Reading: PLC Automatic Pedal Switch for Speed Control
Inst Tools > Blog > PLC Tutorials > PLC Automatic Pedal Switch for Speed Control
Last updated: March 4, 2021 3:51 pm
3 Min Read
We need to use pedal switch control logic at machine work shop for speed control of motor. Write the PLC program for this application using ladder diagram.
Pedal Switch for Speed ControlPLC SolutionList of Inputs/OutputsPLC Logic Automatic pedal switch for Speed ControlLadder Logic Description
PLC Solution
Here we want to operate machine in two different speeds. For this control, we are using pedal switch so we can control the speed of motor.
For normal operation we need to operate machine in speed 1 condition. And for higher operation we need to operate machine in speed 2.
Here we have considered two different speeds of motor. so, by pressing pedal switch first time motor can be started at speed 1. When user will press pedal switch again motor will run at speed 2.
Motor can be stopped by pressing E stop button.
List of Inputs
  • I1 : Pedal switch
  • I2 : E stop button
List of Outputs
  • Q1 : Speed 1
  • Q2 : Speed 2
PLC Pedal Switch Logic for Speed Control
PLC Switch Ladder Diagram
Network 1 :-
In this network, we have used pulse relay instruction for speed 1 output.
Network 2 :-
When pedal switch is triggered first time, it will operate on delay timer.
Network 3 :-
After some 2s delay motor will run at first speed.
Network 4 :-
In this network we have used another pulse relay instruction for the speed 2 output.
Network 5 :-
When pedal switch is triggered second time, it will operate on delay timer for the speed 2.
Network 6 :-
When timer is completed, motor will run at speed 2.
Note:- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple automatic pedal switch for speed selection using PLC, we can use this concept in other examples also.
All parameters and graphical representations considered in this example are for explanation purpose only, parameters or representation may be different in actual applications. Also all interlocks are not considered in the application.
Author : Bhavesh
Variable Frequency Drive (VFD)
Types of AC and DC Motors
Stepper Motor Principle
Electrical Drives Questions
PLC Pump Control Video
Why is 24 Volts Commonly used in PLC Systems?
What is Relay Logic ?
Pause the Timer PLC Ladder Logic
PLC Programming Example on LED Control
Data Types in PLC – Bit, Byte, Integer, Real, String
PLC Programming Example with Pushbutton and Motor
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
How to do Force in GE PLC Proficy Machine Edition?
PLC Program to control level of parallel tanks
Parallel Tanks Level Control using PLC Ladder Diagram Tutorial
Conveyor Sorting Omron PLC Programming
CX-Programmer Products Sorting & Counting – Omron PLC
How to Train Your Maintenance Team for Industrial Automation Systems
Automatic Car Door Simulation
Automatic Door Operation PLC Programming and Simulation
Thermal Dispersion Flow Switch Working Principle
Single Phase Earth Return System
Single Phase Earth Return System Advantages & Disadvantages
Power Electronics Diode Circuits Questions and Answers
Why Measure Level
Omron PLC Example
Design a Water Pump PLC Program using CX-Programmer
Measurement of Resistance Objective Questions
