Reading: Interconnection between PLC, MCC, LCP & Pumps – Video
Inst Tools > Blog > Control Systems > Interconnection between PLC, MCC, LCP & Pumps – Video
This video shows us the relation between Programmable Logic Controller (PLC), motor control center (MCC), Local Control Panel (LCP) for controlling a Pump or Motor.
Last updated: November 2, 2023 4:11 pm
Control Systems PLC Tutorials Videos
4 Comments
1 Min Read
PLC Pump Control Video
Interconnection between PLC , MCC, LCP & Pumps
MCC : Motor Control Center or Substation where motor will be powered.
PLC/DCS : Control System, where Motor can be controlled as per logic (Auto) or as per operator action (Manual).
LCP : Local Control Panel which is installed in the field, near motor in which start, stop push buttons are available
  • Switch Types and Common Terminology
  • Basics of Temperature Switch
  • Relay Principle & its Types
  • Creating Custom Calibration Resistances
  • Switch Contact Normal State and Make/Break
Setpoints and Alarms in Control System
#10 PLC Best Practices – Assign Register Blocks by Function
What is a Recorder ?
Automatic Door Operation PLC Programming and Simulation
PLC Program to Separate Different Size Objects
4 Comments
  • Vicky says:
    December 17, 2016 at 3:55 pm
    Nicely Done. Great Animation for beginners and worth sharing video.
  • peter says:
    December 28, 2017 at 4:40 am
    Please sir I need knowledge in instrumentation, please update me by sending article into my email for study
    • S Bharadwaj Reddy says:
      January 7, 2018 at 2:47 pm
      Hi, You can subscribe for Daily email updates : CLICK HERE
    • salahudin says:
      September 22, 2022 at 10:05 am
      Hi, Peter Can you also please share with me instrumentation training courses.
PLC Instruction List for Motor Reverse and Forward Direction
Structured Text PLC Example for Motor Interlocking and Control
Free PID Controller Gains Tuning Tool
PLC Math instructions
Split Range in Foundation Fieldbus
Foundation Fieldbus Split Range Valves
What is NEST loading in DCS
Parts of PLC
Parts of PLC
Process Shutdown
Difference between Process shutdown and Emergency Shutdown
PLC Programmer Tools
PLC to PLC Communication using S7 Connection
PLC to PLC Communication using S7 Connection PUT & GET Instructions
PLC Programming Software
Difference between Soft Starter and VFD
Open Loop Control Block Diagram
Insulation of Thermowell
Facts on Thermowell Insulation Thickness
What is Process Control ?
What is Process Control?
Safety in Automation Systems
Solar Pump
What is a Solar Pump VFD? – Advantages, Principle
Calibration Interview Questions and Answers
