Reading: PLC Timer Example: Sequential Control of Three Lights with Reset
Inst Tools > Blog > PLC Tutorials > PLC Timer Example: Sequential Control of Three Lights with Reset
Learn how to use a PLC timer for sequential control of three lights with reset functionality including step-by-step programming.
Last updated: October 28, 2024 4:03 pm
7 Min Read
In the world of PLC automation, the Timer is an important component in controlling the time of a program. By using a timer, we can control the time a device or system should be active or inactive. This article will discuss a simple application of a Timer, there are three lights that will turn On sequentially and will turn Off sequentially with a time interval of 10 seconds using Omron CX-programmer PLC software.
Sequential Control of Three Lights with ResetAddressing of ProgramPLC Timer Example
In this PLC example, the following buttons are used.
  1. The PB_START (0.00) button is used to turn ON the system.
  2. The PB_STOP (0.01) button is used to turn OFF the system.
PLC Sequential Lights Control Example
This program has 2 sequences:
SEQUENCE 1
This sequence will Run when the system is turned On, namely when the PB_START (0.00) button is Pressed.
When Sequence-1 has started Lamp 1 LAMP_1 (100.01) will be ON.
10 seconds after that, Lamp 2 LAMP_2 (100.02) will turn ON, and 10 seconds later, Lamp 3 LAMP_3(100.03) will also turn ON.
When Sequence-1 is running, the value in memory word SEQUENCE (D0) will be “1” and will be set to zero “0” when Lamp 1 LAMP_1 (100.01), Lamp 2 LAMP_2 (100.02), and Lamp 3 LAMP_3 (100.03) has turned ON.
SEQUENCE 2
This sequence will Run when the system is turned OFF, namely when the PB_STOP (0.01) button is Pressed.
Sequence-2 can only be executed when Lamp 1 LAMP_1 (100.01), Lamp 2 LAMP_2 (100.02), and Lamp 3 LAMP_3 (100.03) are all ON.
When Sequence-2 has started Lamp 3 LAMP_3 (100.03) will be OFF.
10 seconds after that, Lamp 2 LAMP_2 (100.02) will turn OFF and 10 seconds later, Lamp 1 LAMP_1(100.01) will also turn OFF.
When Sequence-2 is running, the value in memory word SEQUENCE (D0) will be “2” and will be set to zero “0” when Lamp 1 LAMP_1 (100.01), Lamp 2 LAMP_2 (100.02), and Lamp 3 LAMP_3 (100.03) has turned OFF.
PLC Timer Example Sequential Control of Three Lights with Reset
CommentInput (I)Output (Q)Memory WordMemory BitsTimer
PB_START0.00
PB_STOP0.01
LAMP_1 100.01
LAMP_2 100.02
LAMP_3 100.03
TIMER_1    T0000
TIMER_2    T0001
TIMER_3    T0002
TIMER_4    T0003
SEQUENCE_1   W0.00
SEQUENCE_2   W0.01
SEQUENCE  D0
PLC Timer Example
RUNG 0 (START SYSTEM)
In this Rung, when the PB_START (0.00) button is pressed, the value in the memory word SEQUENCE (D0) becomes “1”, so the system will Run on Sequence-1.
PLC Turning Lights On and Off Sequentially
RUNG 1 (STOP SYSTEM)
In this Rung, when the PB_STOP (0.01) button is Pressed and the NO contact of Output LAMP_3 (100.00) is ON, the value in the memory word SEQUENCE (D0) becomes “2”, so the system will Run in Sequence-2.
PLC Automation for Sequential Control
RUNG 2 (SEQUENCE 1)
If the value in the memory word SEQUENCE (D0) is equal to “1”, then the memory bit SEQUENCE_1 (W0.00) will be in the HIGH state and the Timer TIMER_1 (T0000) will Start counting up to 10 seconds.
When Timer TIMER_1 (T0000) has finished counting, the NO contact of Timer TIMER_1 (T0000) will be in the HIGH state and Timer TIMER_2 (T0001) will count up to 10 seconds.
Using PLC Timers for Sequential Control
RUNG 3 (SEQUENCE 2)
If the value in the memory word SEQUENCE (D0) is equal to “2”, then the memory bit SEQUENCE_2 (W0.01) will be in the HIGH state and Timer TIMER_3 (T0002) will Start counting up to 10 seconds.
When Timer TIMER_3 (T0002) has finished counting, the NO contact of Timer TIMER_3 (T0002) will be in the HIGH state and Timer TIMER_4 (T0003) will Start counting up to 10 seconds.
Light Control with PLC Timer
RUNG 4 (LAMP 1)
In this Rung, if contact NO of memory bit SEQUENCE_1 (W0.00) in the HIGH state, then Output LAMP_1 (100.01) will be ON. Because it uses Latching, the LAMP_1 (100.01) Output will remain in the ON state even though the NO contact of memory bit SEQUENCE_1 (W0.00) in the LOW state.
The LAMP_1 (100.01) Output will be OFF if the NC contact of the Timer TIMER_4 (T0003) is in the HIGH state.
RUNG 5 (LAMP 2)
In this Rung, when the NO contact of Timer TIMER_1 (T0000) is in the HIGH state, the Output LAMP_2 (100.02) will be ON. Because it uses Latching, the LAMP_2 (100.02) Output will remain in the ON state even though the NO contact of Timer TIMER_1 (T0000) in the LOW state.
The LAMP_2 (100.02) Output will be OFF if the NC contact of Timer TIMER_3 (T0002) is in the HIGH state.
RUNG 6 (LAMP 3)
In this Rung, when the NO contact of Timer TIMER_2 (T0001) is in the HIGH state, the Output LAMP_3 (100.03) will be ON. Because it uses Latching, the LAMP_3 (100.03) Output will remain in the ON state even though the NO contact of Timer TIMER_2 (T0001) in the LOW state.
The LAMP_3 (100.03) Output will be OFF if the NC contact of memory bit SEQUENCE_2 (W0.01) is in the HIGH state.
PLC Example with 10-Second Delay
RUNG 7 (RESET SEQUENCE)
In this Rung, when the NO contact of Timer TIMER_2 (T0001) or Timer TIMER_4 (T0003) in the HIGH state, the memory word SEQUENCE (D0) will be reset to zero “0”. Because the MOV(021) instruction moves the zero value to the memory word SEQUENCE (D0).
  • Simple Conveyor Control PLC Program Example
  • Create a User-Defined Function Block in Codesys
  • Structured Text PLC Example for Motor Interlock
  • Allen Bradley PLC to PLC Communication Tutorial
  • PLC Packing Machine Control System Program
How to take Backup from Siemens S7-300 PLC?
Retentive ON Delay Timer using PLC
SCADA Hardware and Software
Types of Expressions in the SCL Language of the Tia Portal
Basics of PLC Programming
How to Communicate with Excel from RsLinx?
Studio 5000: Programming Three Motors with Fixed Priorities
PLC Basics – Manual Control, Closed Loop, ON-OFF with Hysteresis
What is CODESYS? Why Do You Need to Learn it?
Sorting and Counting Products on Conveyors by Color
PLC Programming for Multi-Color Sorting Conveyor System
Why Are Charcoal and Salt Added to an Earthing Pit
Why Are Charcoal and Salt Added to an Earthing Pit?
Siemens Tia Portal PLC Training Course
What is a Network Switch?
Download Modscan software
How to Use ModScan Software for Testing Modbus Communication?
PLC Programming Basics for a Packing Machine Control System
PLC Packing Machine Control System Program in XG5000
Simulation in Machine Expert HVAC
How to do Simulation in Schneider PLC?
Learn SCL programming from scratch
How to Start Writing SCL Language in Siemens Tia Portal?
4-wire RTD Bridge Circuit
Why we use Wheatstone bridge in RTD?
absorption-type optical analyzer
Absorption Type Optical Analyzer
Piston Check Valve
What is Piston Check Valve ?
Chemical Sensors Objective Questions
Is it Possible to Measure liquid-liquid Level Interface using Float
Is it Possible to Measure Liquid-Liquid Level Interface using Float?
Electric Circuits Objective Questions – Set 7
NDIR gas analysis
Non-Dispersive Analyzers
Turbidity Sensor Calibration Procedure
