Reading: Instrument Technicians Tools – Instrumentation Test
Inst Tools > Blog > Instrumentation MCQ > Instrument Technicians Tools – Instrumentation Test
Test your skills on instrument technician tools with our MCQ questions and answers resource for instrumentation equipment.
Last updated: July 25, 2024 11:50 am
Instrumentation MCQ
9 Min Read
Instrument Technicians ToolsWhich tool is commonly used to measure voltage, current, and resistance in electrical circuits?Which device is specifically used for calibrating 4-20 mA current loops in industries?What instrument is essential for calibrating pressure sensors and transmitters?Which tool is used to calibrate temperature sensors like thermocouples and RTDs?What device is used for configuring, calibrating, and troubleshooting HART-enabled field instruments?Which tool measures pressure using a column of liquid?Which device generates electrical signals with varying frequencies and amplitudes for testing and calibration?What tool is used to measure the insulation resistance of electrical components?Which instrument generates various waveforms for testing and development of electronic circuits?What tool is designed for calibrating and troubleshooting process instruments?Which tool is used to measure the frequency of an electrical signal?What device is used to visualize and analyze electronic signal waveforms?Which tool is used for field calibration and configuration of digital instruments and control systems?What instrument uses known weights to apply a specific pressure for calibration purposes?Which tool is used to generate and control pressure for calibrating pressure instruments?What device is used to measure and display pressure readings directly?Which tool is used to calibrate both thermocouples and RTDs?What instrument measures temperature without direct contact with the object?Which tool allows for precise adjustment of electrical resistance values for calibration?What device measures electrical parameters by clamping around a conductor?Which tool is used for testing and verifying the functionality of fieldbus networks?What instrument simulates continuous signals like 1 to 5 volts for testing and calibration of electronic devices?Which tool is used to calibrate weighing scales and balances?What tool allows for precise adjustment of capacitance values for calibration purposes?What instrument is used to calibrate flow meters by generating known flow rates?Which tool provides a reliable connection for testing electrical circuits?What device measures inductance, capacitance, and resistance for component testing?Which device simulates RTD signals for testing and calibration?Which tool generates a vacuum for testing and calibrating pressure instruments?What instrument measures the resistance of the ground to ensure proper grounding?Which device is used to analyze and troubleshoot network performance?Which tool allows for precise adjustment of inductance values for calibration purposes?What instrument provides a stable temperature environment for calibrating temperature sensors?Which device can generate and measure multiple electrical parameters for calibration?What tool simulates thermocouple signals for testing and calibration?
This video helps you provide clear explanations for the instrument technician’s questions.
Instrument Technician Tools - Instrumentation Engineering Quiz
Question 1
A. Clamp Meter
B. Multimeter
C. Decade Box
D. Oscilloscope
Show the Answer
Multimeter
Question 2
A. Thermocouple Calibrator
B. Manometer
C. Loop Calibrator
D. Signal Generator
Show the Answer
Loop Calibrator
Question 3
A. Function Generator
B. Loop Calibrator
C. Clamp Meter
D. Pressure Calibrator
Show the Answer
Pressure Calibrator
Question 4
A. Temperature Calibrator
B. Loop Calibrator
C. Signal Generator
D. Analog Simulator
Show the Answer
Question 5
A. Multimeter
B. Function Generator
C. HART Generator
D. HART Communicator
Show the Answer
HART Communicator
Question 6
A. Manometer
B. Portable Hand Pump
C. Deadweight Tester
D. Pressure Gauge
Show the Answer
Manometer
Question 7
A. Process Calibrator
B. Signal Generator
C. Field Communicator
D. Insulation Tester
Show the Answer
Signal Generator
Question 8
A. Oscilloscope
B. Decade Box
C. Pressure Calibrator
Show the Answer
Insulation Tester
Question 9
A. Manometer
C. Loop Calibrator
D. Temperature Calibrator
Show the Answer
Function Generator
Question 10
A. Decade Box
B. Clamp Meter
C. Process Calibrator
D. Infrared Thermometer
Show the Answer
Process Calibrator
Question 11
A. Resistance Tester
B. Frequency Counter
C. Flow Calibrator
D. Frequency Generator
Show the Answer
Frequency Counter
Question 12
A. Clamp Meter
B. Signal Generator
C. Oscilloscope
D. Thermocouple Simulator
Show the Answer
Oscilloscope
Question 13
A. Field Communicator
B. Calibration Weights
D. Hand-Held Vacuum Pump
Show the Answer
Field Communicator
Question 14
A. Deadweight Tester
B. Drillweight Tester
C. Dryweight Tester
D. Duckweight Tester
Show the Answer
Deadweight Tester
Question 15
A. LCR Meter
C. Function Generator
D. Oscilloscope
Show the Answer
Portable Hand Pump
Question 16
A. Insulation Tester
B. Level Indicator
C. Pressure Gauge
D. Flow Meter Calibrator
Show the Answer
Pressure Gauge
Question 17
A. Voltage Calibrator
B. Thermocouple and RTD Elements
C. Decade Box
D. Thermocouple and RTD Calibrators
Show the Answer
Question 18
A. Analog Simulator
B. Thermocouple and RTD Sensors
C. Infrared Thermometer
D. Process Calibrator
Show the Answer
Question 19
A. Hand-Held Vacuum Pump
B. Decade Resistance Box
C. Thermocouple Simulator
Show the Answer
Question 20
A. Clamp Meter
B. Field Communicator
C. Multifunction Calibrator
D. LCR Meter
Show the Answer
Clamp Meter
Question 21
A. Fieldbus Tester
B. Bus Communicator
C. Network Gauge
D. Signal Generator
Show the Answer
Fieldbus Tester
Question 22
A. Oscilloscope
B. Infrared Thermometer
C. Frequency Counter
D. Analog Simulator
Show the Answer
Analog Simulator
Question 23
A. Weight Generator
C. Signal Generator
D. Function Generator
Show the Answer
Calibration Weights
Question 24
B. Decade Capacitance Box
C. Multimeter
Show the Answer
Question 25
A. LCR Meter
B. Digital Manometer
C. Flow Meter Calibrator
D. Flow Generator
Show the Answer
Question 26
A. Decade Box
B. Electrical Test Leads
D. Ground Resistance Tester
Show the Answer
Question 27
B. Clamp Meter
C. LCR Meter
D. Deadweight Tester
Show the Answer
LCR Meter
Question 28
A. RTD Generator
B. Clamp Meter
C. RTD Simulator
D. Resistance Tester
Show the Answer
RTD Simulator
Question 29
A. Multifunction Calibrator
B. Hand-Held Vacuum Pump
C. Vacuum Gauge
D. Oscilloscope
Show the Answer
Question 30
A. Signal Generator
B. Decade Box
C. Ground Resistance Tester
Show the Answer
Question 31
A. Frequency Counter
C. Clamp Meter
D. Network Analyzer
Show the Answer
Network Analyzer
Question 32
B. Clamp Meter
C. Decade Inductance Box
D. Multifunction Calibrator
Show the Answer
Question 33
A. Dry Block Calibrator
B. Manometer
C. Signal Generator
Show the Answer
Question 34
B. Decade Box
Show the Answer
Question 35
B. Thermocouple Generator
C. Analog Simulator
Show the Answer
  • Testing thermocouples and RTDs
  • How to Test a Pressure Gauge?
  • Troubleshooting with Loop Calibrator
  • Loop Calibrator to Simulate a 4-20 mA
  • List of Tools used by Instrument Technician
Fibre Optic Sensors Objective Questions
Radio Telemetry Objective Questions
Top 100+ SCADA Questions
Viscosity Measurement Objective Questions
Application of Feedback Objective Questions
  • Divyeshpatel says:
    August 28, 2024 at 11:41 am
    Apply for instrument technician
Basic Temperature Sensors MCQ Questions Answers
Semiconductor Sensors Objective Questions
Control Loop Multiple Choice Questions
Digital Transducers Objective Questions
Process Control & Instrumentation Objective Questions – Set 3
Sensors and Transducers Test
Ladder Logic Questions and Answers
Resistive Transducers Objective Questions
Relay Types
Types of Relays – Questions and Answers
PID Controllers Multiple Choice Questions
PID Controller Multiple Choice Questions
Pressure Measurement Objective Questions
Electrical Networks Objective Questions
Top 80+ Valve Questions and Answers
Pressure Gauges Common Problems
Pressure Gauges : Common Causes for Failures and Their Effective Solutions
GSM Based Projects
GSM Based Projects – Ideas and Topics
Types of Wireless Technologies in Industrial Automation
Paint Mixing System
Paint Mixing System
Feedback Transducer System Objective Questions
Discrete control system block diagram
Process Control Instrumentation
PLC Multiple Choice Questions
How Weigh Feeder Works
How Weigh Feeder Works ?
