Reading: Oval Gear Flow Meters – Principle, Advantages, Animation
Inst Tools > Blog > Animation > Oval Gear Flow Meters – Principle, Advantages, Animation
Oval Gear Flow Meters are a type of positive displacement meter. As liquid flows through the meter, a pair of oval shaped gears are forced to rotate.
Last updated: October 31, 2023 4:22 pm
Animation Flow Measurement
3 Min Read
Oval gear flow meters are a type of positive displacement meter. As liquid flows through the meter, a pair of oval-shaped gears are forced to rotate by the flow of the liquid.
Oval Gear Flow MetersPrinciples of OperationOVAL Gear Flow Meter AdvantagesOVAL Gear Flow Meter LimitationsApplications of OVAL Gear Flow Meters
These gears mesh together & force a finite amount of fluid through the meter.
A sensor or mechanical drive detects the rotation of the gears to determine the displaced volume of liquid. The faster the flow rate, the faster the gears turn.
OVAL GEAR FLOW METERS WORKING ANIMATION
The oval gear flow meter comprises oval-shaped, geared rotors that rotate within a housing of specified geometry.
Fluid differential pressure causes the inter-meshing gears to rotate, trapping a ‘pocket’ of fluid between the gear and the outer housing and subsequently emptying the fluid pocket into the downstream flow. The capillary action of the metered fluid forms a liquid seal.
Each ‘pocket’ holds a precise and known volume of fluid so counting the pocket frequency gives a measurement of the volumetric flow rate. This is typically achieved by embedding magnets in the rotors, which then actuate a reed switch or provide a pulse output as they rotate and thus the flow is measured electronically.
Oval gear Flow Meter Principle
  • Traditional proven flow technology
  • Simple to install
  • No straight pipe runs are required so flow meters can be installed in restricted areas
  • Not suitable for steam or multi-phase fluids
  • Fluid slippage adversely affects accuracy; this varies with flow rate, differential pressure, temperature, viscosity, and clearance
  • Not recommended for low-viscosity fluids, including water or water-like fluids (because of an increase in fluid slippage)
  • Accuracy is adversely affected by bubbles present in fluids
The oval gear flow meter is designed primarily for use with higher-viscosity fluids, which has led to applications such as the flow metering of oils, syrups, and fuels.
  • Ultrasonic Doppler Flow Meter
  • Positive Displacement meters
  • Microwave Flow Sensor Principle
  • DP Flow Transmitter Calculation
  • Metal tube Variable Area Meters
Flare Knockout Drums Working Animation
Equivalent Logic Gates using PLC Ladder Diagrams
Electromagnetic Flow Meters Working Principle
What is a Segmental Wedge Flow Meter?
Orifice Sizing Guidelines and Thumb Rules with Flowchart
Orifice Plate Turndown ratio
What is a Coriolis Flow Meter?
Basics of Orifice Plates
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
Deluge Valve Working Principle
Sight Glass Level Measurement Principle
Potentiometer Working Principle Animation
Flow Meter Characteristics
Dome Valve Working Principle
Vortex Flow Meter Principle
Vortex Flow meter Animation
Pressure Temperature Compensation Flow Measurement
Float level gauge Principle
Float Type Level Indicator Principle
Switch NO or NC Contact
Normally-open and Normally-closed Switch Contacts
Sealed Bellows Temperature Sensors
Bellows Pressure Sensors Working Principle Animation
Flow Meter Calibration Procedure
On-OFF Valve Animation
What is ON/OFF Valve ?
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Programmable Logic Controller Practice Tests
Types of PLC Memory
Types of PLC Memory
Remote Factory Acceptance Test
PLC program for Sorting System by Size Example
PLC Based Product Sorting Machine System – Lift Control
PLC analog input scaling
PLC Analog Input Scaling
Fan Motor Frequent Journal Bearing Failures
Fan Motor Frequent Journal Bearing Failures Posed Plant Outages
Difference Between Single Pair Ethernet and Traditional Ethernet
