Reading: Pneumatic Moment-balance Differential Pressure Transmitter
Inst Tools > Blog > Practical Questions > Pneumatic Moment-balance Differential Pressure Transmitter
Explain the principle of Pneumatic Moment-balance Differential Pressure Transmitter using the circuit diagram.
Last updated: October 3, 2020 10:04 am
Practical Questions
3 Min Read
The following diagram is that of a pneumatic moment-balance differential pressure transmitter, similar to the Foxboro model 13A. The term “moment” refers to the physics principle of a force acting on a lever to produce a torque.
“Moment-balance” is more appropriate than “force-balance” in this case because the device pits moment against moment, rather than force against force directly:
Pneumatic Differential Pressure Transmitter
Describe this instrument’s response to an increasing differential pressure (increasing pressure on the “High” side, and steady pressure on the “Low” side; or decreasing pressure on the “Low” side with steady pressure on the “High” side), step by step.
Answer:
As the differential pressure increases (“high” side pressure increases relative to “low” side pressure):
  • The diaphragm “capsule” is forced to the right.
  • The Force bar rotates counter-clockwise about the sealing diaphragm, which acts as a fulcrum for the force bar.
  • Flapper approaches nozzle.
  • Nozzle backpressure increases.
  • Increased nozzle backpressure presses up on relay diaphragm.
  • Inside the relay, the ball-shaped supply valve opens and the cone-shaped vent valve closes.
  • Relay output pressure increases (more than the nozzle backpressure increase, due to amplification).
  • This output pressure is sent to the bellows, which presses to the left at the range bar’s lower end.
  • The range bar rotates clockwise about the “range wheel” (movable fulcrum nut).
  • The top of range bar moves to the right, pulling against the force bar to move the flapper away from the nozzle.
  • The system reaches equilibrium, where the force exerted by the bellows against the range bar balances force exerted by the diaphragm capsule against the force bar.
End result: output pressure equals some proportion (multiple or fraction) of differential pressure across the diaphragm capsule.
More Questions
1. Describe the purpose of the sealing diaphragm shown roughly mid-way along the length of the force bar.
2. Identify how this instrument will respond to obstructions (blockages) in the following locations:
→ Orifice
→ Nozzle
→ Vent (located on relay body)
Interest to add any further points? Share your answers with us through the below comments section.
  • Pressure Gauge Dial
  • Level Gauge Design
  • Diaphragm Pressure Sensor
  • Pneumatic Relay Questions
  • Instrument Calibration Question
Credits: Tony R. Kuphaldt
Compressor Emergency Shutdown Root Cause Analysis
Differential Capacitance Pressure Sensor Circuit
Motion-Balance and Force-Balance Instruments
Determine the Instrument Calibration Error
Electric-driven Air Compressor Troubleshooting
Resistance Temperature Detector (RTD) Questions – 2
Simple High Level Indicator Circuit
Find Thermocouple Ouput Voltage
PLC connected to Three Pushbutton Switches
Upgrading the Electrical System in an Automobile
Identify Two Pressure Switches Logic
Liquid Level Switch Control Logic
Calculate the 0%, 50%, and 100% Calibration Points
Purge Type Level Transmitter
Purge Type Level Transmitter Questions
Guided-wave Radar Asset Management Parameters
Siemens PLC Block Diagram
Programmable Logic Controller (PLC) Questions and Answers – 14
10 Questions on Reforming Furnace Control System
PLC program to control a water pump
PLC Program to Control a Water Pump
level control system
Practical Process Control System Questions & Answers – 11
Dip Tube Type Level System
Questions on Dip Tube Type Level System
Calculate Hydraulic System Fluid Pressure
Phosphate Dozing System
Phosphate Dozing System Problems
Temperature Sensors Fault
Lime Slaker
Advancements in Lime Slaking Technology: What’s New And What’s Next
igbt-symbol
Types of IGBT
Basics of Emergency Shutdown System
Emergency Shutdown System Philosophy
Concepts of State, State Variables & State Model
PLC Commissioning and Testing
PLC Commissioning and Testing Procedure (Programmable Logic Controller)
Turbine-Compressor System Architecture
