RTDs
How to Install Thermowell on an Elbow?
thermocouple types
What is a Thermocouple ?
Temperature Controller Problem
Electrical Resistance Temperature Curves of RTD
Resistance Temperature Detectors (RTD) Construction
RTD Calculator Software
Thermocouple Calibration
RTD installed after the Orifice Plate
Why RTD installed after the Orifice Plate ?
field-mounted thermocouple
Thermocouple Extension Wires
Analytical Instrumentation Engineering Projects
Top 100 Analytical Instrumentation Engineering Projects
Simatic Prosave HMI
How to Backup and Restore from Simatic Prosave HMI?
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Snubber Circuits
Thyristor Protection Circuits (SCR) – Types, Principle, Explanation
Magnetic proximity sensors
Magnetic Proximity Detectors – Types, Principle, Advantages
Difference Between Microcontroller and PLC
Confined Space
Single-Phase Induction Motors Multiple Choice Questions (MCQ)
125+ Single-Phase Induction Motors Multiple Choice Questions (MCQ)
