Reading: On/off Control Theory
Inst Tools > Blog > Control Systems > On/off Control Theory
Last updated: November 10, 2019 2:23 pm
Control Systems
Once while working as an instrument technician in an aluminum foundry, a mechanic asked me what it was that I did.
I began to explain my job, which was essentially to calibrate, maintain, troubleshoot, document, and modify (as needed) all automatic control systems in the facility.
The mechanic seemed puzzled as I explained the task of “tuning” loop controllers, especially those controllers used to maintain the temperature of large, gas-fired industrial furnaces holding many tons of molten metal. “Why does a controller have to be ‘tuned’?” he asked.
“All a controller does is turn the burner on when the metal’s too cold, and turn it off when it becomes too hot!”
In its most basic form, the mechanic’s/engineers’s assessment of the control system was correct: to turn the burner on when the process variable (molten metal temperature) drops below setpoint, and turn it off when it rises above setpoint.
However, the actual algorithm is much more complex than that, finely adjusting the burner intensity according to the amount of error between PV and SP, the amount of time the error has accumulated, and the rate-of-change of the error over time.
In his casual observation of the furnace controllers, though, he had noticed nothing more than the full-on/full-off action of the controller.
The technical term for a control algorithm that merely checks for the process variable exceeding or falling below setpoint is on/off control. In colloquial terms, it is known as bang-bang control, since the manipulated variable output of the controller rapidly switches between fully “on” and fully “off” with no intermediate state.
Control systems this crude usually provide very imprecise control of the process variable. Consider our example of the shell-and-tube heat exchanger, if we were to implement simple on/off control :
Note : To be precise, this form of on/off control is known as differential gap because there are two setpoints with a gap in between. While on/off control is possible with a single setpoint (FCE on when below setpoint and off when above), it is usually not practical due to the frequent cycling of the final control element.
ON OFF Control Principle
As you can see, the degree of control is rather poor. The process variable “cycles” between the upper and lower setpoints (USP and LSP) without ever stabilizing at the setpoint, because that would require the steam valve to be position somewhere between fully closed and fully open.
This simple control algorithm may be adequate for temperature control in a house, but not for a sensitive chemical process! Can you imagine what it would be like if an automobile’s cruise control system relied on this algorithm?
Not only is the lack of precision a problem, but the frequent cycling of the final control element may contribute to premature failure due to mechanical wear.
In the heat exchanger scenario, thermal cycling (hot-cold-hot-cold) will cause metal fatigue in the tubes, resulting in a shortened service life.
Furthermore, every excursion of the process variable above setpoint is wasted energy, because the process fluid is being heated to a greater temperature than what is necessary.
Clearly, the only practical answer to this dilemma is a control algorithm able to proportion the final control element rather than just operate it at zero or full effect (the control valve fully closed or fully open). This, in its simplest form, is called proportional control.
Centralized vs Decentralized Automation Systems
What is Alarm Shelving? – Nuisance Alarms, Types, Suppression
Modbus Function Codes and Addresses
PID Controllers with Output High Select Logic
What LIC and FIC Controllers will do?
Cascade Control
What is Adaptive Control?
Layer-2 and Layer-3 Network Switches
Building Management System
What is Interposing Relay in a PLC System ?
Functional Safety Terminology in Industrial Automation
How to Solve Electrical Ground Loop Problems?
What is Electromagnetic Noise Interference?
DeltaV System to Excel
How to Export Data from DeltaV System to Excel
Process Alarms Types
Process Switches and Alarms
On-Off Controller example
ON-OFF Controller Principle
Industrial Automation Mobile Apps
What is Loop Checking
What is Loop Checking?
DCS System Layout and its Different Parts
Grounding Electronic Equipment
Importance of Grounding Electronic Equipment
feedforward control theory
Proportioning Feedforward action
Calibration of Temperature Sensor with Indicator
Difference Between Industrial Computer and Normal Computer
Difference Between Industrial Computer (IPC) and Normal Computer (PC)
mass spectrometer sample system
Mass Spectrometer Working Principle
Cable Bending Radius
What is Cable Bending Radius? – Definition & Calculation
Closed-tank-DP-Level-Transmitter-with-wet-leg-Zero-elevation-Calibration
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
Linear Variable Displacement Transducer (LVDT)
What is LVDT ?
Flow Control Valves
Difference Between a Flow Control & a Needle Valve
DCS Marshalling Cabinet
