Reading: PID in Siemens TIA Portal
Inst Tools > Blog > PLC Tutorials > PID in Siemens TIA Portal
Last updated: March 4, 2021 11:58 am
In this article, I will discuss how to use PID instruction using Siemens TIA Portal.
PID plays a huge role in process industries where it is used to control the process variable.
I will use CPU-1500 to explain to you about the PID block. Here, we want to run the PID block, but we can not run this in the main OB as the PID block needs to update at a specified time interval.
To execute a specific time interval, we have to use cyclic interrupt OB.
Let’s understand how the PID block in the TIA portal works. Follow the below steps to add cyclic OB.
Step 1:
Open TIA PORTAL. Create a new project. Add a new OB.
After adding the main OB, do follow the below step as shown in the window.
PID Block in Siemens TIA Portal
Step 2:
Click on “Add new block”.
Click on “organization block” then select “cyclic interrupt”.
Here, it adds the cycle time. Normally we use a cycle time of a 1 second. Hit ok to proceed.
Cyclic interrupt in Tia Portal
Step 3:
Now add PID block in cyclic OB as shown in the below window.
Step 4:
Clicking on a PID compact will open up a new window.
This pop up opens because PID requires storage location to keep the data that it does in the form of DB (Data block). Hit “ok” to proceed.
PLC PID Control
Step 5:
Here, in the PID block on the top right side, you can see two different icons.
One icon on the left-side holds the configuration window and another icon on the right-side holds information of the commissioning window.
PID configuration window
Step 6:
As you can see in the below window, clicking on the configuration icon will open up a new window.
In this window, you can add all the information related to scaling, controller type, input, and output parameter.
PID parameters
Step 7:
In the “PID Parameter” you can add gain for the PID parameter.
In the tuning rule, you can set the controller structure.
PID Advanced Settings
Step 8:
In the below window you can see a commissioning window.
In this window, you can monitor the graph. You can see the process variable and response time of the manipulated variable to calculate dead time.
From the calculation, you can tune the process easily and efficiently.
PID commissioning window
Step 9:
As you can see in the large red rectangle, you can add the parameter.
On the top left side, you can monitor your process and fine-tune it.
PID Scaling
Author: Suhel Patel
  • RSLogix 500 PID Instruction
  • Allen Bradley Powerflex VFD
  • PID Tuning Parameters
  • PID Controller Action
  • Namur Digital Input Card
High-end Programmable Logic Controller – Schneider PLC
Free Allen Bradley PLC Ladder Logic Training Course
Single-acting Cylinder OR Logic Operation (PLC and Sensors)
What is a Floating License? – Automation Software Systems
3 Phase Motor Control using PLC Ladder Logic
  • AngryGuy says:
    January 26, 2021 at 2:36 am
    WHY YOU BLOCK PAGE ZOOM !!!
PLC Multiple Outputs Configuration
Move Instruction in Tia Portal
How to use Sub Routines with Allen Bradley PLC
Difference Between Industrial Computer (IPC) and Normal Computer (PC)
Timers in Codesys – Timer ON, Timer OFF, Pulse Timer
SCADA for Substation Automation
PLC Ladder Logic Example
Download Free Robotics Software
Step by Step Guidelines to Download Free Robotics Software
Communication between Factory IO and Siemens Tia Portal
Components of PLC
What is a Line Choke or Reactor in a VFD
What is a Line Choke or Reactor in a VFD?
Scaling in PLC
PLC Ladder Logic for Sensor Scaling with Offset
4-20mA Loop Power Supply Questions
Edge Detection in PLC
Edge Detection in PLC Programming
MCQ on Measurement and Instrumentation
250+ Electronic Measurements and Instrumentation MCQ Questions
Industrial PLC Communication Network
Basics of Industrial Communication Networks
Averaging Pitot Tube Principle
What is a Torbar? – Averaging Pitot Tubes
Electrical & Instrumentation QA QC Interview Questions
100 Electrical & Instrumentation QA QC Interview Questions
Process Shutdown
Difference between Process shutdown and Emergency Shutdown
Single-Bed Demineralizer
Demineralizers
Single-Acting Air Compressor Cylinder
Reciprocating Compressors
Process Safety and Instrumentation
