Reading: Premature Arc Fault Breaker Failures
Inst Tools > Blog > Root Cause Analysis (RCA) > Premature Arc Fault Breaker Failures
3.3. KV motors antifriction bearings did not last 6-months even!. Premature arc fault breaker failures - Electrical Problems.
Last updated: September 28, 2022 3:02 pm
S Raghava Chari
2 Min Read
Electrical engineering root cause analysis (RCA) related to premature arc fault breaker failures and their solutions.
Arc Fault Breaker Failures ProblemAuthor Root Cause AnalysisSolution
Article Type:Root Cause Analysis (RCA)
Category:Electrical
Equipment Type:Motors
Author:S. Raghava Chari
Peculiar pits at the inner race and outer race rolling-element contacting area pointed out induced current circulation via the Arc Fault Breaker (AFBs) as RC.
Solution
The author declined the manufacturer’s offer of free replacement Arc Fault Breaker (AFBs); he pointed out a German Motor fitted with an insulating sheet below the Plummer block to stop shaft current circulation and insisted on a similar solution.
Finally, the manufacture fitted a Nylon insert at the NDE bearing seat of each motor.
Shaft current circulation ceased and hence AFB’s suffered no shaft current flow failures.
Author: S. Raghava Chari
  • Problems with Switchgears
  • Transformer Problem Solved
  • Aluminum Cable Terminations
  • What is a Magnetic Contactor?
  • Arc Fault Breaker Problem Solved
Too Low-Temperature Readings after a Failed Thermocouple Change
Frequent Feeder-A Lightning Arrester (LA) Bursts – Root Cause Analysis
Gearbox within week Failing Journal Bearing upset Plant Operations
Less than 40% available Plant Air Compressors made available 100% for Operations
Industrial Light Fittings and Street Light Poles Corrosion Problems
Automation Panel Electronic Cards Failure investigation
None Could Repair Slightly Damaged Magnetic Flow Meter Flow Tube
Root Cause Analysis for Tank Overflow due to Valve Problem
Recurring Short Circuit Flash Overs Safety Hazards & Damages
30 Electrical Engineering Problems – Root Cause Analysis
Repeat Failures of Letdown Valves
Control Panel Instruments Problem Threatened Plant Shutdown
Panel and Field Pneumatic Controller’ Bumpless Transfer Issues
Welding Machine Fail in Dusty and Corrosive Areas
Plant Air Storage Tank
Incident Investigation: Motor Operated Valve Lesson
Mechanical Engineering Plant Problems Solved
Mechanical Engineering Plant Problems Solved – Root Cause Analysis
old Pressure Switches
Pressure Switch Frozen Screwed Cover Extends the Plant Shutdown
Discharge Head 3‑monthly leaks of Steam Turbine Driven Centrifugal Compressors
Single Bearing Motor Stator Winding
Critical High KiloWatt Motor Winding Burnout Threats
Junction Box Cooler
Junction Box Internal Corrosion Problems and Solutions
Piston No-Diaphragm Seal Instrument
Seal Pressure Instruments Root Cause Analysis
Cutaway View of Circuit Breaker
Low Voltage Air Circuit Breaker Principle
Pump Low throughput
[RCA] Pump Low throughput Eliminated
Distributed Control System Questions and Answers
Distributed Control System Objective Questions
A Question on Steam Drum Water Level Measurement
Top 250 Electronic Circuits Objective Questions and Answers
On Delay Timer TON in Tia Portal
Timers in PLC Programming – Siemens Tia Portal Tutorials
Rotating Magnetic Field Multiple Choice Questions
Thin Client in SCADA
What is Thin Client in SCADA? – Purpose, Advantages
