Reading: One Shot Rising PLC Example Program
Inst Tools > Blog > PLC Tutorials > One Shot Rising PLC Example Program
Last updated: March 4, 2021 3:45 pm
2 Min Read
Build the ladder logic program to turn ON or OFF the lamp using single push buttons using one shot rising (ONR) instruction.
ONE Shot Rising (OSR) InstructionList of Inputs and OutputsPLC Logic ConditionsOne Shot Rising PLC Program
PLC Push button Instruction
One shot Rising is used to develop a signal/Pulse that is exactly one scan in duration. When a signal is applied to a contact/Push Button, no matter how long the signal stays on, a single pulse of one scan length is generated after the one shot.
One Shot PLC Inputs and Outputs
One Shot PLC Logic Conditions
Program Description
RUNG 0000
Start/Stop Push Button is connected with one shot rising bit with the output memory bit.
RUNG 0001
Previous rung output bit and Lamp output bit are connected in X-OR gate logic to make the condition possible. Interlocking of output bit is used to turn the output ON/OFF in different condition.
Conclusion:
The above explained ladder logic for lamp turn ON/OFF using single push button is for example only. We can use this example program to understand the working of Push Buttons, one shot rising in AB PLC.
Author : Hema Sundaresan
Programmable Logic Controller MCQ
Control Valves PLC Ladder Logic
Different Speed Reference PLC Logic
PLC Motor Start Stop with Jog Function
Drilling Machine Operation using PLC
Basics of Loop Checks
What is Human Machine Interface (HMI) ?
How to Choose a Suitable HMI for Your Application?
ON Delay Timer using PLC
What is Distributed IO? – Decentralized Peripherals in PLC
PLC Power Supply and Operating Voltages
Safety PLC Coding Practices – Programming Recommendations
Different Types of Schneider PLC
Peripheral Inputs and Outputs in Siemens PLC
Control Speed of Induction Motor using Analog Output of PLC
Example of Controlling the PLC Output using Push Buttons
0 to 10 mA Current Loop
What is Live Zero in 4-20 mA Current Loop?
Convert Raw Counts to Engineering Units
Raw Counts to Engineering Units : Conversion Formula
Studio 5000 Tutorial PLC Programming for Digital Alarms
Studio 5000 Tutorial: PLC Programming for Digital Alarms
Profibus DP Master
DP Master System Configuration in PLC
What is a Tag in SCADA
What is a Tag? Types of Tags in SCADA
Interlock Philosophy
Types of Interlocks
What is an RTU - Remote Terminal Unit
What is an RTU? – Remote Terminal Unit
Components of SCADA
Components of SCADA
Product Packaging Automation
Why Does Product Packaging Matter in Retailing?
Mitsubishi PLC Timers
Mitsubishi PLC Timers with Ladder Diagram
Classification of Weighing Balance
Classification of Weighing Balance and Weight
What is a Dosing Pump? - Types, Advantages, Applications
What is a Dosing Pump? – Types, Advantages, Applications
Proximity Switch Working Animation
Actuators Questions and Answers
Industrial Networking Interview Questions
Industrial Networking and Wireless Interview Questions
Electrical and Instrument Engineers Job Profile
Instrumentation and Electrical Teams Interactions (Detail Design Engineering)
