Reading: Metal Tube Variable Area Flow Meters Principle
Inst Tools > Blog > Flow Measurement > Metal Tube Variable Area Flow Meters Principle
Metal Tube Variable Area Flow Meters measure the volumetric flow rate of liquid and gases that operate on the float principle.
Last updated: November 1, 2023 12:08 pm
Flow Measurement
2 Min Read
Metal tube Variable Area Flow Meters measure the volumetric flow rate of liquid and gases that operate on the float principle.
Metal Tube Variable Area Flow MetersPrinciple of Variable Area Flow Meters
Metal tube variable area flow meter features a tapered metal tube, in which a float is allowed to move freely up and down.
Metal tube Variable Area Flowmeters Principle
Image Courtesy: Brooks
The float reaches a stable position when the upward force exerted by the flowing liquid equals the weight of the float. The float position is transmitted by a magnetic coupling system to the scale.
The rotational movement of the follower magnet system transmitted to the indicator is linearised and the flow rate is indicated directly on the scale.
The flow path has a tapered part. A float containing a magnet is located in the tapered tube. Fluid flows from the bottom of the flowmeter and goes upward through the tube.
The differential pressure produced by the float and the tapered tube pushes the float upward, and the float stops when the weight of the float and the differential pressure balance. In other words, the position of the float corresponds to the flow rate.
Metal tube Variable Area Flow meters
The movement of the magnet in the float is detected by the magnetic coupling, which converts it into the movement of the pointer.
Although the tapered tube and thread part are welded by braze pressure welding (BPW) with high-frequency induction heating, TIG welding may be used in some specifications.
Source: tokyokeiso
  • Averaging Pitot Tube Principle
  • Different Types of Control Valve
  • Flow Measuring Devices Questions
  • Linear to Square Root Conversion
  • What is Flow Meter Accuracy?
Differential Pressure (DP) Flow Meters Range Calculation Methods
Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
Orifice Plate Turndown ratio
Magnetic Flow Meter Animation
Flow Meter Characteristics
Overview of Positive Displacement Flow Meters
  • Krishna says:
    August 17, 2024 at 10:41 am
    It’s all ok. Then how the movement of the float is convert to 4…20mA.?
How to Read Circular Chart Recorder for Flow Measurement?
Importance of Flow Meter Turndown Ratio
Lobed Impeller Flow Meters Working Principle
Swirl Flow Meters Working Principle
Continuous Flow Measurement
Types of Variable Area Flow Meters
volumetric flow measurement for liquids versus gases
Standardized Volumetric Flow
Types of Flow Meters
Interview on Flow Measurement
Interview Questions on Flow Measurement
Turbine Flow Meter Animation
Turbine Flow Meter – Principle, Advantages, Disadvantages
vortex flow transmitter
What is a Vortex Flow Meter?
Water Cut Meter
What is Water Cut Meter?
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Vortex Flow Meter Animation
Hot Air Welding
What is Hot Air Welding? – Advantages
Instrument Ranging
Notes on Instrument Ranging
PLC Ladder Logic Chemical Mixing Process
Chemical Mixing Process using PLC
Temperature Gauges and Elements Specifications
Temperature Gauges and Elements : Detailed Specifications
Characteristics of Transducers Objective Questions
Induction Generator Quiz
PLC Fault Diagnosis - PLC Training Documents
PLC Fault Diagnosis – PLC Training Documents
Pipe Elbow Sudden Burst
A Pipe Elbow Sudden Burst Fatalities and Wrecked Panel Instrumentation
