Learn how to program an OMRON PLC for a car parking system application for gate open and close operations based on sensor inputs.
Car Parking System Application
Car parking systems generally have 2 Gates, namely the Gate to enter the parking area and the Gate to exit the parking area. The Gate will OPEN/UP when it detects a car going through it and it will again CLOSE/DOWN after the car passes through the Gate. The number of cars entering and exiting the parking area will be counted.
PLC Logic
This Car Parking System program has 3 main buttons, the START_SYSTEM (0.00) button is used to turn ON the system, the STOP_SYSTEM (0.01) button is used to turn OFF the system, and the RESET_COUNTER (0.02) button is used to Reset the Counter to Zero “0”.
Each Gate has 4 Sensors, for example on ‘Gate IN’ the SENS_CAR_IN1 (0.03) Sensor functions to detect an incoming car, when the SENS_CAR_IN1 (0.03) Sensor is Active it will Activate the GATE_IN_UP Output (100.00) so that the Gate opens/rises. The gate will Stop opening/rising when the LS_GATE_IN_UP Sensor (0.07) is Active, the LS_GATE_IN_UP Sensor (0.07) functions as a limiter for the highest point of the Gate.
After the car passes the gate, the SENS_CAR_IN2 sensor (0.04) will be Active for a moment and Activate the GATE_IN_DOWN output (100.01). The Gate closes/descends again and will Stop descending when the LS_GATE_IN_DOWN Sensor (0.08) is Active.
The LS_GATE_IN_DOWN (0.08) sensor functions as a limiter for the lowest point of the Gate. COUNTER (D0) will count incoming cars (+1) when the SENS_CAR_IN1 Sensor (0.03) is Active. ‘Gate OUT’ has the same working system as ‘Gate IN’, the difference is that when a car is detected leaving, the data from COUNTER (D0) will decrease (-1). Data from COUNTER (D0) will decrease when LS_GATE_OUT_DOWN (0.10) is Active.
This program has an Alarm function, when there is a problem with the Gate Electric Motor then the TRIG_ALARM_IN (1.00) or TRIG_ALARM_OUT (1.01) input is Active so that the GATE_IN_ALARM (100.04) or GATE_OUT_ALARM (100.05) output will be Active.
Inputs and Outputs
Addressing Input, Output, TIM, Bit Memory, and Word Memory details are as follows.
| Comment | Input (I) | Output(Q) | Word Memory | Memory Bits |
| START_SYSTEM | 0.00 | |||
| STOP_SYSTEM | 0.01 | |||
| RESET_COUNTER | 0.02 | |||
| SENS_CAR_IN1 | 0.03 | |||
| SENS_CAR_IN2 | 0.04 | |||
| SENS_CAR_OUT1 | 0.05 | |||
| SENS_CAR_OUT2 | 0.06 | |||
| LS_GATE_IN_UP | 0.07 | |||
| LS_GATE_IN_DOWN | 0.08 | |||
| LS_GATE_OUT_UP | 0.09 | |||
| LS_GATE_OUT_DOWN | 0.10 | |||
| TRIG_ALARM_IN | 1.00 | |||
| TRIG_ALARM_OUT | 1.01 | |||
| COUNTER | D0 | |||
| IR_SYSTEM | W0.00 | |||
| IR_GATE_IN_UP | W0.01 | |||
| IR_GATE_IN_DOWN | W0.02 | |||
| IR_GATE_OUT_UP | W0.03 | |||
| IR_GATE_OUT_DOWN | W0.04 | |||
| IR_ALARM_GATE_IN | W0.05 | |||
| IR_ALARM_GATE_OUT | W0.06 | |||
| GATE_IN_UP | 100.00 | |||
| GATE_IN_DOWN | 100.01 | |||
| GATE_OUT_UP | 100.02 | |||
| GATE_OUT_DOWN | 100.03 | |||
| GATE_IN_ALARM | 100.04 | |||
| GATE_OUT_ALARM | 100.05 |
OMRON PLC Programming
RUNG 0 (START SYSTEM RUNG)
This Rung functions to Activate and Deactivate the entire system. When the START_SYSTEM (0.00) button is pressed then Coil IR_SYSTEM (W0.00) is Active.
Because of the latching function of the coil IR_SYSTEM (W0.00) then even if the START_SYSTEM (0.00) button is released, the system will remain Active. The IR_SYSTEM (W0.00) Coil will only switch OFF when the STOP_SYSTEM (0.01) contact is Active.
RUNG 1 (COUNT(+))
This Rung serves as an up-counter for cars entering the parking area. When the IR_SYSTEM (W0.00) and SENS_CAR_IN1 (0.03) Inputs are ON, the COUNTER (D0) will increase by +1 using the “@++”/Binary Increment instruction.
RUNG 2 (COUNT(-))
This Rung serves as a down counter for the cars leaving the parking area. When the IR_SYSTEM (W0.00) and SENS_CAR_OUT1 (0.05) are Active then the COUNTER (D0) will decrease by -1 using the instruction “@–”/Binary Decrement.
RUNG 3 (RESET COUNTER)
This rung has a function to Reset data in the COUNTER (D0). When the IR_SYSTEM (W0.00) and the RESET_COUNTER (0.02) are Active, the COUNTER (D0) will become zero ‘0’ because the MOV instruction is used to move the value ‘0’ to the memory address Word COUNTER (D0).
RUNG 4 (GATE IN UP SYSTEM)
Rung 4 has a function to open/raise “Gate IN”. When the IR_SYSTEM (W0.00) and SENS_CAR_IN1 (0.03) are Active, then the IR_GATE_IN_UP (W0.01) coil will be Active.
Coil IR_GATE_IN_UP (W0.01) will be disabled when contact LS_GATE_IN_UP (0.07) is Active. Coil IR_GATE_IN_UP (W0.01) has an Interlock function so that if Input SENS_CAR_IN1 (0.03) is disabled, Coil IR_GATE_IN_UP (W0.01) is still Active.
RUNG 5 (GATE IN DOWN SYSTEM)
Rung 5 has a function to close/lower “Gate IN”. When the IR_SYSTEM (W0.00) and SENS_CAR_IN2 (0.04) are Active, then the IR_GATE_IN_DOWN (W0.02) coil will be Active.
Coil IR_GATE_IN_DOWN (W0.02) will be disabled when contact LS_GATE_IN_DOWN (0.08) is Active. Coil IR_GATE_IN_DOWN (W0.02) has an Interlock function so that if Input SENS_CAR_IN2 (0.04) is deactivated Coil IR_GATE_IN_DOWN (W0.02) is still Active.
RUNG 6 (GATE OUT UP SYSTEM)
Rung 6 has a function to open/raise the “Gate OUT”. When the IR_SYSTEM (W0.00) and SENS_CAR_OUT1 (0.05) are Active, then the IR_GATE_OUT_UP (W0.03) coil will be Active.
Coil IR_GATE_OUT_UP (W0.03) will be disabled when contact LS_GATE_OUT_UP (0.09) is Active. Coil IR_GATE_OUT_UP (W0.03) has an Interlock function so that if Input SENS_CAR_OUT1 (0.05) is disabled, Coil IR_GATE_OUT_UP (W0.03) is still Active.
RUNG 7 (GATE OUT DOWN SYSTEM)
Rung 7 has a function to close/lower “Gate OUT”. When the IR_SYSTEM (W0.00) and SENS_CAR_OUT2 (0.06) are Active, then the IR_GATE_OUT_DOWN (W0.04) coil will be Active.
Coil IR_GATE_OUT_DOWN (W0.04) will be disabled when contact LS_GATE_OUT_DOWN (0.10) is ON. Coil IR_GATE_OUT_DOWN (W0.04) has an Interlock function so that if Input SENS_CAR_OUT2 (0.06) is deactivated Coil IR_GATE_OUT_DOWN (W0.04) is still Active.
RUNG 8 (ALARM GATE IN)
This Rung functions to Activate the Alarm from “Gate IN”. When the IR_SYSTEM (W0.00) and the TRIG_ALARM_IN (1.00) are Active, then the IR_ALARM_GATE_IN (W0.05) Coil will be Active.
RUNG 9 (ALARM GATE OUT)
This Rung functions to Activate the Alarm from “Gate OUT”. When the IR_SYSTEM (W0.00) and the TRIG_ALARM_OUT (1.01) are Active, then the IR_ALARM_GATE_OUT Coil (W0.06) will be Active.
RUNG 10 (OUTPUT GATE IN UP)
This Rung functions to Activate the Output contact GATE_IN_UP (100.00). When the IR_SYSTEM (W0.00) and the IR_GATE_IN_UP (W0.01) are Active, then the GATE_IN_UP output contact (100.00) will be Active.
The GATE_IN_UP (100.00) output will only be disabled when the IR_ALARM_GATE_IN (W0.05) is ON and when the IR_SYSTEM (W0.00) is OFF.
RUNG 11 (OUTPUT GATE IN DOWN)
This rung functions to activate the Output GATE_IN_DOWN (100.01). When the IR_SYSTEM (W0.00) and the IR_GATE_IN_DOWN (W0.02) are active, then the Output GATE_IN_DOWN contact (100.01) will be activated. The Output GATE_IN_DOWN (100.01) will only be deactivated when the IR_ALARM_GATE_IN (W0.05) is active and the IR_SYSTEM (W0.00) is inactive.
RUNG 12 (OUTPUT GATE OUT UP)
This Rung functions to Activate the GATE_IN_DOWN (100.01) Output. When the IR_SYSTEM (W0.00) and the IR_GATE_IN_DOWN (W0.02) are Active, then the GATE_IN_DOWN output (100.01) will be Active. The GATE_IN_DOWN (100.01) output will only be disabled when the IR_ALARM_GATE_IN (W0.05) is ON and when the IR_SYSTEM (W0.00) is OFF.
RUNG 13 (OUTPUT GATE OUT DOWN)
This Rung functions to Activate the Output GATE_OUT_DOWN (100.03). When the IR_SYSTEM (W0.00) and the IR_GATE_OUT_DOWN (W0.04) are Active, the Output GATE_OUT_DOWN (100.03) will be Active. The GATE_OUT_DOWN (100.03) output will only be disabled when the IR_ALARM_GATE_OUT (W0.06) is ON and when the IR_SYSTEM (W0.00) is OFF.
RUNG 14 (OUTPUT GATE IN ALARM)
This Rung functions to Activate the GATE_IN_ALARM (100.04) Output. When the IR_SYSTEM (W0.00) and IR_ALARM_GATE_OUT (W0.05) are Active, the GATE_IN_ALARM (100.04) Output will be Active. Contact NO” P_1s ” functions so that the GATE_IN_ALARM (100.04) Output is Active by blinking every 1 second.
RUNG 15 (OUTPUT GATE OUT ALARM)
This Rung functions to Activate the GATE_OUT_ALARM (100.05) Output. When IR_SYSTEM (W0.00) and IR_ALARM_GATE_OUT (W0.06) are Active then the Output GATE_OUT_ALARM (100.05) will be Active. Contact NO” P_1s ” functions so that the GATE_IN_ALARM (100.04) Output contact is Active by blinking every 1 second.
- Automated Garage Gate Control PLC Logic
- Doll Claw Machine using Omron PLC Program
- PLC Program for Ceramic Oven Conveyor System
- PLC Controlling a Water Pump with 3 Power Sources
- Scheduled Daily Plant Watering PLC Programming
good platform for automation engineer i always like this platform
thanks sir
