Reading: Siemens S7 300 CPU Status and LED Errors Explanation
Inst Tools > Blog > PLC Tutorials > Siemens S7 300 CPU Status and LED Errors Explanation
Last updated: March 4, 2021 12:14 pm
4 Comments
2 Min Read
In Siemens S7 300 CPUs, there is a series of LED lights with different colors which shows us the modes, status, and errors of the PLC.
S7 300 LED ErrorsSFBFMAINTDC5VFRCERunSTOP
S7 300 LED Errors
SF
System fault: it indicates there is an error in the system, this error could be software error like an error in programming or hardware error like a power loss of one of the input modules
Color: Steady Red
BF
Bus Fault: it indicates that there is an error in the system network, like a bad contact in one of the communication connectors, or there is an overlap between the addresses in the network
Color: Steady Red
MAINT
Maintenance: where ever this indicator energized this means that the CPU is not working anymore and needs a service, but this is rarely happening.
Color: Steady yellow
DC5V
This led indicates that there is a 24 Volt DC provided to the CPU.
Color: Steady Green
FRCE
Force: it indicates that at least one of the PLC inputs or outputs is forced to on or off.
Run
Run mode is on whenever the CPU is working properly without any troubles, and flashes in the startup of the CPU.
Color: Steady Green
STOP
a.
When the CPU is in STOP mode or there is a software/hardware error.
b.
For a memory reset request when inserting the memory card.
Color: Yellow flashes slowly
c.
When the memory reset is being carried out.
Color: Yellow flashes quickly
Author: Karim Ali Anwar
  • Problems with TON Timer
  • Analogy of Ohm’s Law
  • As-found and As-left Calibration
  • Workstation Healthiness Checks
  • Programmable Logic Controller
Connecting Blocks in Functional Block Diagram – Studio 5000
Playground Swing Logic Exercise Program in PLC
PLC Automatic Pedal Switch for Speed Control
Analog Measurement using Ladder Logic
Difference Between Microcontroller and PLC
4 Comments
  • John Quintero says:
    May 27, 2020 at 6:43 am
    Hello Karim, thank you very much for your explanation about the S7 300. Have a great day.
  • Raghu Ram Gudela says:
    July 31, 2022 at 12:31 pm
    What if all the indications flashes at a time? Can anyone explain me about this?
  • Nana Frimpong says:
    July 13, 2023 at 11:48 am
    APPRECITED WITH THE UPDATE ON S7-300-LED ERRORS.
    THANK YOU.
  • MD.Raju says:
    August 21, 2023 at 9:30 am
    In CPU 315 2PN/DP
    if all indicator LED light same time glowing with out blinking what is the problem??
    Thank you
How to use PLC with SQL Database? – Basics & Tutorials
Flexible Input Output Modules
Use of Regions in SCL Language
Siemens PLC Project: Automatic Parking with Vehicle Counter
Allen Bradley SLC 500 PLC Programming
How to take Backup from Siemens S7-300 PLC?
Open Platform Communication (OPC)
Configuration of Siemens Scada and PLC
Configuration of Input and Output Tags in Siemens Scada and PLC
Color detection PLC logic
Conveyor Sorting System with Color Detection PLC Logic
Introduction to PLC
Introduction to PLC – Advantages of PLC
PLC Programmer Salary and Future Career Scope
Burning Oven PLC Program
PLC Program for Ceramic Burning Oven Conveyor System
PLC Programming for Sequential Batch Mixing System
PLC XOR LOGIC with Ladder Diagram
PLC Logic Functions
Inverse Transducers Objective Questions
Battery Hazard
Battery Hazards
Create an Application in HMI using Tia Portal
Fence grounding specifications
All About Electric Fence Gates
Flow Transmitter Output Current Calculation
Calculate Flow Transmitter Output Current
Induction Motor Protection Interview Questions
Induction Motor Protection Interview Questions Answers
Troubleshooting Magnetic Flow Meters Common Problems
How to Create DFB in Schneider PLC? – Derived Function Block
