Reading: Instrument Cables Sheath Material
Inst Tools > Blog > Instrumentation Design > Instrument Cables Sheath Material
Sheath of the cables are used to protect the cables from damage. Instrument Cables Sheath Materials selected as per operating temperature of cable.
Last updated: January 18, 2021 3:52 pm
2 Min Read
The cables sheath is used to protect the cable from the external damages and also used to hold the multiple conductors inside the cable together.
Cables Sheath MaterialTypes of MaterialsStandards
In simple terms, the outer layer of a cable is called sheath.
The sheath may be available in two layers in a cable called as Inner sheath and Outer sheath as shown in below figure.
The cable sheath material will be selected based on the usage/application of the cable and it’s operating temperature.
The applicable standard for the selection of the cable sheath material based on the IEC 60092-359 standard.
Different types of cable sheaths are available to use as per the application. The selection of cable sheaths are different for high-voltage, high-current, fire resistant, fire retardant applications etc.
Types of Materials
The following are different types of cable sheath materials:
  • Rubber
  • Silicone
  • Polyvinyl Chloride (PVC)
  • Polyethylene (PE)
  • Low Smoke & Fume (LSF)
  • Low Smoke Halogen Free (LSHF)
  • Polytetrafluoroethylene (PTFE)
  • Fluorinated Ethylene Propylene (FEP)
  • Neoprene
  • Polyurethane
Standards
The standards for cable sheath materials are mentioned below:
  • IEC 60332-3: Flame Retardant
  • IEC 60331: Fire Resistance
  • IEC 60134: Low Smoke
  • IEC 60092-359: Halogen Free SHF 2
  • Basics of Cable Shields
  • Instrument Cable Routing
  • Thermocouple Selection
  • Select a Pressure sensor
  • Cable Shielding with Ferrites
How to Select a Inductive Proximity Sensor
Control Valve Recommended Practices for Harsh Process Conditions
Location of Measurement Displays
How to Calculate Heat Load in Electrical/Electronic Panel Enclosure
Instrumentation and Control (I&C) Design
  • mahmoud says:
    October 17, 2020 at 2:33 pm
    BS EN 50288-7 allows both Lead sheath and multi-layer sheathing, if i will use multi-layer sheath for control cable what will the disadvantage?
    when i can use multi-layer sheath instead of Lead sheath?
Basics of Fail-safe Circuits
Interactions With Process Control Systems Philosophy
Major issues for Sensors Selection
Floating Vs. Grounded Voltage
Motor Control Circuit Wiring
Remote Seals Transmitters Temperature Error
Remote Seal Transmitters Temperature Error
Instrument Air Quality
Single Line Diagram of UPS System
Pneumatic Piping Design and Specification
Air Consumption Calculation for Control Valves
Air Consumption Calculation for ON/OFF Valves
Vortex Flow Meters
All About Vortex Flow Meters
Level Gauges
Level Gauge Design
Immersion Electrical Heaters
Single and Three Phase Immersion Electrical Heaters Wiring Circuits
Instrument Air (IA) System
What is a Core Type Transformer
Difference Between Core and Shell Transformers
PID-Controller-Simulator-graph
PID Controller Tunning Parameters Simulator
Foundation Fieldbus
Foundation Fieldbus – Advantages, Limitations, Architecture
Power Systems MCQ Series 11
Coil Type Timers in Siemens PLC Programming
Why 4-20 mA Current Signal is used instead of Voltage Signal
Percentage-to-Process-Variable-Conversion
Formula for Percentage to Process Variable Conversion
