Reading: Principle of Operation of PLC
Inst Tools > Blog > PLC Tutorials > Principle of Operation of PLC
To understand the PLC working process, let’s take one simple example application is to turn ON a lamp using one push-button and stop button.
Last updated: March 12, 2023 10:24 am
To understand the PLC working process, let’s take one simple example in figure 1.0. The application is to turn on a lamp using one push-button and stop using another button.
PLC Working ProcessPLC Input ModulePLC Output ModuleBasic PLC Program Example
PLC Working Process
Let’s take the IO list before starting the program,
Input components of this application are two buttons, Start and stop pushbuttons. The output component is one lamp. All three IOs in this example come under digital IOs, which meant one bit require for its operation.
Also Read:
  • Introduction to PLC
  • Parts of PLC
PLC Input Module
Both the inputs are connected to the input module of the PLC and the output lamp is connected to the PLC output module.
PLC Input Module Circuit
Fig 1.1 – Input Module
PLC Output Module
Lamp output connected to Out 0 of PLC output module as shown in fig 1.2
PLC Output Module Circuit
Fig 1.2 – Output Module
According to the PLC vendor, Addressing the PLC IO channels (ports) will get vary. The images above for IO wiring is generalized one. The connection can be sink or source according to the PLC hardware.
Building a PLC Panel from Scratch - Industrial Control Panel
Let’s write the program for the above example in Allen Bradley PLC Software, refer fig 1.3
PLC Example Program for Lamp
Figure 1.3 – PLC Ladder Logic
Start push-button (PB) is addressed as I: 0/0 which is the format of giving a single bit address. Stop push-button (PB) as I: 0/1 and output lamp as O: 0/0.
There are two types of contacts in Ladder programming,
  1. NO (Normally open) and
  2. NC (Normally closed).
Usually, NO is used to make the contact and NC is to break the contact. In the above example, Start PB is pressed to turn on the lamp (Which is meant to make a contact to turn ON lamp), so we used normally open contact of PB.
The lamp is a coil, which will turn on if PB is pressed. But when using pushbutton (PB) we should clearly understand its working flow. Whenever we press PB, only that time it will make a contact, if release the PB, it will turn off the lamp.
Latching is another concept in the ladder to make a contact continuously. We latched another contact named the same as start PB address in parallel to start PB. Whenever start PB is pressed, it latched this parallel contact to make the lamp on continuously.
Stop PB is to turn off the lamp which is meant to break the contact, NC contact is used in series with Start PB. Whenever it is pressed it will turn off the lamp by breaking the latching circuit.
Push buttons are used in Industries for their easy handling and rust-free properties.
Once the logic is done in PLC programming software, We have to download the program into the PLC controller using PPI (Point to Point Cable) or Ethernet Cable. CPU has to be in the run mode to see the output and input status in software.
CPU of the controller stores the program in its memory. When the corresponding physical input goes high, the CPU reads the input details to the program, performs the logic we have written inside the program, and fetches the output to output modules which will turn on/off the physical output. This reading, processing, and fetching of IOs inside the CPU is called SCAN time.
The same concept can be done by using the relay concept.
Normally open push button will be looks like below, in relay logic
Basic Symbols in PLC
A normally closed push button will be looks like as shown in the above diagram.
The relay coil symbol is also shown in the above diagram.
Replacing the NO and NC contacts with the above symbols can build the relay logic.
Author: Hema Sundaresan
  • SFC Language in PLC
  • PLC Sizes and Applications
  • Functional Components of PLC
  • PLC Hardware Troubleshooting
  • Errors and Faults in Siemens PLC
PLC Pump Permissive Interlocks
Difference Between Normal Counters and Fast Counters – Learn PLC
What is Motor Jogging ?
Implement UDT in PLC Programming: User-Defined Data Type
Difference between DCS & PLC Systems
SCADA Communication and Protocols
Instrumentation System Architecture
What is an RTU? – Remote Terminal Unit
PLC Interlock Logic with First Input Priority
Example PLC Program
Surface Grinding Process using PLC Program
Automatic Box Filling System using PLC Programming
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
Proper Earthing Practices Used for PLC Control Panel
PLC Logic - Control Spray Nozzle, Fans, and Puncher
Advanced Ladder Logic PLC Example
Automatic Sanitizer – Complex Ladder Logic PLC Examples
Industrial PLC Communication Network
Basics of Industrial Communication Networks
Forward Reverse Motor Control with Repeat Cycle Using PLC
Difference between Power Cables and Signal Cables
Level Transmitter configuration in PLC
Scaling with Parameters (SCP) Instruction in PLC
PLC Engineers Interview Questions
PLC SCADA Engineers Interview Questions and Answers
Effect of Lead Wire Resistance on RTD
valve plug and seat damage
Control Valve Erosion Problems
Why is White Powder Used in Electrical Cables
Why is White Powder Used in Electrical Cables?
Common Control Valve Problems
Troubleshooting Common Control Valve Problems
Chocked flow
Control Valve Cavitation and Flashing
4 way solenoid valve root cause
Safety Liquid Ammonia Disconnect threatens NH3 Vapor Spill
Synchronous Motor Starting Methods
Thyristor Chopper Circuit Quiz
