Reading: Preventive Maintenance of Weighing Scale
Inst Tools > Blog > Common > Preventive Maintenance of Weighing Scale
Last updated: March 11, 2024 3:35 pm
Common
The weighing scales are found in many industries, almost every plant may have a weigh scale. It is a very important component because you need to check how much material you are dispatching, receiving, or transporting.
Without a weighing scale, you cannot function a plant system properly. Like every device, industrial weighing scales too require maintenance on time. This ensures longer life as repeated failure of this equipment can prove too costly for plant operations. In this post, we will see how to do preventive maintenance of weighing scales.
Maintenance of the Weighing Scale
Weighing Scale Maintenance
Weighing scales are electrically operated devices. Some are battery powered and some require direct power. Mostly, issues occur in battery-powered ones.
Either the battery can go dead quickly, become faulty, or give low power output. So, it is necessary to frequently check batteries and replace them if necessary.
Many operators do not check the loading capacity of the scale. If its maximum range is 1000 kg, then they will intentionally or unintentionally place a load of higher than 1000 kg for getting their work done. Overloading is not good for the performance of the scale, as it will deprive it after some time of its performance. It can damage the internal load cell of the device.
Cleaning is the best solution for maintenance. When you are loading or unloading material on the scale, it can accumulate dirt, dust, or other contaminants on its surface. If it reaches its internal parts, it can damage them after prolonged use. So, regularly clean the scale, avoid touching sensitive parts for cleaning, and read the SOP of the scale for its cleaning. It will clearly state the liquid to be used for this purpose.
Visual inspection is a great tool for maintenance. Often operators ignore it and do not see the scale properly. Check for any hardware damage, broken wire, incorrect weight display, broken display, or any abnormal sound coming.
As the weighing scale is an electrical device, it must be properly grounded, connected to earth leakage circuit breakers, and other safety which will provide safety to the device and nearby personnel from any shock, voltage fluctuation, or damage.
Weigh Bridge
Always touch the scale by wearing proper PPE, hand gloves, safety glass, or protective clothes.
Electrical devices must be conducted with risk assessment. This will potentially warn the operators of any safety hazards or risks involved in operating it.
Every display has some error code in it to show what is the fault. If any code appears on the display, check it and try to troubleshoot. Ignoring the error code is not a good sign for the performance of the weighing scale.
An electronic device cannot function without its software inside. So, a scale must be regularly checked with its vendor for any firmware or software update for proper functioning.
At Least calibrate the scale once a month, so that you get accurate weight readings. If it is not done, then there are chances that you may get improper readings and affect your performance. So, timely calibration is also a must; also because different types of loads can have some effects on the weighing of the scale.
Maintain proper documentation of the maintenance schedule like calibration dates, maintenance tasks, the date on which repair was done, or other data related to maintenance. This will help the engineers to keep a record of the scale performance and how to maintain it in the future.
Check all the legs of the scale are touching the surface. It happens that after some course of time, some screws may become loose. This can lead to an unbalance of the scale mounting. And if some heavy or critical load is placed on the scale, it can fall down and become unsafe for operation.
  • Valve Commissioning
  • What is a Pilot Valve?
  • What is a Poppet Valve?
  • Valve Flow Direction
  • Solenoid Manual Reset
What is a Spare Part? Classification, Cost, Critical Inventory
HVAC Water Chillers Principle
What are the Advantages & Disadvantages of CNC Milling?
Streamlining Field Instrumentation: The Role of Advanced Overlays
Instruments Troubleshooting – Problems, Causes, Corrective Actions
What Type of Heating is Best for Your Home?
Car Lifts – Choosing the Right One for Your Mechanic Shop
How are Data Centers Cooled?
Conveyor : Belt, Screw, Pneumatic, Hydraulic, Roller, Chain, Bucket, Vibratory
Ideal Guide To Sheet Metal Fabrication Manufacturing and Design
What is a Legend? – Piping and Instrumentation Diagram
HVAC Refrigeration Cycle
Fiber Optic Cable vs Coaxial Cable
What Do You Learn in Software Engineering?
Password Protect Apps and Files
International Standards - Types and their Details
International Standards – Types and Their Details
Tungsten Grinders
How to Choose the Best Tungsten Grinders for Welders?
CNC Milling versus CNC Turning
CNC Milling versus CNC Turning – Which is the Best Option?
How Does Starlink Work
How Does Starlink Work?
Hydrogen Sulfide Accident
The Aghorn Hydrogen Sulfide Accident – H2S Gas
Optical Modulation
What is Optical Modulation? – Methods of Optical Modulation
IPv4 vs IPv6 - What’s the Difference Between IP addresses
IPv4 vs IPv6 – What’s the Difference Between IP addresses?
Solar-Based Engineering Projects
Top 100 Solar-Based Engineering Projects
Purpose of Stop in a Pressure Measuring Instrument
Pressure Measurement using Manometer
PLC ON DELAY TIMER FUNCTION
#6 PLC Best Practices – Validate Timers and Counters
Advances in Control System
Neural Networks
Classification of Weighing Balance
Classification of Weighing Balance and Weight
Problem in Water Level Control System
PLC Program for Burglar Alarm Security System
PLC Program for Alarm Security System
