Reading: Rotameter Working Principle and Animation
Inst Tools > Blog > Animation > Rotameter Working Principle and Animation
A rotameter is a device that measures the flow rate of liquid or gas in a closed tube. It is one type of variable area flow meter.
Last updated: October 31, 2023 12:22 pm
Animation Flow Measurement How It Works
RotameterAdvantages of RotameterDisadvantages of Rotameter
Rotameter belongs to a class of meters called variable area meters, which measure flow rate by allowing the cross-sectional area the fluid travels through, to vary, causing a measurable effect.
Rotameter
Variable Area Flow meter Working Animation
A rotameter consists of a tapered tube, typically made of glass with a ‘float’, made either of anodized aluminum or ceramic, actually a shaped weight, inside that is pushed up by the drag force of the flow and pulled down by gravity.
The drag force for a given fluid and float cross-section is a function of flow speed squared only.
A higher volumetric flow rate through a given area increases flow speed and drag force, so the float will be pushed upwards.
However, as the inside of the rotameter is cone-shaped (widens), the area around the float through which the medium flows increases, and the flow speed and drag force decrease until there is mechanical equilibrium with the float’s weight.
Floats are made in many different shapes, with spheres and ellipsoids being the most common. The float may be diagonally grooved and partially colored so that it rotates axially as the fluid passes.
This shows if the float is stuck since it will only rotate if it is free. Readings are usually taken at the top of the widest part of the float; the center for an ellipsoid, or the top for a cylinder. Some manufacturers use a different standard.
Rotameter Working
The “float” must not float in the fluid: it has to have a higher density than the fluid, otherwise, it will float to the top even if there is no flow.
The mechanical nature of the measuring principle provides a flow measurement device that does not require any electrical power. If the tube is made of metal, the float position is transferred to an external indicator via a magnetic coupling.
This capability has considerably expanded the range of applications for the variable area flow meter since the measurement can observed remotely from the process or used for automatic control.
  • A rotameter requires no external power or fuel, it uses only the inherent properties of the fluid, along with gravity, to measure flow rate.
  • A rotameter is also a relatively simple device that can be mass-manufactured out of cheap materials, allowing for its widespread use.
  • Since the area of the flow passage increases as the float moves up the tube, the scale is approximately linear.
  • Clear glass is used which is highly resistant to thermal shock and chemical action.
  • Due to its use of gravity, a rotameter must always be vertically oriented and right way up, with the fluid flowing upward.
  • Due to its reliance on the ability of the fluid or gas to displace the float, graduations on a given rotameter will only be accurate for a given substance at a given temperature. The main property of importance is the density of the fluid; however, viscosity may also be significant. Floats are ideally designed to be insensitive to viscosity; however, this is seldom verifiable from manufacturers’ specifications. Either separate rotameters for different densities and viscosities may be used, or multiple scales on the same rotameter can be used.
  • Due to the direct flow indication the resolution is relatively poor compared to other measurement principles. Readout uncertainty gets worse near the bottom of the scale. Oscillations of the float and parallax may further increase the uncertainty of the measurement.
  • Since the float must be read through the flowing medium, some fluids may obscure the reading. A transducer may be required for electronically measuring the position of the float.
  • Rotameters are not easily adapted for reading by machine; although magnetic floats that drive a follower outside the tube are available.
  • Rotameters are not generally manufactured in sizes greater than 6 inches/150 mm, but bypass designs are sometimes used on very large pipes.
  • Variable Flow Meter Theory
  • Calibrate Different Flow Meters
  • Turbine Flow Meter Verification
  • Calibration Turbine Flow Meter
  • Orifice Flow Meter Specification
Online Simulation
Electrical Switches Working Animation
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
V Cone Flow Meter – Principle, Advantages, Disadvantages
Dall Tube Flow Meter – Principle, Advantages, Disadvantages
Oscillating Piston Flow Meters Working Principle
Classification of Flow Measurement Techniques
Particle Image Velocimetry (PIV) Principle
Solenoid Valve Working Animation
Probe Type GWR Level Transmitter Working Animation
Open Loop and Closed Loop Animation
Area Velocity Flow Meter Principle
Flow Meters Troubleshooting
Turbine Flow Meters Troubleshooting
Water Cut Meter
What is Water Cut Meter?
Venturi Flow Measurement Principle
Why Flow is Directly Proportional to the Square Root of DP?
Rotameter
What is a Variable Area Flow Meter?
orifice-plate
Orifice Plate Turndown ratio
Metal tube Variable Area Flowmeters Principle
Metal Tube Variable Area Flow Meters Principle
Pressure Temperature Compensation Flow Measurement
Tilt Level Switch Theory
Tilt Level Switch Working Principle
Purpose of Emergency Shutdown (ESD) System
Gearbox within week Failing Journal Bearing upset Plant Operations
Distribution transformer
Different Types of Transformers
What is Hydraulics
What is Hydraulics?
How to do Control Valve Sizing
How do you do control valve sizing in Layman’s terms?
Anti Surge Controller Theory
Anti Surge Controller Working Principle
Pressure Gauges with Diaphragm Sensor Principle
Industrial Automation Acronyms
111 Industrial Automation Acronyms Questions and Answers
