Reading: What is Namur Digital Input Card?
Inst Tools > Blog > PLC Tutorials > What is Namur Digital Input Card?
Last updated: March 4, 2021 12:15 pm
2 Min Read
What is Namur digital input card? And what it is used for?
If you open the hardware configuration in the SIMATIC manager platform for Siemens PLC programming software and want to add a digital input card to your project you will notice some digital input modules with suffix NAMUR.
Namur Digital Input
NAMUR DI modules have the ability to receive NAMUR sensors signals and can detect if the sensor status is on, off, wire broken, or sensor short-circuited. But how the PLC can detect that?
From the above figure the NAMUR sensor circuit composed of sensing switch and resistances, the NAMUR DI module can detect the sensor resistance in the following cases.
In case of the sensor is off
The sensor’s total resistance = 10 KΩ+ 1 KΩ= 11KΩ
In case of the sensor is on
The sensor’s total resistance = 1 KΩ
Because in that case the 1 KΩ resistor is neglected by the ohms law
In case of wire broken
The sensor’s total resistance = ∞
In case of sensor short circuit
The sensor’s total resistance = 0
So the NAMUR sensor is a special digital sensor with a special modules to be connected to. But why we need all of this?
In some plants, there are sensors in critical positions where it’s important to know if the sensor is broken before it’s too late. Or in other plants, it’s used for personal safety protection and in minor cases to prevent electricians from bypassing the terminals of the sensor in order to simulate sensor on status.
Author: Karim Ali Anwar
  • What is Namur NE 43?
  • What is Namur NE 107?
  • 2 wire Sensors Operation
  • 4-20 mA Namur Current Signals
  • Programmable Logic Controller
Check Block Consistency Tools in Simatic Manager
Create a Function (FC) for a Valve Logic in Siemens PLC
Function of Racks in PLC – Types of SIEMENS S7-400 PLC Racks
PLC, DCS, and ESD Marshalling Cabinet Checks
Best Practices of PLC Wiring – Programmable Logic Controller
Flood Warning System using Programmable Logic Controller
PLC Data Comparison Instructions
PLC Program for Automatic Bottle Rejection System
What is Motor Jogging ?
How to Install GSD File in Step 7 PLC using Simatic Manager?
Preventa XPS MC, XPS MP - Safety controllers
High-end Programmable Logic Controller – Schneider PLC
Controlling of Tank Level Using Proportional Controller in PLC
PROFIBUS is also a Master Slave protocol
Elevator PLC Ladder Logic
PLC Counter Example for Bank
Power Supply Sizing for Industrial Automation Systems
Structured Text PLC Example for Motor Interlocking and Control
PLC Ladder Diagram program
Contacts and Coils in PLC Ladder Logic
Electrical Machines MCQ Series 14
Connection between PLC and Contactor
Torque Measurement Objective Questions
PLC program for Latching and unlatched circuit
Purge & Pressurization Systems Questions
Purge & Pressurization Systems Interview Questions
Ladder Logic of Motor Forward and Reverse
PLC Programming Example for Motor Forward and Reverse Control
PLC Demo Software
PLC Trainer Demo Download
