Reading: How to use Masked Move Instruction in PLC
Inst Tools > Blog > PLC Tutorials > How to use Masked Move Instruction in PLC
Last updated: January 17, 2022 7:21 pm
3 Min Read
The pattern of bits in the mask determines which bits will be passed from the source address to the destination address, and which bits will be masked. Only bits in the mask that are set (1) will activate the mask operation. In this article, MVM (Masked Move) is discussed.
Masked Move Instruction Block DiagramMVM Instruction DescriptionMVM Instruction Function :Example 1Example 2Example PLC Program using MVM InstructionProgram DescriptionConclusion
There are three parameters in MVM,
Source :
It is the address of the data you wants to move.
Mask :
Address of the mask through which the instruction moves data. The mask acts like a filter    for the destination.
Destination :
It is the address where the instruction moves the data.
There are three ways to give mask address,
  1. To enter a hexadecimal mask: type the hexadecimal value followed by the letter H (Hexadecimal).
  2. To enter a binary mask: type the binary value followed by the letter B (Binary).
  3. To enter a decimal mask: type the decimal value.
Note : RSLogix will make any necessary conversion and display the hexadecimal value.
Activation of mask bit pattern will move the data in Source address to destination address. Move function will not happen until mask bit is activated.
Example 1
When the rung condition goes true,
Case 1
Output When Mask Bit is not activated,
MVM PLC Block
Case 2
Output When Mask Bit is activated,
Example 2
Case 1
Masked Move Instructions
Case 2
Mask Command in PLC
In this program, When N7:2 equals to the value 9, turn ON O:0/0,
PLC Program using Mask Instruction
Program Description
 Rung 0000
When input condition goes true (I:0/0 turns “ON”),MVM instruction will move the data in N7:0 to N7:2.
Rung 0001
Equal block is used from comparator function to turn on O: 0/0 when N7:2 equal 9.
Conclusion
The above explained concept for Masked Move is for example only. We can use this example program to understand the working of MVM instruction in AB PLC.
Author : Hema Sundaresan
PLC Analog Input Scaling
SCADA for Substation
PLC Counter Instruction
Features of SCADA
PLC Troubleshooting
How to use Sub Routines with Allen Bradley PLC
Standard Colors in PLC Automation Systems
Split Range Control Application using PLC Ladder Logic
PLC Program for Mailbox with Letter Counting & Light Indicators
Allen Bradley Bitwise Logical Operations
Basics of Fail-safe Circuits
PLC Motor Operation based on Time Cycle Sequence – Program
Electrical Ladder Diagram Control using Timers Example
Automatic Railway Crossing Gate Control PLC Program
PLC Program for Controlling Sequence of Conveyors with Interlock
How to Work With Simulator in S7-1200 and S7-1500 PLC?
PLC Logic for Automatic Bending Machine for Exhaust Pipe
Pause the Timer PLC Ladder Logic
Save and BR Memory in Siemens PLC Programming
SAVE and BR Memory Instructions in Siemens PLC Programming
What is PLC
What is a PLC? – Programmable Logic Controller
Push button Motor PLC Logic
PLC Programming Sequence Logic
PLC Programming to Control Lights in a Sequence
Peripheral Inputs and Outputs in Siemens PLC
What is meant by a SCADA System
Troubleshoot the Status of a PLC Via CPU Indicators
Control Valve Passing Problem after Overhauling Job
Level Gauge Interface Measurement
Level Gauge Interface & Temperature Problems
PLC Fault Diagnosis - PLC Training Documents
PLC Fault Diagnosis – PLC Training Documents
Transistor as an Amplifier in Common Emitter
Process Control & Instrumentation Objective Questions – Set 7
Safety Integrity Level (SIL)
Thermocouple Temperature Measurements Errors
Thermocouple Temperature Measurement Errors
Thermography and Thermometry Objective Questions
