Reading: PLC Level Control of Two Tanks
Inst Tools > Blog > PLC Tutorials > PLC Level Control of Two Tanks
Design a ladder logic for PLC level control of two tanks. Learn the PLC programming with practice problems.
Last updated: November 3, 2023 12:47 pm
PLC Level Control of Two TanksProblem DiagramProblem SolutionList of inputs and outputsPLC Ladder diagram for level controlling of two tanksProgram ExplanationResult
Problem Description
Two simultaneous process are to be performed in two separate tanks which are connected through a valve.
First Process takes place in process tank 1 and second process takes place in tank 2. Write the ladder program for level controlling of two tanks in PLC.
Problem Diagram
PLC Program to Control Level of Two Tanks
Problem Solution
Arrange two pressure controlled tanks for processes. Process 1 will be done in process 1 tank and process 2 will be done in process 2 tank.
Use an inlet vale for material inlet in process 1 tank. Add one more valve between two tanks as a connecting valve.
Consider two sensors (High and Low) for process 1 tank and consider only low sensor for process 2 tank.
For this application we can use PLC, we will write PLC program for this application.
Digital Inputs
  • Cycle START :- I0.0
  • Cycle STOP :- I0.1
  • Low level process 1 tank (LL1) :- I0.3
  • Low level process 2 tank (LL2) :- I0.4
  • High level process tank 1 (LH1) :- I0.5
  • Process 1 done :- I1.0
  • Process 2 done :- I1.1
Digital Outputs
  • Inlet valve :- Q0.0
  • Connecting valve :- Q0.1
  • Outlet Valve :- Q0.2
M memory
  • Cycle ON bit :- M0.0
PLC Level Control
Tank Level Control
PLC Tank Level
Program Explanation
For this application, we used S7-300 PLC and TIA portal software for programming. We can implement this logic by using other PLC also.
Network 1:
Network 1 is for latching circuit. Whenever START button is pressed (I0.0), Cycle ON (M0.0) bit will be ON. Cycle can be STOP by pressing STOP PB (I0.1).
Network 2:
If LL1 (I0.2) is detected and cycle START is pressed, an inlet valve (Q0.0) will be ON. Consider LH 1(I0.3) interlock during this function.
Network 3:
When the level of material of process tank 1 goes high hence LH 1(I0.3) is detected and level of material in process 2 tank goes low, connecting valve (Q0.1) will be ON. This function takes place while PLC is detecting process 1 done command.
Network 4:
When process 2 is completed and process 2 tank is not low, an outlet valve (Q0.2) will be ON. Cycle ON bit (M0.0) should be ON during the whole cycle.
Note : The above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also.
Result
Author: Bhavesh
  • PLC Execution of the Application
  • VFD Motor Speed Control
  • PLC Heating and Mixing of Products
  • Two Way Switch Logic using PLC
  • PLC Counting Moving Objects
1oo2 Evaluation Safety Instruction in Safety PLC
How to Download GX Works? Mitsubishi PLC Software
Relay circuits
Identify the Problem in the PLC Program
Real-time PLC Projects – Industrial Automation
PLC Program to Simulate Gate Array Logic
  • Pradeep says:
    September 16, 2018 at 10:18 am
    Where is ladder diagtam for process 1&2. Please mention it, so that new comers can under easily.
PLC Programming Example for Motor Forward and Reverse Control
Top PLC Manufacturers
Timers using Statement List (STL) PLC Programming
What is a PLC? – Programmable Logic Controller
Tia Portal – Optimized and Standard Data Block Access
Difference Between Normal Counters and Fast Counters – Learn PLC
How a PLC communicates with Transmitters
How PLC Reads the Data from Field Transmitters
PLC Program for Water Level Control
PLC Program for Water Level Control Logic
Classic Control Circuits
Save and BR Memory in Siemens PLC Programming
SAVE and BR Memory Instructions in Siemens PLC Programming
Use of Regions in SCL Language
Remote Factory Acceptance Test
Free Download PLC Simulator using Excel
IP Address Change in Simatic
PLC Configuration of Profinet I/O System
CONTROL VALVE CHARACTERISTICS
Difference between Quick Opening, Linear & Equal Percentage Control Valve characteristics
DP transmitter with Manifold
Pressure Transmitter Manifolds
How to Control VFD with PLC using Ladder Logic
Alternator Voltage Regulation Quiz
Functional Design Specifications (FDS) for DCS and SIS Projects
Functional Design Specifications for DCS and SIS Projects – FDS Document
Advantages and Disadvantages of Per Unit System
