Reading: Multistage Flash Drums Erratic Level Readings
Inst Tools > Blog > Root Cause Analysis (RCA) > Multistage Flash Drums Erratic Level Readings
Instrumentation engineering root cause analysis of multistage flash drums erratic level instrument readings.
Last updated: September 28, 2022 2:55 pm
S Raghava Chari
Multistage Flash Drums Erratic Level ReadingsAuthor RCARoot Cause IdentifiedRoot Cause RemovedRoot Cause found solution implementedRoot Cause Solution Benefits
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Sensors
Author:S. Raghava Chari
High Pressure (HP) side extended seal diaphragm differential pressure transmitters (DPT) never developed pinholes, unlike the previously discussed urea plant seal DPTs, shop calibrated, and static pressure tests passed before field installation.
Yet the 5-stages flash drums erratic level readings stopped the 750 T/d NH3 commissioning.
Author RCA
Because of drift-free calibration, all differential pressure level transmitters (DPLT) erratic outputs and the excellent brand name the author’ attributed root cause was:
HP, LP or both representative signals did not reach the differential pressure level transmitters (DPLT).  Therefore, he studied the high-pressure (HP) and low-pressure (LP) taps carefully from the vessel drawing and noted the following
  1. The 4” flanged HP extended diaphragm immerses fully in tranquil liquid NH3 contained in each stage chamber. Hence, the DP senses representative HP signal
  2. Welded to the previous stage bottom a 300 mm long extension skirt forms a 150 mm radial width annulus (below figure)
  3. Liquid NH3 from the previous higher pressure stage enters the annulus tangentially – a process requirement
  4. The DPLT LP tap senses the annulus gas pressure
He considered these observations and concluded:
  1. The tangential entry and liquid evaporation cause unsteady pulsating annulus pressures
  2. The DPLT LP port senses this pulsating unrepresentative pressures – the erratic liquid NH3 level readings Root Cause disturbances could be causing the DPLTs outputted erratic level signals..
Root Cause Removed
½ hour thought flashed solution was: insert a supplementary nozzle via the LP tap penetrating ½‑extension skirt (above figure) to feed the skirt tranquil pressure to the DPLT LP port.
The diagnosed root cause impressed management ordered, “Go ahead; modify all stages LP taps”, to avoid a second shutdown if this step succeeds.
A crew took the below-listed steps:
  1. They inserted a shop made 100 mm long guide bush in the LP tap and bolted a flange over it
  2. A long drill passing through the guide bush bore drilled 20 mm dia hole in the skirt wall
  3. The crew inserted the shop made supplementary nozzle secured it bolting a flange
  4. Instrument crew connected the supplementary nozzle to the DPLT LP port
  5. Mech and Inst crew did these for all stages
The DPTs read correctly, as expected, and commissioning progressed rapidly.
Author: S. Raghava Chari
  • Turbine Flow Meter Constraints
  • Pitot-tube Replaced with Orifice
  • Mechanical Temperature Indicator
  • Pressure Transmitter Stopped Working
  • Seal Pressure Instruments Problems
Ammonia Feed Ball Valve to Ship Tank Closed
Thermowell Shank to Flange Repeat Weld Leaks
Seal Pressure Instruments Root Cause Analysis
Steam Letdown Station Problems and their Solutions
Mechanical Engineering Plant Problems Solved – Root Cause Analysis
HT Motor Problem appears after Disassembly and Reassembly
RCA – Compressor Did Not Trip on Suction Pressure Low Low
High-pressure Service Level Transmitters Misunderstood Zero Drifts
Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
NH3 Plant Turbo-compressor Sudden Rise in Temperature
Cooling Tower Fans Frequently Failing
Doubtful Temperature Readings
Doubtful Temperature Readings threatens Soaking Pit Wrecks
Solenoid Valve Failure in Plant Start-Up
Leaking Plug Valves pose Safety Hazards and Lead to Plant Shutdown
Leaking Plug Valves Pose Safety Hazards and Lead to Plant Shutdown
Packaging Machinery
Poor Bagging Scale Availability Threatened Production Cuts
Turbine to Gearbox Alignment Drifts Caused Pump Transfers Problems
RCA Related to Trip Throttle Valve (TTV)
Recurring Short Circuit Flash Overs Safety Hazards
Recurring Short Circuit Flash Overs Safety Hazards & Damages
Process Air Compressor Overhauls Eliminated
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
Plant Shutdown Analysis: Valve Closed and SOV Coil Failure
Linear Programming in Excel
How to Do Linear Programming in Excel?
failure rate of a component - 1
Failure rate and MTBF of Safety Instrumented Systems
PLC analog output card
PLC Analog I/O and Network I/O
AC Voltage Controllers Objective Questions
Selecting the Proper Failure Mode
How to Select Control Valve Failure Mode
Grounding Electronic Equipment
Importance of Grounding Electronic Equipment
Liquid Level Measurement using Pressure Transmitter
Liquid Level Measurement using Pressure Transmitter Questions
DC Circuit
Main differences between Sinking and Sourcing Circuits
