Reading: What is an Insertion Flow Meter? – Types, Principle, Advantages
Inst Tools > Blog > Flow Measurement > What is an Insertion Flow Meter? – Types, Principle, Advantages
A classic example of an insertion flow meter element is the Annubar, a form of averaging pitot tube. Learn the types and principles.
Last updated: November 2, 2023 6:59 am
Flow Measurement
When the pipe carrying process fluid is large in size, it may be impractical or cost-prohibitive to install a full-diameter flow meter to measure fluid flow rate.
Insertion Flow MeterAnnubarInsertion-type Turbine FlowmeterAdvantages of Insertion-type Instruments
A practical alternative for many applications is the installation of an insertion flow meter: a probe that may be inserted into or extracted from a pipe, to measure fluid velocity in one region of the pipe’s cross-sectional area (usually the center).
A classic example of an insertion flow meter element is the Annubar, a form of averaging pitot tube pioneered by the Dieterich Standard corporation. The Annubar flow element is inserted into a pipe carrying fluid where it generates a differential pressure for a pressure sensor to measure:
Insertion flow meters
The Annubar element may be extracted from the pipe by loosening a “gland nut” and pulling the assembly out until the end passes through a hand ball valve.
Once the element has been extracted this far, the ball valve may be shut and the Annubar completely removed from the pipe:
Annubar
For safety reasons, a “stop” is usually built into the assembly to prevent someone from accidently pulling the element all the way out with the valve still open.
Other flowmeter technologies manufactured in insertion form include vortex, turbine, and thermal mass.
An insertion-type turbine flowmeter appears in the following photographs:
insertion-type turbine flow meter
If the flow-detection element is compact rather than distributed (as is certainly the case with the turbine flow meter shown above), care must be taken to ensure correct positioning within the pipe. Since flow profiles are never completely flat, any insertion meter element will register a greater flow rate at the center of the pipe than near the walls.
Wherever the insertion element is placed in the pipe diameter, that placement must remain consistent through repeated extractions and re-insertions or else the effective calibration of the insertion flow meter will change every time it is removed and re-inserted into the pipe. Care must also be taken to insert the flow meter so the flow element points directly upstream, and not at an angle.
A unique advantage of insertion instruments is that they may be installed in an operating pipe by using specialized hot-tapping equipment.
A “hot tap” is a procedure whereby a safe penetration is made into a pipe while the pipe is carrying fluid under pressure.
The first step in a hot-tapping operation is to weld a “saddle tee” fitting on the side of the pipe:
insertion flow instruments
Next, a ball valve is bolted onto the saddle tee flange. This ball valve will be used to isolate the insertion instrument from the fluid pressure inside the pipe:
A special hot-tapping drill is then bolted to the open end of the ball valve. This drill uses a high-pressure seal to contain fluid pressure inside the drill chamber as a motor spins the drill bit. The ball valve is opened, then the drill bit is advanced toward the pipe wall where it cuts a hole into the pipe.
Fluid pressure rushes into the empty chamber of the ball valve and hot-tapping drill as soon as the pipe wall is breached:
hot-tapping drill
Once the hole has been completely drilled, the bit is extracted and the ball valve shut to allow removal of the hot-tapping drill:
insertion flow meter installation
Now there is a flanged and isolated connection into the “hot” pipe, through which an insertion flowmeter (or other instrument/device) may be installed.
Hot-tapping is a technical skill, with many safety concerns specific to different process fluids, pipe types, and process applications. This brief introduction to the technique is not intended to be instructional, but merely informational.
  • Transit Time Flow Meter Advantages
  • Segmental Wedge Flow Meter
  • Piston Flow Meter Principle
  • Magnetic Flowmeter Quiz
  • Flow Measurement Questions
What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
Coriolis Flow Meter Uncertainty and Inaccuracy
Working Principle of Vortex Flow Meter
Flow Instruments – Selection, Principle & Application
Different Types of Flow Elements
Troubleshooting Magnetic Flow Meters Common Problems
Difference between Fixed Area & Variable Area FlowMeters
How to do Turbine Flow Meter Verification?
Measure Flow rate using Level Sensors
Design Considerations of Orifice Plate
In-Line Flow Switch Working Principle and Animation
All About Turbine Meters
Orifice Flow Measurement Formula
Basics of Flow Measurement
Impeller Flow Sensor
Impeller Flow Sensor Working Principle and Animation
Turbine Flow Meter Animation
Turbine Flow Meter – Principle, Advantages, Disadvantages
Orifice Plate
Orifice Plate Questions and Answers
Circular Chart Recorder
How to Read Circular Chart Recorder for Flow Measurement?
Linear to Square Root Extraction
Classification of Flow Measurement Techniques
multiphase-flowmeter-working-principle
What are Multiphase Flow Meters? – Working Principle, Advantages
Water Treatment Plant
Difference Between ETP, STP, and WTP – Treatment Plants for Water
Power Flow Through an Inductive Impedance Questions
Artificial intelligence in supply chain management
Interference Immunity (EMC)
How to Troubleshoot Control Valve - Problems and Solutions
How to Troubleshoot Control Valve? – Problems and Solutions
device-specific-diagnostics-to-ne107-status-signals
NAMUR NE107 Standard
CNC Programming - Definition, Types, and Tips
CNC Programming – Definition, Types, and Tips
What is Pump Cavitation
What is Pump Cavitation? How to Avoid Cavitation?
