Reading: Proximity switches Circuit Diagram Operation
Inst Tools > Blog > Animation > Proximity switches Circuit Diagram Operation
Last updated: August 22, 2020 7:42 pm
Animation Switches
6 Comments
A proximity switch is one detecting the proximity (closeness) of some object. By definition, these switches are non-contact sensors, using magnetic, electric, or optical means to sense the proximity of objects.
Proximity Switch SymbolPrinciple of Operation:Proximity Switch NPN TypeProximity Switch PNP Type
A proximity switch will be in its “normal” status when it is distant from any detectable object.
Being non-contact in nature, proximity switches are often used instead of direct-contact limit switches for the same purpose of detecting the position of a machine part, with the advantage of never wearing out over time due to repeated physical contact.
Most proximity switches are active in design. That is, they incorporate a powered electronic circuit to sense the proximity of an object. Inductive proximity switches sense the presence of metallic objects through the use of a high-frequency magnetic field. Capacitive proximity switches sense the presence of non-metallic objects through the use of a high-frequency electric field. Optical proximity switches detect the interruption of a light beam by an object. Ultrasonic proximity switches sense the presence of dense matter by the reflection of sound waves.
The schematic diagram symbol for a proximity switch with mechanical contacts is the same as for a mechanical limit switch, except the switch symbol is enclosed by a diamond shape, indicating a powered (active) device:
Proximity Switch Operation Animation
Many proximity switches, though, do not provide “dry contact” outputs. Instead, their output elements are transistors configured either to source current or sink current. The terms “sourcing” and “sinking” are best understood by visualizing electric current in the direction of conventional flow rather than electron flow.
The following schematic diagrams contrast the two modes of switch operation, using red arrows to show the direction of current (conventional flow notation). In both examples, the load being driven by each proximity switch is a light-emitting diode (LED):
Proximity Switch consists a sensor circuit and a driver circuit. The sensor circuit purpose is used to detect any near by objects. The sensor circuit sends an output High signal to the transistor based driver circuit when any object found near to the sensor circuit. The transistor based driver circuit may use NPN or PNP transistors and it depends on the application we use.
When a signal received from the sensor circuit, the transistor will be turned ON and the output will be ON. When the object is moved away from sensor circuit, the sensor output is OFF so transistor is OFF and the output will be OFF.
Note: The sensor circuit may contain a LC Resonant oscillator or a mutual induction based circuit. The LC Resonant oscillator generates a designed resonant oscillations continuously. whenever there is any metal object nearby to the sensors, the oscillations may vary and it depends on the object properties. This change in oscillations will be detected and generates an output either High or Low,  nothing but object found or not.
Proximity Switch Circuit Diagram Explanation with Animation
Note: The Red dot in the animation indicated the flow of current path.
Proximity Switch PNP Type Working Animation
A common coloring convention for electronic proximity switches is brown for +V power supply, blue for ground (− pole of power supply), and black for the switched output signal. This convention is common to sinking and sourcing proximity switches alike.
An electronic switch designed to sink current through its signal wire is alternatively referred to as an NPN switch due to the type of transistor used in its output. Conversely, an electronic switch designed to source current through its signal wire may be referred to as a PNP switch.
The key to understanding these labels is to recognize the emitter terminal of the output transistor is always the one connected to the power supply rail. For a sinking switch, this means the emitter must connect to the negative rail, necessitating an NPN transistor to do the switching. For a sourcing switch, this means the emitter must connect to the positive rail, in which case only a PNP transistor will suffice.
Hall Effect Sensor Working Principle Animation
Guided-wave Radar Level Measurement Animation
What is ON/OFF Valve ?
Turbine Flow Meters Animation
Encoder Working Principle
6 Comments
  • Isaac Newton says:
    August 9, 2016 at 5:05 pm
    Explained in a better way … Thanks
    Please expalin PNP & NPN in a better way.
  • Umesh Maurya says:
    October 14, 2016 at 10:18 am
    sir,
    when i am making print. Header line Heading line (Animation Basics, Measuremetn… etc.) full design spot coming in between Aricals. So please do someting.
    thanks.
    • S Bharadwaj Reddy says:
      October 14, 2016 at 12:52 pm
      Hi, Right now i am facing some problems with Print/Pdf options. Soon those will be solved. Thanks
  • Bikash Dutta says:
    October 10, 2019 at 11:29 pm
    Very good thing
  • GANI MULYANA says:
    June 18, 2020 at 6:58 pm
    AMAZING
  • asdf says:
    November 10, 2021 at 11:20 am
    What software did you use to stimulate this?
Basics of Ball Valves
Flare Knockout Drums Working Animation
Temperature Switch Principle
Digital Building Blocks – GATES
Side Mounting Float Switch Working Principle
Pull Up and Pull Down Switch Circuits
Microwave Flow Sensor – Working Principle and Applications
Dome Valve Working Principle
Total Organic Carbon Analyzer Working Principle
TOC Analyzer Working Principle
Capacitance Type Level Transmitter Working Principle
Capacitance Level Transmitter Animation
Pyrometer Principle
Optical Pyrometer Working Principle Animation
Flow Switch Symbol
Principle of Flow Switch
Differential Pressure Switch Working Principle
Relay Wiring
DPDT switch
Switch Types and Common Terminology
Switch NO or NC Contact
Normally-open and Normally-closed Switch Contacts
Analog Electronics Projects
Analog Electronic Projects for Final Year Engineering Students
Flow Meter Hook Up
Flow Meter Installation Guidelines
Career Scope in Electrical Engineering
Allen Bradley PLC to PLC Communication in Studio 5000
Advantages of Redundant System
Redundant Automation Systems – Need and Advantages
Ladder Logic for Motor Control
PLC Programming for 3 Motors control in Ladder logic
Alarm Management System
What is Alarm Management System ?
PID Simulator
PID Simulator Download
