Reading: Managed Switch vs Unmanaged Switch
Inst Tools > Blog > Control Systems > Managed Switch vs Unmanaged Switch
In this article, you will learn the basics of managed switch and unmanaged switch in networking.
Last updated: January 24, 2023 11:15 am
Control Systems
In this article, you will learn the basics of the managed switch and unmanaged switch in networking.
What is the difference between a managed network switch and an unmanaged network switch?Managed Switch vs Unmanaged Switch
The network Switch is one of the most important parts of any network. All the communications going on a network are only possible because of a network switch.
The network switch receives data from one port and sends the data to the other port or the correct location. Because of this functionality, the network switch is also called the brain of any network. Because the network switch manages the data communication between all the devices on the network.
Managed Switch
Figure – Managed Switch
Any Network Switch can be classified on the basis of the number of ports. The most common type of network switch is 24-port and 48-port network switches in industrial applications. But one of the main parameters which differentiate network switches is whether the switch is managed network switch or an unmanaged network switch.
One of the most basic differences between a managed network switch and an unmanaged network switch is that the unmanaged network switch allows the device to connect to the network by simply plugging into the network switch port.
While in the case of a managed switch, greater control over the ports of the network switch is provided.
Unmanaged Switch
Figure – Unmanaged Switch
Let us see the differences between the managed network switch and unmanaged network switch in detail:
  • The managed network switches allow to manage, monitoring as well as the configuration of all the devices connected to its ports. While the unmanaged network switch has the facility of only connecting the device to the network by simply plugging the device into the port of the network switch.
  • This option of simply plug and play is sometimes advantageous for the user while using an unmanaged network switch. While in the case of the managed network switch, the user has to configure the device before connecting it to the network.
  • The traffic in the managed network switch is effectively managed by creating new local networks and allocating a bunch of devices connected to the managed network switch. While in the case of an unmanaged network switch, no control over the data traffic is provided.
  • In terms of network security, managed network switch is much preferred over an unmanaged network switch. In managed network switch, advanced features to detect network threat and shut them down on time is available. Also, data protection and control data are much more advanced in managed network switches. While in unmanaged network switches, no such control over threat protection and data is available.
  • A feature like SNMP (Simple Network Management Protocol) is present in managed network switches, which allows the managed network switch to be connected to a remote network for remote troubleshooting. Hence, in such cases, no physical connection with the network is required while working on the network. In the case of unmanaged network switches, no such feature of SNMP is present.
  • The cost of unmanaged network switches is much less than compared to the cost of managed network switches.
  • Background of Modbus
  • Cyber Security Questions
  • Cables in Automation
  • IoT based Control System
  • Redundant Control Systems
Basics for CAN Bus Protocol – Controller Area Network
How Important is VPN for Control Engineers?
What is Marshalling Cabinet?
History of Internet of Things (IOT)
  • freddy hlengani baloyi says:
    January 24, 2023 at 10:10 pm
    I like to attend short course
Integral (Reset) Control Theory
Difference Between Batch Process and Continuous Process
The need for automatic controls
What is Multi-touch Technology? – Industrial Automation
Control Panels Material Take-Off (MTO) – Engineering Project
Introduction to PlantPAx Distributed Control System
DCS Troubleshooting Control Valve Loop
Industrial Automation Cold and Hot Standby
Instrumentation Commissioning
Commissioning Documents for Instrumentation Engineers
What is Wellhead Control Panel?
Level Control Loop Principle
Integrating Processes – Liquid Level Control
Solve Pressure Control System Problems
Automation Engineer Troubleshooting Tips
Loop Diagram
PT Loop Diagram Faults
PLC based Auto Manual Operation of Roll down Shutters
PLC based Auto/Manual Operation of Roll down Shutters in Industry
Ultrasonic Level Switch Principle
IACS Network
Remote Connectivity to Industrial Automation Systems
Allen-Bradley MicroLogix PLC Wiring
Programmable Logic Controller (PLC) Questions and Answers – 8
Rotary Stem Valves
Rotary Stem Valves
Top Free PLC Software
RF-Capacitance Level Switch Principle
