Reading: What is Rewire Tool in Simatic Manager?
Inst Tools > Blog > PLC Tutorials > What is Rewire Tool in Simatic Manager?
Last updated: March 4, 2021 12:03 pm
2 Min Read
This article is about to use of a rewire tool using Simatic manager.
Rewire tool is only used when you want to replace old input or output with a new one.
You can use this only in an offline window of Siemens Simatic Manager.
Do follow the below steps to know how to replace old I/Os with a new one using rewire tool.
To make changes, always remember to select the block which you want to replace with new I/Os.
If you select only a single or few blocks then changes only apply to the selected blocks and not to the whole project.
 Step 1:
Open Simatic manager. Select the “blocks”.
Open Simatic manager function blocks
Step 2:
To open a rewire tool, you can open it in two ways.
First, select the block and go to the option where you can find “rewire”.
Second, select block and do right click and choose “rewire”.
Rewire Tool
Step 3:
The following window will open up. Here, you can add old addresses and replace it with a new one.
rewire tool in simatic manager
Step 4:
For example, I have changed some of the addresses as shown in the below window.
After adding addresses click “ok” to proceed.
STEP7 Rewire tool
Step 5:
The following pop-up will open. Click “yes” to proceed.
Rewiring Function
Step 6:
The following list of the changes will appear in the notepad. Where you can see the list of the block and were changes made to.
You have successfully made changes to the addresses.
Rewiring STEP 7 Simatic Manager
Author: Suhel Patel
  • Trace Function in Tia Portal
  • Script in Intouch Scada
  • InTouch SCADA Login Security
  • Digital to Analog Conversion
  • Open Platform Communication
PLC Ladder Logic for Opposite Acting Control Valves Application
DeMorgan’s Theorems using Ladder Diagram
Setpoints and Alarms in Control System
PLC Sequential Operation Example Program
Parking Lights PLC Program Explained with Video
How to implement SR Flip Flop using PLC Ladder Logic
SCADA Software and their Comparison
Produced Tags and Consumed Tags in Studio 5000
CX-Programmer Products Sorting & Counting – Omron PLC
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
PLC Programming Example on LED Control
Free Omron PLC Programming Course in HINDI
PLC Programmer Salary and Future Career Scope
Multiple Pumps Control using PLC
The STAR-DELTA Auto And Manual Program
Single-acting Pneumatic Cylinder operation with Limit Switch
Single-acting Pneumatic Cylinder Operation with Limit Switch
PLC IO Examples
Quiz: Identifying I/O Examples in PLC Systems
Advantages of Redundant System
Redundant Automation Systems – Need and Advantages
PLC Boxes Sorting Based on Height
PLC Programming: Sorting and Distribution of Boxes by Height
Comparison of Absorption Chillers and Electric (Compression) Chillers
Difference between Water Cooled Chiller and Air Cooled Chiller
PLC Automatic Control of Two Outputs with one Input
Shunt-Wound DC Generator Principle
Shunt-Wound DC Generators
Vision Camera System
Vision Camera Systems in Industrial Automation
Electronic Devices & Circuits Quiz – Set 10
Opposite Acting Valves
What is Split Range Control Loop ?
Installation of a Control Valve
How to Install a Control Valve?
