Reading: How does a Redundant Controller comes in line when the Main Controller fails?
Inst Tools > Blog > Control Systems > How does a Redundant Controller comes in line when the Main Controller fails?
Last updated: December 19, 2019 9:44 pm
Control Systems Guest Articles
2 Min Read
How does a Redundant Controller comes in line when the Main Controller fails in the distributed control system (DCS)?
The Processor Card performs calculations and control computation. In case of Field Control Station (FCS) (simply we can assume as a System Cabinet with Processor cards & other IO cards) with duplexed configuration, there are two processor cards. One of the cards is in control status (main) and the other is in the standby status.
In case of FCS with duplexed configuration, both the processor cards perform control computation.
From the below figure, we have Left Processor Card and Right Processor Card. Again each processor card has two inbuilt processors or CPU, which perform the same control computation (optional feature, some cards may have only one, depends on manufacturer).
By Default, One Processor Card (say Right CPU) will be main and Other (Left) card is in Standby mode during Start-up.
All Inputs & outputs will be shared among the Two Processor Cards (Left & Right). The same program will be downloaded into both Cards (left & Right).
As per below figure, Both Left & Right Processor Cards have two Sub CPU’s inside. The two sub CPU’s in each Processor Card (Left or Right) executes same functions.
A comparator compares the computation results during each computation cycle of these CPU’s. If the results match computation is normal and the data is sent to locations such as the main memory and bus interface unit for further processing to take respective action. If the results do not match, the corresponding processor card will be stopped.
If the error occurs in the active (main) processor card, then switchover to standby card occurs without any interruption to live monitor/control of the plant.
main controller fails
Image Courtesy : Yokogawa
Serial Communication Error Checking Methods and Algorithms
Managed Switch vs Unmanaged Switch
How to Import PlantPAx Library?
Oracle Database 12c Administrator Certified Associate Certification
Features of PID Controller actions
  • Vivian says:
    February 19, 2018 at 6:22 am
    How does it know which processor is giving the error signal ?
Closed Loop Control System : Boiler Water Level Control System
What is Override Control? – Need & Applications
What is Ground, and importance of a Grounding System?
DCS Quiz
DCS Quiz
SinkingOutput
Difference Between the Sinking and Sourcing?
Programmable Logic Controller (PLC)
What is Interposing Relay in a PLC System ?
DCS Marshalling Cabinet Checks
PLC, DCS, and ESD Marshalling Cabinet Checks
Typical process control loop
How Process Control Loop Works
Hot Well Level Control System in Condensing Turbine
Control Panels Material Take-Off (MTO)
Control Panels Material Take-Off (MTO) – Engineering Project
Instrumentation Colleges in United States
Colleges to Study Instrumentation Engineering in United States
What is Shielded Twisted Pair Cable
What is Shielded Twisted Pair Cable? – Advantages, Disadvantages
Why we use Cable Shielding with Ferrites ?
Steam Tracing
Steam Tracing
0-10 VDC to 0-20 mA Conversion
How to Convert Voltage to Current using Resistor ?
Which Gases Can a Multi-Gas Detector Detect
Which Gases Can a Multi-Gas Detector Detect?
Capacitive Level Measurement Principle
Modbus in Industrial Networks
Water Treatment Plant
Difference Between ETP, STP, and WTP – Treatment Plants for Water
