Reading: 1 to 8 Demultiplexer PLC ladder diagram
Inst Tools > Blog > PLC Tutorials > 1 to 8 Demultiplexer PLC ladder diagram
Implement 1:8 Demultiplexer in PLC using ladder diagram programming language. Learn PLC programming using examples.
Last updated: November 3, 2023 2:02 pm
This is a PLC Program to implement 1:8 De-multiplexer.
1 to 8 Demultiplexer PLCProblem DiagramProblem Solution1:8 DeMultiplexer Truth TableList of inputs/outputsLadder diagram for 1:8 DemultiplexerProgram Description
Problem Description
Problem Diagram
PLC Ladder Logic for Demultiplexer
Problem Solution
Demultiplexer has one data input Di and three select inputs S0, S1 and S3 and 8 outputs Q0.0 to Q0.7.
To select “n” outputs, we need m select lines such that 2^m = n. Depending on the output. The selection of one of the n outputs is done by the select pins.
Realize the de-multiplexer using Logic Gates. Here we will configure de-multiplexer using ladder language.
When three switches are OFF and Di input is pressed then first output will be ON.As per table we can activate output by switching combination.
DeMultiplexer PLC Truth Table
List of inputs
  • S0 :- I0.0
  • S1 :- I0.1
  • S3 :- I1.0
List of outputs
  • Output1 :- Q0.0
  • Output 2 :- Q0.1
  • Output 3 :- Q0.2
  • Output 4 :- Q0.3
  • Output 5 :- Q0.4
  • Output 6 :- Q0.5
  • Output 7 :- Q0.6
  • Output 8 :- Q0.7
PLC Ladder Logic for Demultiplexer - 1
Demultiplexer PLC Ladder
Demultiplexer PLC Ladder Diagram
Demultiplexer PLC Logic
PLC Demultiplexer Logic
PLC Demultiplexer Example
PLC Demultiplexer
PLC Demultiplexer 1 to 8
Program Description
For this application, we used S7-1200 PLC and TIA portal software for programming.
Network 1:
If Data bit (I2.0) is ON and all inputs are OFF (I0.0=0, I0.1=0 and I0.2=0), Output 1 (Q0.0) will be ON.
Network 2:
If data bit (I2.0) is ON, input 1 (I0.0) OFF, input 2 (I0.1) OFF and input 3 (I0.2) is ON, Output 2 (Q0.1) will be ON.
Network 3:
If data bit (I2.0) is ON, input 1 (I0.0) OFF, input 3 (I0.2) OFF and input 2 (I0.1) is ON, Output 3 (Q0.2) will be ON.
Network 4:
If data bit (I2.0) is ON, input 2 (I0.1) ON, input 3 (I0.2) ON and input 1 (I0.0) is OFF, Output 4 (Q0.3) will be ON.
Network 5:
If input 2 (I0.1) and input 3 (I0.2) are OFF and input 1 (I0.0) is ON, Output 5 (Q0.4) will be ON.
Network 6:
If data bit (I2.0) is ON, input 1 (I0.0), input 3 (I0.2) ON and input 2 (I0.1) is OFF, Output 6 (Q0.5) will be ON.
Network 7:
If data bit (I2.0) is ON, input 1 (I0.0), input 2 (I0.1) ON and input 3 (I0.2) is OFF, Output 7 (Q0.6) will be ON.
Network 8:
If data bit (I2.0) is ON, input 1 (I0.0), input 2 (I0.1) and input 3 (I0.2) ON, Output 8 (Q0.7) will be ON.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of 1:8 Demultiplexer, we can use this concept in other examples also.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications. Also all interlocks are not considered in the application.
Author: Bhavesh
  • PLC 3 to 8 Line Decoder
  • Matrix Keypad works ?
  • PLC T Flip Flop Logic
  • Flow Totalizer in PLC
  • SR Flip Flop using PLC
Timer in Studio 5000 – TON, TOF, RTO
Implement UDT in PLC Programming: User-Defined Data Type
How to Create Project in Wonderware Intouch?
Latched and Momentary Operation of Motor PLC Program
Tia Portal – OB30 Cyclic Interrupt Organization Block
PLC Program for Automatic Parameter Initialization When Power UP
PLC Programming Course Online Free
PLC Program for Filling Operation
PLC Program for Continuous Filling Operation
Omron PLC programs
PLC Programming Best Practices and Tips
Draw a Ladder Logic to control a bulb using push buttons in PLC
Concept of Latching in PLC
Relay Permissive and interlock circuits
PLC Program to Control Motor Speed using VFD Drive
Motor Speed Control using VFD and PLC Programming
Safety Tips When Working With Electricity
Safety PLC Programming steps
Safety Door Interlock PLC Program
Diaphragm Pump
What is a Diaphragm Pump?
Centrifugal Compressor outage reduced
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Power Transistor Objective Questions
Zigbee Projects
Zigbee Based Project Ideas and List
Reduce Control Valve Noise
How to Reduce the Control Valve Noise?
