  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: PLC Program for Flow Totalizer
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > PLC Program for Flow Totalizer
PLC program to implement totalizer for flow meter. The flow meter has 4-20mA output that represents 0 to 100 liters/hour fuel flow in a pipe.
Last updated: November 3, 2023 11:32 am
5 Comments
Make a PLC program to implement a totalizer for the flow meter. The flow meter has 4-20mA output that represents 0 to 100 liters/hour fuel flow in a pipe.
PLC Program for Flow TotalizerProblem SolutionList of Inputs/OutputsInputs ListM MemoryLadder Diagram for TotalizerProgram ExplainedNetwork 1:Network 2:Network 3:Network 4:Result
By using this logic, we can calculate total fuel passed from the pipe.
When the totalizer value reaches 5000 liters, then automatically it should be reset or we can reset the value using the RESET button.
Problem Solution
We can solve this problem by simple logic. Here we consider a flow meter for measuring the fuel with a maximum flow rate of 100 liters/hour.
Here we will convert this flow rate from L/H to L/Sec by using DIV instruction for calculation.
After that by using 1 second clock pulse, we will store this value in another memory location and every second new value will be added & updated.
Here for example we consider the max value for the totalizer to be 5000 liters so after this value totalizer should be RESET.
So we will compare this value with the actual value and reset it automatically or we will provide a RESET button to reset the totalizer value.
Inputs List
  • Reset:- I0.0
M Memory
  • M0.5:- 1 second (1s) clock pulse
  • M1.2:- Positive edge of clock pulse
  • MD10:- Memory word for final output (L/H) of flow meter
  • MD18:- Memory word for final output (L/Sec) of flow meter
  • MD22:-Total liters addition
  • MD26:-Total fuel in liter
Flow Totalizer
Flowmeter Totalizer
flow totalizer plc logic
plc programming totalizer
Program Explained
In this problem, we will consider S7-300 PLC and TIA portal software for programming.
Network 1:
Here we have taken final output value of the flow meter in L/H (MD10). By using DIV instruction we converted L/H flow into L/sec and final value stored in MD18.
Network 2:
Here clock pulse of 1s (M0.5) will add value every second and store the result in memory word MD22.
Network 3:
Here we moved value of MD22 in MD26 (total fuel in liter) for display purpose.
Network 4:
In this network we need to reset totalizer. If total fuel is greater than 5000 (5000 value is for example purpose, it is depended on flow meter configuration & it’s range ) then totalizer count should be zero automatically or we can reset by pressing RESET button (I0.0).
Note: The above logic is for explanation purpose only. Here we have considered only final output of the scaling, so we have not mentioned 4-20mA scaling in the logic.
Result
siemens plc totalizer
Author: Bhavesh
  • Process Interlocks and Trips
  • Motor Speed Control using VFD
  • D Flip Flop PLC Ladder Logic
  • PLC Oil and Water Separation
  • Conditional Control Logic using PLC
Difference between DCS & PLC Systems
Communicating Delta PLC Software to Simulator
Types of Interrupt OB in Siemens Tia Portal
5 Comments
  • Hồ Hoàng Phi says:
    September 6, 2019 at 7:20 am
    hi admin, I0.0 receives the signal from the flow meter. so how to get the signal of I0.0 to MD10. I don’t understand that place
    • clo says:
      December 16, 2024 at 8:03 pm
      I0.0 goes through analogue scaling that is into norm x and scale x, the output of scale x is md10.
      or you can give I0.0 to md10 through analogue input mapping using move function
  • Reda says:
    May 13, 2023 at 8:17 pm
    Hi, i want to inform you that i tested this program but after period of time there is a difference between the total in flowmeter and in the program.
    Can we solve this issue by taking pulse signal as input and use in the program in place of 1s pulse ?
    • John says:
      October 19, 2023 at 6:20 pm
      Hi Reda, the flowmeter is more accurate. The example given is a rough PLC totaliser using a slow sample interval of 1 sec so it’s gonna have high error.
      Yes taking pulses from the flowmeter will make it as accurate as the flowmeter itself, but you may need a high speed counter on your PLC to accommodate it if the frequency of pulses is fast.
  • Oralkhan says:
    March 5, 2024 at 9:13 pm
    Hello! Thank you for your topic. I have a question, I use Mitsubishi FX3U PLC and FX3u-4AD analog input module. PLC has 30 Ms scan cycle time and flow meter make request each second, but PLC make request every 30 Ms, how can I solve this problem?
208kSubscribersSubscribe
Recent Comments
Related Articles
Create an Application in HMI using Tia Portal
LIFO Instruction in Allen Bradley PLC Programming
LIFO Instruction in PLC
Cybersecurity in PLC
Studio 5000 Programming Three Motors with Fixed Priorities
Studio 5000: Programming Three Motors with Fixed Priorities
PLC Program Paint Spraying
PLC Program for Paint Spraying
How-to do Security of SCADA Systems
How-to do Security of SCADA Systems?
PLC Program for Star Delta Starter using Functional Block Diagram
PLC Documents
PLC System Documentation
More Articles
A Question on Steam Drum Water Level Measurement
Comparator used in Siemens S7-1200 PLC.
Siemens PLC Comparator Logic
FF Function block location
Foundation Fieldbus Logics
Thermal Mass Flowmeter Principle
Thermal Mass Flow Meter – Principle, Advantages, Applications
Learn SCL programming from scratch
How to Start Writing SCL Language in Siemens Tia Portal?
Synchronous Generator Salient Pole vs Non Salient Pole
Automotive Rail Rapid Transit
Instrumentation documents
