Reading: Level Gauges Objective Questions and Answers – Instrumentation
Inst Tools > Blog > Instrumentation MCQ > Level Gauges Objective Questions and Answers – Instrumentation
This level gauges objective questions to help you with instrumentation exams and learn level indicators in industrial instrumentation.
Last updated: July 24, 2024 2:08 pm
Instrumentation MCQ Level Measurement
7 Min Read
Level Gauges Objective QuestionsWhat is the working principle of a float type level gauge?What is the key working principle of a reflex level gauge?How does a sight glass gauge provide level indication?What is the main operational principle of a magnetic level gauge?How do float type level gauges translate liquid level into readable measurements?What is the primary advantage of a magnetic level gauge?What type of level gauge involves a transparent tube for direct visual inspection?In which scenario is a magnetic level gauge most beneficial?What is a key disadvantage of using a sight glass gauge?Which type of level gauge is best for colorless liquids?Which level gauge is preferred for high-pressure applications?Which type of level gauge is not recommended for use with corrosive liquids?Why might a float type level gauge be chosen over other types?Which level gauge is best suited for hazardous chemical applications?What is the main drawback of using a reflex level gauge?Which level gauge is often used in boiler systems?Which level gauge is least affected by changes in liquid density?Why might a magnetic level gauge be chosen for use with hazardous liquids?Which level gauge type is typically installed directly on the vessel wall for easy monitoring?Why are sight glass gauges not recommended for high-pressure applications?Which type of level gauge is most effective in high-temperature environments?What is a primary disadvantage of using float type level gauges with viscous liquids?Which level gauge type uses prisms to reflect light for level indication?Why are reflex level gauges not ideal for use with opaque or dark liquids?Which level gauge type is often used in food and beverage industries for its hygienic properties?Why are float type level gauges less effective with highly viscous liquids?
This video helps you to learn about the explanations for each question on the level measurement instrumentation.
Level Gauges Questions and Answers - Instrumentation and Control
Question 1
A. Magnetic coupling
B. Buoyancy
C. Light reflection
D. Direct visual inspection
Show the Answer
Buoyancy
Question 2
B. Buoyancy
C. Light reflection and refraction
Show the Answer
Question 3
B. Buoyancy
C. Direct visual inspection
D. Light reflection
Show the Answer
Question 4
A. Buoyancy
B. Direct visual inspection
C. Light refraction
D. Magnetic coupling
Show the Answer
Magnetic coupling
Question 5
A. Using prisms
B. Magnetic coupling
C. Float movement
D. Light reflection
Show the Answer
Float movement
Question 6
A. Low cost
B. No power required
C. High accuracy and safety
D. Simple installation
Show the Answer
Question 7
A. Magnetic Level Gauge
B. Float Type Level Gauge
C. Reflex Level Gauge
D. Sight Glass Gauge
Show the Answer
Sight Glass Gauge
Question 8
A. Low-pressure applications
B. Non-hazardous liquids
C. High-temperature and high-pressure applications
D. Simple water tanks
Show the Answer
Question 9
A. High cost
B. High maintenance
C. Limited to non-hazardous liquids
D. Not suitable for continuous monitoring
Show the Answer
Question 10
B. Reflex Level Gauge
C. Float Type Level Gauge
Show the Answer
Reflex Level Gauge
Question 11
A. Reflex Level Gauge
C. Sight Glass Gauge
D. Magnetic Level Gauge
Show the Answer
Question 12
Show the Answer
Sight Glass Gauge
Question 13
A. Cost-effective
B. High precision
C. Low maintenance
D. Continuous monitoring capability
Show the Answer
Question 14
A. Float Type Level Gauge
B. Sight Glass Gauge
Show the Answer
Question 15
A. High cost
B. Limited to non-hazardous liquids
C. Not suitable for high-pressure applications
D. Reduced visibility with dark liquids
Show the Answer
Question 16
Show the Answer
Sight Glass Gauge
Question 17
Show the Answer
Question 18
A. Cost-effective
B. Simple installation
C. High maintenance
D. No direct contact with the liquid
Show the Answer
Question 19
Show the Answer
Sight Glass Gauge
Question 20
A. High cost
B. High maintenance
C. Safety concerns
D. Poor accuracy
Show the Answer
Safety concerns
Question 21
B. Magnetic Level Gauge
D. Float Type Level Gauge
Show the Answer
Question 22
A. High cost
B. Difficult installation
C. Requires power
D. Reduced accuracy
Show the Answer
Reduced accuracy
Question 23
Show the Answer
Reflex Level Gauge
Question 24
A. High cost
B. High maintenance
C. Poor visibility
D. Requires power
Show the Answer
Poor visibility
Question 25
Show the Answer
Sight Glass Gauge
Question 26
A. High cost
B. Complex installation
C. Reduced float movement
D. Requires power
Show the Answer
  • Types of Level Measurement
  • What is Reflex Level Gauge?
  • Plumb-bob Level Gauge Principle
  • Magnetic Level Gauge Float Design
  • Types of Level Gauges
Magnetostrictive Level Measurement
Capacitive Level Measurement
Pressure Transmitters Leg Compensation Technique
Types of Pressure – Instrument Questions and Answers
Split-Range, Auto-Selector, Ratio & Cascade Systems
Ultrasonic Level Switch Working Principle
Application of Feedback Objective Questions
Level Measurement Objective Questions
Laser Level Measurement Principle
Analog Demodulators Objective Questions
Siemens Differential Pressure Transmitter Calculations (Flange Type)
Ultrasonic level measurement
Ultrasonic Level Measurement
remote seal capillary type dp transmitter
Instrument Technicians Tools - Instrumentation MCQ Questions
Instrument Technicians Tools – Instrumentation Test
Sensors Objective Questions
Closed-tank-DP-Level-Transmitter-with-cleaning-leg-Calibration
Basic Digital Building Blocks Objective Questions
Performance of Systems Objective Questions
Performance of Control Systems Objective Questions
Magnetic Float Level Sensor Principle
Magnetic Float Level Transmitter Working Principle
4-20mA to Process Variable conversion
Formula to Calculate Process Variable from 4-20mA
Calibration Instruments
Basics of Calibration
Electrical Machines MCQ Series 2
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Dry-Leg
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
Control Valves Flow Direction
Control Valve Flow Direction
Comparison of MOSFET and BJT
PLC Program for Temperature Control using Thermostat
Hot wire Anemometer Principle
Hot Wire Anemometer Principle and Types
