Reading: Light ON OFF Control using PLC
Inst Tools > Blog > PLC Tutorials > Light ON OFF Control using PLC
Last updated: March 4, 2021 3:43 pm
2 Min Read
We most often come across light ON OFF control; single switch with multiple conditions using programmable logic control (PLC) is discussed here.
PLC Light ON OFF ControlLamp Control LogicInputs and OutputsPLC Ladder Logic for Light ControlPLC Logic DecriptionConclusion:
Note : The above image used only as reference, terminal details may be different with the logic.
Lamp Control Logic
There are only two switch for start and stop lamp. The conditions are,
PLC Light Control Logic Conditions
Note: If stop switch is pressed at any one of the above step, the process should stop.
Inputs and Outputs
PLC Inputs and Outputs for Light Control
PLC Light Control
PLC Lamp Ladder Logic example
PLC Logic for Light System
 RUNG 0000
Latching rung to operate the system through Master Start and Stop switch..Lamp should be turned on when start is pressed.
RUNG 0001 to RUNG 0006
when start is turned on/off memories are latched to store the status of Start switch
RUNG 0007
Conditions are wired in series and parallel to make the condition possible.
Conclusion:
The above explained Light turn ON/OFF control using PLC is for example only. It may vary from real time. We can use this example program to understand the working of memories and Latching in AB PLC.
Author : Hema Sundaresan
PLC Example with Switches
Maintenance of PLC System
PLC System Documentation
PLC Ladder Logic for Elevator
MCQ on SCADA systems
How Could FB and FC Make Me Professional PLC Programmer?
PLC Mixing Process with Adjustable Timer and Valve Control
Types of Digital Outputs in PLC
Step by Step Guidelines to Download Free Robotics Software
Ladder Logic for Stair-Case wiring using Toggle Switches
PLC Latching Function
Various Causes for PLC Going in Stop Mode
PLC Structured Text Program for Output Generation via Equations
What are FIFO and LIFO Sequences in PLC?
4–20 mA Process Control Loops
PLC Compressor Control Ladder Logic
What is a PLC? – Programmable Logic Controller
PROFIBUS is also a Master Slave protocol
Codesys function block example
Create a User-Defined Function Block in Codesys
Pneumatic valve operation in sequence mode
Sequential PLC Programming for the Pneumatic Valves
siemens plc db addressing
FB Block in Siemens PLC Programming
HMI screen for operator
Auto Tiffin Box Filling Station
PID with Practical Example
Push button Motor PLC Logic
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
Transistor as Switch Working Animation
How a Transistor Switch Works
Emergency Shutdown Valve
Emergency Shutdown Valve : Advantages
Touch Potential
Methods to Reduce Step Potential and Touch Potential in Substation
Thermowell Shank to Flange Repeat Weld Leaks
Stability in Frequency Domain
Time Domain Analysis
Different Control Modes of Air Handling Unit (AHU)
Control Modes of Air Handling Unit (AHU) – HVAC Basics
diaphragm-pressure-gauge
Diaphragm Pressure Sensors
4-wire pH Transmitter Problem
