Reading: #8 PLC Best Practices – Validate HMI Input Variables at PLC Level
Inst Tools > Blog > PLC Tutorials > #8 PLC Best Practices – Validate HMI Input Variables at PLC Level
HMI access to PLC variables can be restricted to a valid operational value range but further cross-checks in the PLC should be added.
Last updated: September 21, 2021 2:18 pm
HMI access to PLC variables can (and should) be restricted to a valid operational value range at the HMI, but further cross-checks in the PLC should be added to prevent, or alert on, values outside of the acceptable ranges which are programmed into the HMI.
Validate HMI Input Variables at PLC LevelExample 1Example 2Example 3
Security ObjectiveTarget Group
The integrity of PLC variablesProduct Supplier Integration / Maintenance Service Provider
Input validation could include out-of-bounds checks for valid operational values as well as valid values in terms of data types that are relative to the process.
If a PLC variable receives a value that is out-of-bounds, provide PLC logic to either input a default value to that variable which does not negatively affect the process, and can be used as a flag for alerts, or input the last correct value to that value and log the event for further analysis.
HMI screen for operator
Example 1
An operation requires a user to input a value on an HMI for valve pressure. Valid ranges for this operation are 0-100, and the user’s input is passed from the user input function on the HMI to the V1 variable in the PLC.
In this case,
  1. HMI input to variable V1 has a restricted range of 0-100 (dec.) programmed into the HMI.
2. The PLC has a cross-check logic that states:
IF V1 < 0 OR IF V1 > 100, SET V1 = 0.
This provides a positive response of a presumably safe value to an invalid input to that variable.
Example 2
An operation requires user input for measurement thresholds to a variable that should always be within an INT2 data range. The user input is passed from the HMI into the V2 variable in the PLC, which is a 16-bit data register.
  1. HMI input to variable V2 has a restricted range of -32768 to 32767 (dec.) programmed into the HMI.
2. The PLC has data-type cross-check logic that monitors the overflow variable (V3), which exists just after V2 in the PLC’s memory structure:
IF V2 = -32768 OR IF V2 = 32767 AND V3 != 0,
SET V2 = 0 AND SET V3 = 0 AND SET DataTypeOverflowAlarm = TRUE.
Example 3
Scale PV (Process Value), SP (SetPoint), and CV (Control Variable) for PID (Proportional, Integral, Derivative controller) to consistent or raw units to eliminate scaling errors causing control problems.
Incorrect scaling might lead to inadvertent abuse cases.
Why?
Beneficial for…?Why?
                      Security1. While HMIs typically provide some sort of input validation, a malicious actor can craft or replay modified packets to send arbitrary values to the variables in the PLC which are open to outside influence (open to values passed from an HMI, for example).
2. PLC protocols are typically marketed as “open” protocols and published to the general public, so creating malware that utilizes “open” protocol information can be trivial to develop.
PLC variable mapping can typically occur through traffic analysis during the reconnaissance phases of an attack, thus providing the intruder with the necessary information to craft malicious traffic to the target and thereby manipulate a process with unauthorized tools.
Cross-checking values passed into the PLC before implementing that data into the process ensures valid data ranges and mitigates an invalid value in those memory locations by forcibly setting safe ranges when a value is detected as out-of-bounds during the course of the PLC scan.
Reliability/
Maintenance/
References
Standard/frameworkMapping
MITRE ATT&CK for ICSTactic:  TA010 – Impair Process Control
Technique:  T0836 – Modify Parameter
  ISA 62443-3-3SR 3.5: Input Validation
SR 3.6: Deterministic Output
  ISA 62443-4-2CR 3.5: Input Validation
CR 3.6: Deterministic Output
  ISA 62443-4-1SI-2: Secure coding standards
SVV-1: Security requirements testing
MITRE CWECWE-1320: Improper Protection for Out of Bounds Signal Level Alerts
Source: PLC Security
How to use Converters in PLC
How to do Simulation in Schneider PLC?
What is the DDE Protocol?
Difference between Signal Cables and Control Cables
How to Select the Right Encoder for Your Machine?
Allen Bradley PLC Interview Questions and Answers
PLC Program for Password Management using Structured Text
PLC Timer Instructions
XG5000 Example of Simple Conveyor Control PLC Program
Connecting Faceplate to PLC Project – HMI Tutorial
How to Install GSD File in Step 7 PLC using Simatic Manager?
Flexible Input Output Modules
Features of Scada Which are Must in an IoT System
Site Commissioning Steps for PLC Programmers
How to troubleshoot the PLC Hardware faults
Standard Colors in PLC Automation Systems
Industrial Gas Detection Systems
PLC based Gas Detection System using Ladder Logic Project
PLC Valve Control Example
Create a Function (FC) for a Valve Logic in Siemens PLC
Ladder Logic Counters Instruction
Up Counter PLC Program
Do’s and Don'ts in PLC
Do’s and Don’ts in PLC
pH Measurement Questions & Answers
Step-by-step import export in FactoryTalk View
FactoryTalk View Studio – Import and Export Tutorial
Diode-Transistor Logic (DTL) Objective Questions
Digital Electronics MCQ
Logic Gates and Networks Multiple Choice Questions
Pre-Engineering Design Documents
Clamp Meter
What is a Clamp Meter?
Gas Detection Definitions
Standard Gas Detection Definitions
