Reading: Pitot Tube Flowmeter Calculations
Inst Tools > Blog > Practical Questions > Pitot Tube Flowmeter Calculations
Last updated: June 6, 2018 9:51 am
Practical Questions
1 Min Read
A Pitot tube measuring the flow of glycerin (78.6 lb/ft3 ) produces a differential pressure of 35 inches W.C. at a mass flow rate of 450 pounds per minute.
Calculate the differential pressure produced by this same Pitot tube at a flow rate of 310 lb/min.
Calculate the mass flow rate at a differential pressure of 12.6 ”WC.
If the glycerin density happens to change from 78.6 lb/ft3 to 75.1 lb/ft3 , calculate the mass flow rate at a differential pressure of 24.8 ”WC.
Answer :
Differential pressure produced by this same Pitot tube at a flow rate of 310 lb/min = 16.61 ”WC
Mass flow rate at a differential pressure of 12.6 ”WC = 270 lb/min
Mass flow rate at DP of 24.8 ”WC, assuming density of 75.1 lb/ft3 = 370.3 lb/min
More DP Transmitter Questions
Flow Transmitter Readings mismatch with DCS
DP Transmitter Calibration Errors
DP Transmitter Error Calculations
Smart DP Transmitter Flow Meter Calculations
Differential Pressure Transmitter with 5 Way Manifold Valve
Draw the appropriate Pressure Switch Symbol ?
Calculation of Hydrostatic Pressure
Programmable Logic Controller (PLC) Questions and Answers – 8
Pressure Transmitter using Potentiometer and Diaphragm
Calculate Temperature of RTD
Differential Pressure Measurement across Baghouse
A Question on Steam Drum Water Level Measurement
Investigate High Level Alarm of Distillation Process
Problem on Solar Hot Air Collector and Variable Speed Fan
Determine the Temperature of 3 Wire RTD
Galileo Thermometer
Determine Resistance value of Resistors
valve control system
Solenoid Valves Practical Problems
Questions on Pneumatic Control Loop
Question on Remote Seal with Capillary Tubing Transmitter
displacer level transmitter cylindrical weighs
Displacer Level Transmitter 5-point Calibration
Paint Mixing System
Paint Mixing System
two chemical streams are mixed together
Practical Process Control System Questions & Answers – 12
Calculate Hydrostatic Pressure of a vertical column of Acetic Acid
Two Differential Pressure Transmitters
Pressure Level Transmitter Problems
IR Radio Sensors Objective Questions
Distributed Network Protocol Communication
DNP3 Communication Protocol Overview
Basics of Thyristor
Basics of Thyristor
NIST Traceability
NIST Traceability
P&ID Guidelines for Storage Tanks
Pressure Transmitters Purged impulse lines - 2
magnetic-flow-meter-earthing
Speed Control of Pneumatic Cylinder (Explanation with PLC)
