Reading: PLC Program for Controlling a Water Pump with 3 Power Sources
Inst Tools > Blog > PLC Tutorials > PLC Program for Controlling a Water Pump with 3 Power Sources
Example of a PLC Program Controlling a Water Pump with 3 different power sources using Interlock function in CX-Programmer and CX-Designer.
Last updated: July 1, 2024 4:05 pm
7 Min Read
Controlling a Water Pump with 3 Power SourcesI/O ListPLC Program for Controlling a Water PumpSimulation of the PLC Program
This article discusses the PLC application of “Latching” and “Interlock” concepts which can be used as a learning medium for students or beginner PLC programmers.
How The PLC Program Works?
The PLC program uses 4 buttons, the START_SYSTEM (0.00) button is used to Turn ON the system, STOP_SYSTEM (0.01) button is used to Turn OFF the system.
The START_SOURCE1 (0.02) button is used to Turn ON the Water Pump using Source 1, START_SOURCE2 (0.03) button is used to Turn ON the Water Pump using Source 2, START_SOURCE3 (0.04) button is used to Turn ON the Water Pump using Source 3.
The system will Run when START_SYSTEM (0.00) button is Pressed and results in the memory bit SYSTEM_ON (W0.03) being ON. Because it uses Latching, the memory bit SYSTEM_ON (W0.03) remains ON even though the START_SYSTEM (0.00) button has been released. The memory bit SYSTEM_ON (W0.03) will be OFF if STOP_SYSTEM (0.01) button is Pressed.
This system uses the concept of “Latching” and “Interlock”, so that the memory bits SOURCE1 (W0.00), SOURCE2 (W0.01), and SOURCE3 (W0.02) cannot be ON at the same time, they can only be ON alternately.  When one of the memory bits SOURCE1 (W0.00), SOURCE2 (W0.01), and SOURCE3 (W0.02) is Active then the WATER_PUMP (100.00) Output becomes ON.
I/O List
Addressing Input, Output, TIM, Bit Memory, and Word Memory details are as follows.
CommentInput (I)Output(Q)Memory Bits
START_SYSTEM0.00
STOP_SYSTEM0.01
START_SOURCE10.02
START_SOURCE20.03
START_SOURCE30.04
WATER_PUMP 100.00
SOURCE1  W0.00
SOURCE2  W0.01
SOURCE3  W0.02
SYSTEM_ON  W0.03
RUNG 0 (START SYSTEM)
In this Rung, when START_SYSTEM (0.00) button is pressed, the memory bit SYSTEM_ON (W0.03) changes to the ON state. Because it uses latching, the memory bit SYSTEM_ON (W0.03) remains ON even though the START_SYSTEM (0.00) button has been Released.
The memory bit SYSTEM_ON (W0.03) will be OFF if the STOP_SYSTEM (0.01) button is Pressed.
Control of water pump using plc
RUNG 1 (SOURCE 1)
When Normally Open contact of the memory bit SYSTEM_ON (W0.03) is in the HIGH state and START_SOURCE1 (0.02) button is pressed, then the memory bit SOURCE1 (W0.00) changes to the ON state.
Because it uses latching, the memory bit SOURCE1 (W0.00) remains ON even though the START_SOURCE1 (0.02) button has been Released. The memory bit SOURCE1 (W0.00) will be OFF when the Normally Close contact of START_SOURCE2 (0.03) button or START_SOURCE3 (0.04) button is Pressed.
RUNG 2 (SOURCE 2)
When Normally Open contact of the memory bit SYSTEM_ON (W0.03) is in the HIGH state and START_SOURCE2 (0.03) button is pressed, then the memory bit SOURCE2 (W0.01) changes to the ON state.
Because it uses latching, the memory bit SOURCE2 (W0.01) remains ON even though the START_SOURCE2 (0.03) button has been Released. The memory bit SOURCE2 (W0.01) will be OFF when the Normally Close contact of START_SOURCE1 (0.02) button or START_SOURCE3 (0.04) button is Pressed.
Water Pumping System with PLC
RUNG 3 (SOURCE 3)
When Normally Open contact of the memory bit SYSTEM_ON (W0.03) is in the HIGH state and the START_SOURCE3 (0.04) button is pressed, then the memory bit SOURCE3 (W0.02) changes to the ON state.
Because it uses latching, the memory bit SOURCE3 (W0.02) remains ON even though the START_SOURCE3 (0.04) button has been Released. The memory bit SOURCE3 (W0.02) will be OFF when the Normally Close contact of START_SOURCE1 (0.02) button or START_SOURCE2 (0.03) button is Pressed.
RUNG 3 (WATER PUMP OUTPUT)
In this Rung, when one of the Normally Open contacts of the memory bits SOURCE1 (W0.00), SOURCE2 (W0.01), and SOURCE3 (W0.02) in the HIGH state then the Output WATER_PUMP(100.00) becomes ON.
HMI for Water Pump
The above image is the HMI (Human Machine Interface) design of the “PLC Program Controlling 1 Water Pump With 3 Different Power Sources using the Interlock Function”.
Water Pump Control with Three Power Sources
The image above shows, that when START_SYSTEM (0.00) button is pressed, then the SYSTEM_ON (W0.03) indicator light turns on.
PLC indicator light turns on
It can be seen in the picture above when the START_SOURCE1 (0.02) button is pressed, then the SOURCE1 (W0.00) and WATER_PUMP (100.00) indicator lights Turn ON.
PLC SCADA Water Pump
It can be seen in the picture above when the START_SOURCE2 (0.03) button is pressed, then the SOURCE2 (W0.01) and WATER_PUMP (100.00) indicator lights are turned on.
PLC HMI Pump
It can be seen in the picture above when the START_SOURCE3 (0.04) button is pressed, then the SOURCE3 (W0.02) and WATER_PUMP (100.00) indicator lights are turned ON.
PLC Pump Status Indicator
The image above shows, when the STOP_SYTEM (0.01) button is pressed and the system turns off.
  • PLC Programming for Level Control of Two Tanks
  • Controlling the PLC Output using Push Buttons
  • Light ON OFF Control using PLC Programming
  • PLC Sequence of Conveyors with Interlock Function
  • Increment & Decrement Instructions in OMRON PLC
What is Rewire Tool in Simatic Manager?
Allen Bradley Powerflex VFD
Speed Control of Pneumatic Cylinder (Explanation with PLC)
Automatic Highway Lights Program using RTC in Omron PLC
PLC Handbook
Real-time PLC Projects – Industrial Automation
How to Design an Effective HMI? – Human Machine Interface
Free Omron PLC Programming Course in HINDI
Basic Concepts of the Safety Relay
Schneider PLC Example Program for Star-Delta System
PLC Program Example - Signal Lamp Task
PLC Program Examples
PLC Count values higher than 999
Difference Between Static and Temp Memory in Siemens TIA Portal
Best Practices of PLC Wiring
Best Practices of PLC Wiring – Programmable Logic Controller
Flip-Flop PLC Program for Lamps Application
Example of Flip-Flop PLC Program for Lamps Application
Control of Double-acting Pneumatic Cylinder
Redundant Power Supply
How Does Redundant Power Supply Work?
Microprocessors Objective Questions – Set 1
PID-Controller-Selection
PID Controller Selection
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
volumetric flow measurement for liquids versus gases
Standardized Volumetric Flow
Difference Between PLC and RTU
Difference Between PLC and RTU?
Power Electronics MCQ Questions and Answers
Control Valve End Connection
PLC Program using Counters
PLC Counters Program
