Reading: PLC Permissive for Motor Control
Inst Tools > Blog > PLC Tutorials > PLC Permissive for Motor Control
Last updated: March 4, 2021 3:51 pm
PLC Tutorials Practical Questions
2 Comments
2 Min Read
A engineer needs to write a PLC program to control a water pump driven by an electric motor. This water pump will be manually started and stopped by pushbutton switches, and shutdown automatically by any one of several “permissive” switches.
The operating statuses of these switches are listed here:
  • Start pushbutton (normally-open): open when unpressed, closed when pressed
  • Stop pushbutton (normally-open): open when unpressed, closed when pressed
  • Low water level (normally-closed): closed when level is low, open when level is adequate
  • Low oil pressure (normally-open): open when pressure is low, closed when pressure is adequate
  • High vibration (normally-closed): closed when still, open when vibrating
  • Water leak detector (normally-open): open when dry, closed when wet (leak detected)
PLC Permissive Motor Control
The engineer’s first attempt is shown here, but it contains a serious error. Identify and correct this error:
PLC program pushbutton switches
Answer :
The Stop_PB contact instruction should be drawn as normally-closed rather than normally-open as shown in the engineer’s first draft of the PLC program.
The program is designed to shutdown the motor when that pushbutton is pressed (i.e. the Stop_PB contact instruction becomes uncolored (i.e. fails to “conduct” virtual power).
We have been told that the real-world Stop pushbutton switch is NO, which means its contact closes when pressed.
This means pressing the Stop pushbutton causes that bit to be 1, which necessitates an NC contact instruction so that it will un-color under that condition.
PLC Counters Program
Contacts and Coils in PLC
PLC Electric Motor Interlocks
Motor Control Circuit
PLC Pump Permissive
Determine the Problems with Level Transmitter and Gauge
Why Use a Current Loop?
Sketch a Ladder Diagram for PLC to Energize the Lamp
Structured Text PLC Example for Motor Interlocking and Control
PLC Compressor Control Ladder Logic
2 Comments
  • Bruce says:
    April 19, 2018 at 7:09 am
    Why would you show an example of stop being NO and not fail safe. You would never see it wired this way in an individual setting?
  • DIMITRIOS ADAMOS says:
    June 21, 2018 at 8:19 pm
    Hi , i believe that there are two ways that you can program a stop button . this is one way that you mention
    and the other way ,you have stop button NC (hardwired) and you program it as NO in the plc ,fail safe .so there is no wrong in this i believe .great work
Types of PLC Memory
Power Supply Sizing for Industrial Automation Systems
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
Free SCADA Training Course
Pause the Timer PLC Ladder Logic
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
Motor Speed Control using VFD and PLC Programming
Function Block Programming in Studio 5000
Introduction to Functional Block Diagram in Studio 5000
Calculate Incident Power in Radar Level Measurement
Why Are Charcoal and Salt Added to an Earthing Pit
Why Are Charcoal and Salt Added to an Earthing Pit?
Simatic Prosave HMI
How to Backup and Restore from Simatic Prosave HMI?
PLC Load Memory
What is Resources Tab in the Siemens PLC?
Flow Transmitter Readings mismatch with DCS
Omron PLC programs
PC-Based Motion Controller
Various Types of Delta PLC used in Industrial Automation
SMART Transmitters Block Diagram
Smart Transmitters LRV & URV
Schematic Diagram
Schematic Diagram
how-to-avoid-bad-grounds
How to Avoid Bad Grounds ?
Gas Detectors Location Installation
Gas Detectors Installation Techniques
RSLogix5000 PLC Program Backup procedure
Simplified Induction Motor - Cross Section
Siemens Standard Drives Application Handbook (PDF)
Types of Flow Meters MCQ - Instrumentation and Control
Types of Flow Meters MCQ – Instrumentation and Control
Radiometric level Principle
Radiometric level measurement Working Principle
