Reading: Pause the Timer PLC Ladder Logic
Inst Tools > Blog > PLC Tutorials > Pause the Timer PLC Ladder Logic
Write a PLC ladder logic so that a timer starts when a selector switch is ON and timer pause when the selection is OFF.
Last updated: March 4, 2021 10:57 am
2 Min Read
Write a PLC program so that when a selector switch is ON,  the timer starts to count for 5 seconds and switch motor to ON, when the selector switch is OFF before the 5 seconds the timer stops counting and when the selector switch is ON again then the timer starts to count from the last value the timer stopped counting. And so on.
 Inputs & OutputsPause the Timer LogicPLC Ladder Logic
Note: the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
 Inputs & Outputs
I0.0: selector
Q0.0: Motor
PLC Ladder Logic
Network 01
Convert instruction to convert from the integer format to BCD format.
Network 02
When the selector is ON, the timer start to count from the preset value stored in MW2 and stores the remaining time in MW4 while the motor is ON.
When the selector is OFF before 5 seconds elapsed, the motor stops and the negative edge detector energizes the move instruction to move the remaining time to the initial time value MW0.
So when the selector is ON again the timer starts to count from the preset value which is remaining time from the last run.
Network 03
When the remaining time is equal to zero, 5 seconds is moved to MW0 to start counting for the next time.
Author: Karim Ali Anwar
  • PLC Count 999 Plus
  • LIFO Instruction
  • PLC Programming Example
  • Master Control Reset
  • Drink Dispenser System
Steps to Configure TCP/IP Communication in Siemens S7-1200 PLC
ESG in Industrial PLC Automation Systems
  • Mohammed SaeedDowelbite says:
    January 7, 2022 at 3:58 am
    thank you very much for simple methods in explaining plc
PLC Program for Continuous Filling Operation
How to Use ModScan Software for Testing Modbus Communication?
Quiz: Identifying I/O Examples in PLC Systems
Web-based SCADA HMI Software
Conveyor Speed Logic using Structured Text in PLC
Comparator in PLC Programming
Interposing Relay Panel (IRP)
PLC Question Bank
PLC Question Bank
Automatic Lamp Control in Storage Facility
Human Machine Interface
What is Human Machine Interface (HMI) ?
Mixing Process with Valve Control
PLC Mixing Process with Adjustable Timer and Valve Control
Networked SCADA Architecture
How to Troubleshoot Control Valve - Problems and Solutions
How to Troubleshoot Control Valve? – Problems and Solutions
Retro-Reflective Sensor
Mechanical Torsion Meter Principle
Water Vapor in Instrument Air Lines
How to Minimize Water Vapor in Instrument Air Lines?
Loop Diagram
Advantages of Three Phase System Compared to Single Phase System
Aluminum CNC Machining Complete Guide
Aluminum CNC Machining: A Complete Guide You Cannot Miss
Split-Range, Auto-Selector Ratio, And Cascade Systems
Split-Range, Auto-Selector, Ratio & Cascade Systems
